...let me try! [low-cost street bike] -- last steps...
Re: ...let me try! [low-cost street bike] -- last steps...
Postby silvocross » Sun Mar 18, 2012 12:32 pm
bzhwindtalker wrote:Get hold of a huge pile of used laptop battery for free? This could work, you have a lot of room in that frame for a huge battery! 1-2c cells would not be a problem if you can build a 1kw+ pack
It would be cool, the main prob is to find out all this batteries for a good price, at the moment looking for this RC packs: http://www.ebay.it/itm/11-1V-3S-2200mAh-20C-LiPoly-Battery-for-Trex-450-helicopter-free-shipping-/140719672317?pt=RC_Modellbau&hash=item20c38bcbfd#ht_2004wt_1189
I could dissassemble them and wire up a 12s 8.8Ah pack for about 100€, it isn't really too much, but at I'm a student and at the moment I really can't buy them (I shoud also buy a 12s lipo charger, so almost 120€ more).
Maybe I'd look for a sponsor :D :D
http://progettosilvio.co.nf
If the facts don't fit the theory, change the facts
[A. Einstein]
silvocross
Postby auraslip » Sun Mar 18, 2012 11:10 pm
please don't buy lipo off of ebay. 4s packs from hobbyking are $25. You won't find anything cheaper than that, and the quality will at least be assured.
auraslip
1.21 GW
1.21 GW
Postby silvocross » Sun Apr 01, 2012 1:46 pm
I'm back!
new transmission set:
then I made the upper pvc cover, and glued foam to the aluminium sides to avoid noise:
and here the washing machine!
finally, I found out 4 old and completely dry SLA's, so I'm now trying to resurrect them. I know I shouldn't, but... let me try! :D
[A. Einstein]
silvocross
Postby Byte » Sun Apr 01, 2012 1:49 pm
Which pitch are those gears? And how many teeth are they?
Bergli
Turnigy 80-100 130kv
10S 16Ah LiPo
Castle Creations HV 160
Byte
Postby silvocross » Sun Apr 01, 2012 2:04 pm
Byte wrote:Which pitch are those gears? And how many teeth are they?
they're module 1.5mm, so pitch is 4.71mm => 0.185"
the setup is 17/60 x 21/90 = 0,066
[A. Einstein]
silvocross
Postby Neovin » Thu Apr 19, 2012 5:00 pm
Disclaimer: you should not try this, will result in death if not properly used!!!!!!!!
Ohh reviving batteries, have you tried using AC Rectified through a full bridge and light bulb (60watt) then DC side into battery, it has saved a few sla's for me
_____ _________
AC---------------------- Bulb ----------------- rectifier /--------------------------------------- positive
_____ / /
/ / This side will kill if handled whilst powered!!!
AC------------------------------------------------/ /---------------------------------------- negative
_________
I cant stress enough don't do this if you don't understand this, but this can resurrect flooded, sla, agm and desulphate as well as charge nicd and nimh batteries up to 240v
Neovin
1 W
1 W
Postby silvocross » Fri Apr 20, 2012 11:20 am
thanks neovin, I'll try this for sure!
[A. Einstein]
silvocross
Postby Kin » Fri Apr 20, 2012 12:57 pm
Quick thing- you still need to refill the electrolyte before doing that ACrectifier suggestion.
My guess is that the rectifier is the same thing as the "pulsed voltage" devices. The response has been very mixed as to whether it's sucessful or not at reviving batteries, but the design is to break the precipitated sulphate crystals off of the lead cathode.
But the pulsed voltage stuff will need to be done after you get the general operation of the SLAs back to life (namely, restored electrolyte).
New to endless-sphere? Notice a lot of signatures recommending Ebike.ca? That's because it's the best place for a quality and manageable, (but still 'real'), first build. Justin is a solid supporter of electric bike development, and a good source of equipment.
My hat off a thousand times to the green people that effectively run this forum. The ES Mods are superb.
Kin
Postby Neovin » Sat Apr 21, 2012 4:46 am
yeah you correct there, you can replace the bulb with a motor run capacitor and play with the values to get a fixed amperage pulse, it does make it a lot more efficient too.
After treating an old 24v sla that i received drained down to 11v, it doubled the range of the scooter. another thing that can help is to find a way to fast discharge that helps to get the lead back onto the plates.
here's a link to a brilliant website:
http://batteryuniversity.com/learn/
,Neo
Neovin
1 W
1 W
Postby silvocross » Sat Apr 21, 2012 11:37 am
ok, I tried your method (with a light bulb), now it's time to whait and see if the battery mantain the charge.
thanks!
[A. Einstein]
silvocross
Re: ...let me try! [low-cost street bike] -- adding disk b
Postby cwah » Sat May 05, 2012 2:35 am
silvocross wrote:a quick step ahead... :roll:
The brake isn't arrived yet, so today I made a small rear light.
I didn't want to discharge in different ways the 4 batteries using 12V lights, so i run 15 LED in series and a 400ohm resistor at 50V, the light takes about 20 mA (so 1W) with a very good lighting power.
in the picture you can also see the charging plug:
That's a nice arrow. Where did you purchase the board, led and resistors? I want the same :lol:
Find out best events to do in London: http://www.whatonlondon.co.uk/
cwah
Postby silvocross » Mon May 07, 2012 10:46 am
Oh, it's quite simple to do that light.
- I just bought 14 red 3V LED, for example http://www.ebay.it/itm/10pcs-Car-3mm-Re ... 2900wt_956
- then you need some resistors, I used a total of 400ohm, you can use one of these: http://www.ebay.it/itm/1-4w-Watt-0-25W- ... 5ae44bcdb1
- you can assemble the light on a simple prototype board, like this: http://www.ebay.it/itm/New-5-PCS-Bread- ... 27c6bb209e
note that this setup is perfect for using a 40 - 55V power supply like my series of 4 SLA.
for other voltages you need to rearrange the setup, but it's really really simple. :wink:
PS: I'll be in London this weekend!
[A. Einstein]
silvocross
Postby cwah » Tue May 08, 2012 6:00 pm
Thanks for all these links. I think I may give a try with my 74V setup. I suppose I'd need 24 led :)
What are the resistor for? Why are they necessary?
ps: That's great that you're in london. Planning to see some specific place? be careful it's going to rain ;)
cwah
Postby silvocross » Fri May 11, 2012 3:49 am
You're right, you need 24 LEDs for your setup.
Usually LEDs can admit a maximum of 3.15V, so 24 x 3.15 = 75.6V (when connected in series).
Because of their very low internal resistance, they have to be connected in series with a resistor to limit the current, otherwise current will get really high.
LEDs usually accept a current between 10-30mA.
You also have to add a resistor to pull down the voltage in the circuit. when fully charged, you can reach 78V, so the resistor has to manage 78 - 75.6 = 2.4V.
Finally, the resistor value should be 2.4 / 0.020 = 120 ohm (Ohm's law)
Be careful to always check the LED datasheet to be sure about their voltage and current parameters.
...taking off now!
[A. Einstein]
silvocross
Postby Neovin » Mon Oct 08, 2012 1:52 pm
Bump, how are you getting on?
Neovin
1 W
1 W
Postby panurge » Wed Oct 10, 2012 4:36 am
Neovin, are you referring to the battery resurrecting procedure? or you missed this one, perhaps?
viewtopic.php?f=28&t=42262
Jules
Forsan et haec olim meminisse iuvabit
panurge
Postby silvocross » Wed Oct 10, 2012 6:18 am
Hi!
The project is definitely finished and archived, I just started a new improved build based on the experience made with this first bike.
It should be fun, but the construction has dramatically slowed down because I moved to another city for university reasons.
By the way, it's not completely stopped, I'm designing the electronic interface and... I can say it, you'll be surprised :-)
Sent from my Nokia 3310 using Endless Sphere
silvocross
Previous
Who is online
Users browsing this forum: eride, MattyCiii and 6 guests
