Kingfish
Greetings.
For the last few weeks I have been thinking quite a bit about how to build a robust MtB Wheel that can handle long-distance touring and abuse. It began with buying a skinny set of tires for my 9C 2806 hubs; fine for city, but in the greater Seattle area we also have potholes. I fear taco’ing at 25mph. Thus it began the hunt for a good solid solution both for town and for trekking. Currently I have a study on tire size here on tire width:
What is your tire width?
In my search I have narrowed the rim selection down to DT Swiss F 630, or possibly the Mavic EX 729 Disc Downhill 26" x 36mm wide; both good solid rims ready to take abuse. Then it came to me last night that although bicycle tires with rare exceptions, pretty much limit out at 2.5†wide, there might be motorcycle tires in like-sizes that could resolve my durability concerns. The last thing I want when I’m satisfying my high-speed lust, WOT out in there in the open desert between Tucumcari and Timbuktu is to blow a flat or taco the tire. Know what I mean?
The wild-child crazy KF-part of me starts to thinkin: What is the smallest motorcycle tire I can put on my MtB? Small meaning skinny. Turns out that options begin to appear at 18â€Â, 19†and 21†rim diameters, though good luck finding anything narrower than 2.75†tire. Calculating at that size a dual-sport tire on a 21†diameter rim comes to roughly 26.5†in diameter, whilst a 19†rim translates to 24.5†diameter. Both of these are doable. BTW - some info suggests not going larger than 3†wide for any tire/rim combination due to clearance with the rear derailleur.
Pensive, I reviewed my frame and it can take 2.75†wide no worries. My Marzocchi Bomber front shock though is a problem; I’ll need to deflate the tire to get past the V-Brake mounting pins. I was planning on going to disc in the front anyway (er... that’s another project).
OK, now to sort out the rims: Turns out that there are few options here. Rims in this size run between 1.6†to 2.15†and are mostly 40-spoke. However – in diligence I found this source offers 36-spoke rim which is exactly what we need for the 9C hub:
Warp 9. They're a little cheaper here...
Spokes are about 10-gauge; forgive me – we really need to refer to spoke diameters in millimeters. Anything 2.3mm or larger is good.
Cost: With exception to custom-builds (spoke-cutting, rolled, laced) the costs for motorcycle wheels is on par or may be cheaper than going with the high-end downhill bike route. Throw in rim balancing; which is easier?
Conclusion: There’s really quite a gray line between these two worlds. In theory I think I have researched the beefy-arse high-speed tire spec to the nits-end. But more rhetorically, are there a lot of folks out there doing something similar? If I stayed local I think I would be happy in the bike world, but my gypsy soul craves the open sky radical road trip… off the grid, natch.
Imagine: Road Warrior. Rebel Solar-Powered Stations linking the desert expanse! Junk yards and clandestine machine shops. Forget about oil; the war’s about water rights, tofu, and livin’ on the edge…
Give me steak!
Happy Fried’aye. KF
Give me steak!
Happy Fried’aye. KF
