Geebee
Looks like lots of new toys coming to Solar bbq.
http://www.ebike.biz/
Lots of stuff that is hard to find in OZ.
Ben said:...the parts scene in Aus is very limited
BiGH said:what kind of bike are you looking at building? hub? chain?
5. geared motor systems are a bit less efficient than hub motors generally
Advantages/Disadvantages over hub motors:
1. hub motors are very quiet some pretty much completely silent. Geared motors via chain do make quite a bit of noise.
2. having to be completely reliant on changing gears for the motor to drive correctly, is quite a bit of work when riding. It doesn't always go to plan, sometimes your not in the right gear etc, also I found that you have to come off the throttle a bit for nice smooth gear changes, so some learned skill involved.
But the biggest difference is this: with a hub motor there is no gear changes, so you dont really have to change gear all that much for pedalling, you tend to rely on the motor alot. But this allows you to have very nice throttle control, I find that I am constantly adjusting throttle so that my pedalling is not forced, its quite easy to be able to ride along adjusting throttle so that pedalling effort is very light or as much as you want to exert. With a geared motor via chain that is more difficult as you are having to go through all the gears to keep motor on right gear setting for your speed, its just more things happening at one time your brain has to deal with, for me personally hub motors are much easier.
3.maintainence: when driving a motor via the gear system there is alot of wear and tear on the chain/gears/freewheels. The amount of force on the chain and cluster is very large, if you can imagine you can yourself supply 200watts of power without too much effort, then apply this by about 3 times ( the max. power output of the geared motors ), and theres alot of banging and crunching going on especially during gear changes with motor power on. So there are problems arise in the commercial systems ( cyclone,elation,epac) where parts need replacing prematurely due to the forces at work ( some problems that I've heard of are chain breakages, freewheels wearing out early and more rapid sprocket wear ).
4. advantage of geared motor system is that on steep hills you can get really high torque using a low voltage system, so you can climb up very steep inclines without pedal assist, but will be going very slow of course. You can do the same with a hub motor if using lithium batteries, you can get the same result but you need to use a higher voltage system ( more power ) to get the same result. I recently did a test comparing a cyclone system 24v, to my 408 motor ( 48v ) on steep hills that were pretty much identical but I was using about twice the power on the 408 as compared to the cyclone. So for very slow going and steep hills is where I think the geared motor systems have a big advantage.
6. doing some test rides against cyclone kit compared with 408 motor top speed of hub motor much better than chain drive.
side note: how can i get the board to resize this pic? or do i have to do it manually?
<img src="http://mywebsite.bigpond.com/islandearth/nci/epac2small.jpg" width="600">
F. getting a meter made similar to drain brain maybe another month or so till ready, price should be about half of drainbrain price.
Toorbough ULL-Zeveigh said:I never quite understood why that's so, given the close proximity to where the stuf gets manufactured. I presume there must be trade barriers in place to keep from getting swamped with cheap imports.
So any idea if he ships to NA? I'd like to see what a P2B can do.
recumbent said:Toorbough ULL-Zeveigh said:I never quite understood why that's so, given the close proximity to where the stuf gets manufactured. I presume there must be trade barriers in place to keep from getting swamped with cheap imports.
a) More information on the "P2B" motor is definately in order 8)
b) I'm curious about the trade barriers between Australia and China (also Indonesia)
Maybe they just have lots of affordable stuff in Ausiland lucky buggers
