HAL9000v2.0
I started to think about my next bike. It will be downhill based bike with rc motor. First here is sketch of gearing , as I see it. First reduction is with belt drive, then little chain to first cluster of sprockets which is located on pedal axis. second cluster is turned around and it is located on axis of rear swingarm. This is only sketch aand ratios are not correct. Shifting will be done with two aluminum plate which is guided with two arms that make parallelogram and the movement is parallel with plane that lays on top of each sprocket in one cluster. between these plates on front side of the bike will be simple chain guide and on back side chain tensioner similar to rear deluieuer ??!?.
Fell free to comment. I want to hear bad sides...
