ryan
The Cycle Analyst manual says you can determine your range simply by subtracting Amps used from the Ah of your battery. So if you've used 6.1 amps of a 8 Ah pack you have just shy of 2 amps to get you home.
But what if your 8Ah pack is rated 5C?
I have two 36V20A LiFePO4 Headway packs wired in series but haven't "emptied the tank" yet, so I'm not sure how deep I should expect them to go. I'm told they're rated 5C but that real world results can vary. I guess I'm not too sure what that even means. Thanks for your help.
