Actually, they do make the same contacts for both PP75 and SB50, in a few flavors. Go here:
http://www.andersonpower.com/products/multipole-sb.html
then click the "Drawings (+)" link underneath the "SB50 (50 amp)" subheading. There's a listing then of all the subparts available, including these:
- 1307 Loose Piece Low Detent Contact for PP75 & SB50
5900 (Flared) Loose Piece High Detent Contact for PP75 & SB50
5952 (Flared) Loose Piece High Detent Contact for PP75 & SB50
5915 Loose Piece High Detent Contact for PP75 & SB50
265G1-2,G5-6 High Detent Reel Contact for PP75/SB50
265G3-4,G7-8 Low Detent Reel Contact for PP75/SB50
5914 Loose Piece High Detent Contact for PP75/SB50
5953 Loose Piece Low Detent Contact for PP75/SB50
Loose Piece Low Detent Contact #10/12 Wire for PP75/SB50
Flared Loose Piece Low Detent Contact #6 Wire for PP75/SB50
75BBS PP75/SB50 Busbar Contact
75BBS PP75/SB50 Bus Contact
Oh, and for a complete list of all the compatible contacts for the SB50, its at the bottom of the first page of this document:
http://www.andersonpower.com/files.php?file=DS-SB50(3).pdf
The list of contacts for the PP75 is in this one:
http://www.andersonpower.com/files.php?file=DS-PP75(6).pdf
Something I noticed before but never thought of the implications of is that they also offer a "CR" or chemical-resistant version of the housings, which is also rated for higher temperatures.
- Operating Temperature Range **
• SB Line - Polycarbonate (°C) -20° to 105°
(°F) -4° to 221°
• CR-SB Line - PBT / PC Blend (°C) -40° to 120°
(°F) -40° to 248
It's not much of a difference, but hey, it might prevent a *few* of the failures caused by shell deformation.
AFAIK they don't offer such a thing in the PPxx type housings.
- Operating Temperature (°C)*** -20° to 105°
(°F) -4° to 221°
