New serious Offroad bike : The Chainer
Re: New serious Offroad bike : The Chainer
Postby bzhwindtalker » Mon Jul 16, 2012 10:44 am
I made some progress and received my new motor and some goodies from bms-battery (along with 40 euros of tax...)
I solved some issues, the pedals are now clearing the frame perfectly, the 51t chainring fits. But I found some new issues : I will need to make room for the left side chain, the tube is in the way right now, and the shock placement will be complicated..
I ordered a flux core MIG to weld this up, I found a model (made in italy) that does 35-95amp for 220€. I never welded flux core but I assume it is easier than stick, and it's still way cheaper than a decent GAz MIG. My tubes are 2mm thick so it should be quite easy.
The BPM motor looks great and well built, apart from the axle that looks plain ridiculous, i'm glad I have this one in a mid drive and not in-wheel :shock: I fitted a 7speed freewheel with all cogs removed apart from the lowest one, 14t. If I keep the 51t, I will be able to keep up with the motor pretty nicely! But 51t looks a bit too big on this small frame :/
Overnight charger, not bad for 17$... if it does not blow up in the next 2 weeks.
bzhwindtalker
Postby renago » Mon Jul 16, 2012 11:15 am
looks to me that the pivot point is a "bit" too high .
mt personal impression .
Renago
renago
Postby bzhwindtalker » Mon Jul 16, 2012 11:27 am
Yeah I must adimit it's quite extreme, but there are other bikes with a similar geometry, exemple :
Not a race-wining bike, but a bike someone spent a lot of money making...
bzhwindtalker
Postby toolman2 » Tue Jul 17, 2012 8:04 am
yep, but that is never going to have huge drive loads, and if it did, it would jack up real bad under acceleration.
-anyway a lower pivot would prolly be better :wink:
toolman2
Postby wildharemtbkr » Tue Jul 17, 2012 9:32 am
The pivot point and the jackshaft are the same point. There won't be any chain pull in his design. His pivot point is just about perfect. It will also make his wheel path follow the same lines as the front wheel does.
The bottom bracket does look pretty high though. I really like this bike.
wildharemtbkr
Postby bzhwindtalker » Tue Jul 17, 2012 10:24 am
Yeah the BB is a bit too high, I messed up my measurements when building..
You are right, as the jackshaft and suspension pivot are at the same place, so chain pull should not interfere with the suspension.
The pivot point only changes the rear wheel trajectory rigth? Having it close to the front foks action does not seem like a bad thing to me but i'm not a suspention expert, I'm actually really far from understanding what makes a good suspention :shock:
There is a number of things that are not perfect in this build, but I never said I wanted to make something perfect :)
I received the velosolo ISO Disc brake mount sproket, money well spent, this thing is beef !
bzhwindtalker
Postby wildharemtbkr » Tue Jul 17, 2012 12:12 pm
Maybe not perfect, but you are making it! I think it will be quite good. A lot of us can sit here and critique your work, in the meantime you've built and ridden 3 or 4 bikes and learned something from each one. This one may not be perfect, but you will be that much closer to knowing what works. So keep up the good work!
wildharemtbkr
Postby bzhwindtalker » Wed Jul 18, 2012 10:14 am
Received my JS! feels like being a kid with a new lego kit, I like that feeling :)
There will be some parts to modify to reduce the width because it is 10-15mm too wide at the moment, I wish I had a lathe... It's stuff I can do with my hacksaw but it sucks to cut those beautifully machined parts!
The whole setup weigths a consequent 1300g. Oh well :roll:
bzhwindtalker
Postby bzhwindtalker » Wed Jul 18, 2012 10:30 am
This is how I will get it to the right size. I will need to find a way to keep the freewheel adapter from moving if I cut the part with those set screws... I can only reduce the width on this side because otherwise the swingarm would be off center.
what I need to cut.jpg (146.98 KiB) Viewed 581 times
bzhwindtalker
Postby bzhwindtalker » Wed Jul 18, 2012 11:20 am
I managed to get the FW adapter from 29,55mm down to 22,5 with two M5 set screws, I will just have to cut the 20mm axle to size and re-thread the 12mm one. Easy game!
bzhwindtalker
Postby bzhwindtalker » Wed Jul 18, 2012 11:42 am
I only have to make the M6 threads deeper on the FW side and call it a success! The outer bearing supports will be cut too to only keep a 1mm flange on the outside to keep the bearing from moving.
One thing I fear is the torsional loads (when crashing for exemple :P ) bending the frame to the point where the bearings jump away from their supports... It would be better to have the flanges on the inside but space is tigth :?
bzhwindtalker
Postby Phoebus » Thu Jul 19, 2012 9:04 am
Subscribed.
Phoebus
Postby bzhwindtalker » Thu Jul 19, 2012 12:34 pm
I did some very good progress today, I decided to use a 15t FW instead of the 10t sproket that would have provided too much reduction! I should have used screw on track cogs instead of freewheels, I would have saved a lot of weigth... I will be able to do it later.
bzhwindtalker
Postby AussieJester » Thu Jul 19, 2012 8:06 pm
Loving it..subscribed
KiM
AussieJester
Postby bzhwindtalker » Fri Jul 20, 2012 12:19 pm
Da frock!! I have no idea what the hell is happening. I just properly ripped off 50mm² of weld on the frame while trying to get one of the bearing supports straigth, the weld seems to be SOOO weak betwen the frame (mild steel) and the machined bearing supports (unknown steel...) :cry:
I need to call the machine service :evil:
bzhwindtalker
Postby bzhwindtalker » Mon Jul 23, 2012 4:56 am
I got a reply from the machine shop, it appears that they machined those bearing supports from 316L Inox! That's why I couldn't weld it with my regular stick rods... I used the parts I machined before in s235, I welded those instead!
bzhwindtalker
Postby bzhwindtalker » Mon Jul 23, 2012 1:29 pm
Actually they machined ALL my parts in stainless :evil: They are giving me a very low price on an updated version in regular mechanical steel (XC38 probably). I changed some measurements in the process to ease assembly. This means that I will need to cut away the threaded part on the old 20MM axle and weld it again on the new one :/
I received my flux core MIG, I went trougth the included 600g of wire way too fast :P The results are quite good but there is a LOT of splatter. I started on the frame and it's doing the job nicely, it just needs a lot of cleanup. At least the welds are good even in tricky positions and places, which was my problem with stick (Arc) : I could pull a almost perfect weld in some position and do the shitiest job in other ones!
bzhwindtalker
Postby bzhwindtalker » Tue Jul 24, 2012 1:40 pm
I almost finished the main frame, I only have to make a cutout to gain a little more clearance under the 15t sprocket but most of the welding is done. The flux core does quite well on 2MM thick steel, it's just messy. After cleanup, the welds look decent
My front half is very heavy :| like 4kg by itself!
bzhwindtalker
Postby Memran » Tue Jul 24, 2012 3:29 pm
Looking very good!
This is the kind of build I want to do, but just don't have the skills. :(
Memran
Postby jateureka » Tue Jul 24, 2012 8:56 pm
subscribed!
Bafang; Mac; Ezee; Easy2Ride; PowerPed; Nope; Condor; Aprilia; eLation V2; Razor
jateureka
Postby renago » Wed Jul 25, 2012 9:25 am
very nice job mate :wink:
the SS 316 is a very nice steel, if you weld it with the right wire , welding is a piece of cake .
also the final result will be nice smooth and elegant .
may I ask what kind of angle did you decide on the front ?
Renago
renago
Postby bzhwindtalker » Wed Jul 25, 2012 12:23 pm
I ordered the parts remade out of E36 with modified tolerances to help out with the assembly and dis-assembly. I'm keeping the stainless parts aside, I will probably find a use for them! The new replacement parts costed 160 euros but they gave me a 50% discount due of the previous issues, I was expecting a lower price but they were very reactive, I don't like being an ass and argue with reasonable and responsive people!
The planned head tube angle is 64° but the real world result could be way off ;) I will probably use this frame to build a serious adjustable JIG, as I think the frame concept is good, I would like to build one out of cro-mo next with a slightly larger frame.
bzhwindtalker
Postby bzhwindtalker » Wed Jul 25, 2012 1:48 pm
I did a mock-up and it does not look good :/ the BB is way too high and the whole frame looks smalish! Remember those are 24" wheels... I may have to start over new :/
bzhwindtalker
Postby renago » Wed Jul 25, 2012 1:54 pm
what about the Cr/mo tubes I highlighted to you .
were they open to sell some to you ?
or maybe you are using this as a prototype frame ?
I will start mine at the end of August after visiting the bike show in Germany .
Renago
renago
Postby ejay » Wed Jul 25, 2012 2:23 pm
could you get away with a shorter axel-crown fork and lower the swingarm any? My custom frame was wrong in the other direction, longer fork and shorter shock got it ridable....
ejay
PreviousNext
Who is online
Users browsing this forum: No registered users and 5 guests
