Miles' Retro-direct gearbox design (schematic)
Postby Miles » Sun Nov 30, 2008 6:54 am
This is a design for a 2 speed retro-direct gearbox.
An extra gearing stage is added by reversing the rotation direction of the motor.
It wouldn't be difficult to make the gear change automatic - based on motor rpm.
It could be built using chains or synchro belt (one double-sided drive belt needed)
with overrunning clutch bearings or conventional freewheels.
The schematic should be self-explanatory, but please ask if you don't understand it.
Left-click the placeholder image in the PDF to activate the 3D model, then click and drag to rotate.
Retro drive-train.pdf
(281.59 KiB) Downloaded 287 times
Miles
Re: Miles' Retro-direct gearbox design (schematic)
Postby deecanio » Sun Nov 30, 2008 7:22 am
fabulous idea and drawing Miles 8) done with alibre?
Cheers,
D
Kona Stinky 2004
Marzocchi JNR T's 2004
72V 10ah lipo
Xlyte HS3540
Lyen 12 FET Jozz mod
deecanio
Postby Miles » Sun Nov 30, 2008 7:27 am
Thanks D,
Yes, I used Alibre.
Download the attached 3D PDF :wink:
You can publish directly to a 3D PDF with Alibre - even in the free version :)
Miles
Postby deecanio » Sun Nov 30, 2008 7:34 am
yes i have it already :) just need to practice with it and read the tutorials - beats the hell out of my paint drawings :lol:
Kona Stinky 2004
72V 10ah lipo
Xlyte HS3540
deecanio
Postby Miles » Sun Nov 30, 2008 7:37 am
I meant download the 3D PDF above, D :)
Miles
Postby deecanio » Sun Nov 30, 2008 7:57 am
soz, i thought you meant the 3d pdf creator :oops: .
oh man that is awesome - how long did that take you to put together?
i have a rubbish flat 2d drawing i want to convert?
how cool would it be if you could import pictures and have 3d??
Kona Stinky 2004
72V 10ah lipo
Xlyte HS3540
deecanio
Postby Miles » Sun Nov 30, 2008 8:06 am
Schematics are very quick to do.
It's stuff like this that takes time:
(235.68 KiB) Downloaded 924 times
Miles
Postby deecanio » Sun Nov 30, 2008 8:43 am
now that's what im talking about 8)
can you knock one up for the stinky in the next half hour ;)
very very cool Miles, oh well i got another 8 hours to kill at work i'll see if i can get a circle up :)
Kona Stinky 2004
72V 10ah lipo
Xlyte HS3540
deecanio
Postby John in CR » Sun Nov 30, 2008 9:57 am
Miles,
I like that in high gear, where we'd spend most of our time, the gearbox would be at its most efficient operation with only essentially an idler/tensioner and 2 freewheels as additional areas of loss compared to a single direct stage. If these grinder 90° gearboxes didn't have helical gears permitting only 1-way operation, I'd give something very similar a try tomorrow.
3 questions:
1. Don't you have an extra freewheel there on one of small pulleys?
2. Will belts work? My concern is low gear with the load is driven by the back side of the belt. Are there belts that work well with loads on both sides?
3. What do we use for the front freewheels? Will bike type freewheels hold up, or do we really need one-way bearings there?
John
John in CR
Postby Miles » Sun Nov 30, 2008 10:36 am
Hi John,
Yes, it's effectively switching between a one-stage and a two-stage gear-box. The extra drag from the freewheel/one-way and the idler should be less than the losses from the additional stage.
1.That's not a freewheel on the smaller of the middle pulleys (or the motor one) - if you look closely (you need to download the 3D model), you'll see it's a multi-spline (essentially the pulley is rigid to the shaft) - I just made everything open so that you could see through.
2. I think it would work with belts or chains. You can get belts with teeth on both sides (not cheap, though...) only the Gates and Conti ones truly have equal rating for both sides though, I think.
3. I think you could use freewheels or one-way bearings - it depends entirely on their spec. It makes more sense to use one-way bearings with synchro belts.
Unfortunately, there's no way to have regeneration with this system.
Miles
Postby boostjuice » Sun Nov 30, 2008 6:42 pm
Thats just brilliant....Well done Miles, its good to have a true engineer in our midst.
You could definately use Cam-clutch style freewheels in at least the larger pulleys. You just have to keep in mind that their torque rating is lower per cubic volume than a bicycle ratchet/pawl freewheel. the tick-tick-tick sound of regular freewheels does definately get on the nerves so using them would be an added 'luxury'.
boostjuice
Postby Malcolm » Mon Dec 01, 2008 5:01 am
That drive drawing is beautiful Miles. I've printed it out and stuck it on my noticeboard, next to the tilting trikes :D Seems wherever I look now you're popping up with fresh ideas – are you on holiday right now or just retired to a life of leisure?
Do you have any feel for the maximum power that a system of this type could transmit. I imagine that the weakest link is the freewheels/one-way bearings, but I've no feel for their upper limit. I'm just wondering if this could be applied to a lightweight motorcycle.
Malcolm
Postby Miles » Mon Dec 01, 2008 5:32 am
Hi Malcolm,
I'm self-employed, like you, so.... :)
I think it should scale up fine. You can get whatever spec. you want, for the one-way bearings - a sprag clutch 60mm in dia. should handle up to about 150Nm of torque. Freewheels like the ENO can probably handle more than 250Nm, I would guess.
Miles
Postby Mathurin » Mon Dec 01, 2008 2:37 pm
Man I hope chineese spys are reading this so they'll make hubmotors with this type of gearing. Something like low gear to ~10-15km/h with high gear to ~30 would be really sweet.
You have to know, not fear, that someday you are going to die. Until you know that and embrace that, you are useless. - Tyler Durden, Fight club. Ditch the fake identity you've created for yourself, walk your own way in a society of mindless drones to become real, you are not your social status.
Mathurin
Postby Miles » Mon Dec 01, 2008 2:45 pm
I'm sure you won't have to wait too long before 2 speed geared hub motors start appearing, anyway. There are a few patents for them floating around, now, and it's such an obvious and necessary next step...
Miles
Postby HAL9000v2.0 » Mon Dec 01, 2008 2:54 pm
Nice work Miles,
I can see this can be used with this setup...
HAL9000v2.0
Postby Miles » Mon Dec 01, 2008 3:28 pm
Certainly.
I was thinking it would be ideal for LH drive to the rear wheel.
For a chain drive, there's always the classic retro-direct set-up - http://www.frankb.us/gears/ - not so compact, though.
Miles
Postby docnjoj » Wed Dec 03, 2008 8:58 am
Miles! That is truly cool as a moose! Now all we need are internal gears that are up to the quality of the freewheels! :(
otherDoc
E-bike stable at our house
My wife and I ride the trikes
docnjoj
Postby spinningmagnets » Wed Mar 13, 2013 8:03 pm
Miles, I'm putting it in this thread because I got the idea from you. Just a minor variation, but this version is "doable" for me. The entire right-side pedal drive is stock. Just found out the GNG motor is reverse-able. So is John in CRs mini-monster.
A recent poster was asking about having a very low gear for off-road, and also a fairly high top-speed for the street. A 3-speed Nexus-as-a-jackshaft might break teeth at 40-MPH power levels. I began trying to remember info from 2-speed discussions. I have been impressed by two builders who ended up using chain and external sprockets for high power. Very robust when using #415 or #219. Since all FWs are straight in-line (unlike BB-drives with one offset chainring), ENO is an option for the FWs.
I've never embraced the classic RD long chain with an idler approach, but I've recently had second thoughts about a RD system using three chains and a jackshaft with 3 freewheels.
Most of the reduction is accomplished by the Left-Side-Drive from jackshaft to the rear wheel (which I had avoided due to the classic one-speed LSD), leaving reasonable sprocket sizes for the rest of the drive. Final drive on the left, two side-by-side RD chains on the right from the reverse-able motor to the jackshaft.
The RED forward-motor gear is pretty simple self-explanatory. If using #25 or #219, the motor-sprocket could be very small and still have at least 11T.
The BLACK reverse-motor jackshaft gear is a Rassy-style with two idlers. I'd spec chain for the reverse-motor gear due to poor belt teeth engagement, but the rest could be belt-optional. Perhaps low gear should be belted so the high-RPMs would be quieter than chain, or the high gear could be belt for the higher tooth-engagement of the motor-pulley?
Anyways here's a graphic of the motor-reverse gear (*goes to get a beer, and then sit down to draw...comes back in a few minutes). Finished drawing, chose LOW gear for forward-motor, and HIGH gear for reverse, but they could easily be the opposite.
Enough chain-tooth engagement if I eliminate one of the idlers?
Found a sprocket diameter calculator, very easy, type in pitch and tooth-count (bike chain is 1/2" pitch, #219/#25 is 1/4-inch) http://www.rbracing-rsr.com/calcsprocketdiam.html
For a larger 2-speed, that has some room for adjusting the difference between the two gears, a 4:1 as low (64T:16T), and a 2:1 in high (32T:16T). Changing the large sprocket in low will reduce the difference between them, both the 16T are ENO freewheels due to their ability to handle higher power, 16T is their lowest tooth-count. Chain is #415.
In order to make a similar gearbox that is as small as possible, the FWs will be moved to the output shaft. Low is an 11T sprocket to a 22T ENO, and high is a 16T sprocket to a 16T ENO. [2:1 and 1:1]. I don't want to make the drive sprocket for low smaller than 11T, so the 16T in high can be made smaller to bring the ratios closer together. If low is the max 16T:11T, the closest ratios are [2:1 and 1.45:1]
Sprocket diameters in #41 bike chain (because we are using ENO FWs):
11T = 1.77"
16T = 2.56"
22T = 3.51"
32T = 5.10"
64T = 10.19"
The large-range trans would be about 12-inches by 24-inches tall (possibly 4 inches wide). The smaller trans would also be about 4-inches wide, 5 inches front to back, and 9 inches tall.
Last edited by spinningmagnets on Wed Mar 20, 2013 9:16 pm, edited 4 times in total. View post history.
spinningmagnets
Who is online
Users browsing this forum: Google [Bot], MattyCiii, psbot [Picsearch], thickhead and 4 guests
