recumpence
1 GW
Ok, Ok, Ok, I have been holding out for long enough. I really wanted to wait untill the bike was finished before I revealed it. But, what the hey, here are some "Not quite finished" pics.
The frame is a 2007 PK Ripper Team.
Fork is an aluminum, Echo trials item (very lite and super strong).
Cranks are Echo FW cranks with a White Industries FW.
Front hub is a Hope mountain bike item (36 spoke).
Rear hub is an extremely exotic (read expensive) Tri-All trails hub (also 36 spoke).
Front rim is 34mm wide double wall Sun brand.
Rear rim is a Nimbus aluminum double walled 44 mm wide unicycle rim.
Tires are Nimbus unicycle 110psi tires (1.9inch front 2.1inch rear).
Brakes are Hope Hydraulic 4 piston, floating rotor (160mm rear, 183mm front).
The bike was built from scratch as an EV.
I wanted to make the bike as close to an electric only vehicle without losing "Any" pedalling capability. I love to pedal. So, the pedals are not only for looks. The bike pedals just fine, no drag.
It will be geared (innitially) for 35 to 40mph. I want huge power and accelleration. Top speed is not really a concern.
I made sure the bike is built as strong as possible. Oh, I am also looking at several suspension fork options. If I go that route, I will also suspend the seat for a smoother ride. But, for now, I want to get it running.
The entire drive is overbuilt as much as possible for durability. There are 3 White Industries freewheels to allow the motor to run with or without pedalling without any drag or interferance between the pedals and the E-drive.
The rear sprockets are setup by using a White Industries 22 tooth freewheel drilled 12 times to be screwed to an aluminunm adaptor I made that, in turn, I have a 54 tooth, 94mm BCD chainring mounted to. This was a friggin pain in the neck to do. But, in the end, it turned out fantastic!
The rear end of the bike is pretty much taken to the limit. I cannot fit any wide rim or tire in the frame. I cannot run wider chains without interferance (BMX chains are fine). I had to widen the rear triangle/dropout area to fit the 116mm wide hub into the 110mm wide frame. It fits fine and the dropouts are still parrallel.
The battery is a 12S, 4P Lipo with a 9AH total capacity. Those are 20C cells. So, they should be up to the task of 10kw bursts.
I am hoping for about 47 pounds AUW. That will give me a shade over 3pounds per horsepower. This bike will have roughly 3 times the power to weight ratio of a two stroke motorcross bike!
So, who's got some questions?
Matt
Matt
