Hub "Mid Drive" Build
Re: Hub "Mid Drive" Build
Postby LI-ghtcycle » Fri Mar 11, 2011 11:57 pm
neptronix wrote:No freaking way O_O...
In a way, it makes sense that your efficiency is higher.
Hub motors do have an efficiency range, and if you keep them at peak efficiency, you can really go far on less amp hours.
By the way, do you cycle in the crouched position the entire time, or upright? i hear that makes a big difference.
My riding position is the same as it has always been, slightly forward, I make no attempt what so ever to crouch, the fairing does all the work, however, once I get the helmet I want, I imagine I will have less drag, as a MX helmet with the large visor on the top must cause a good deal of drag.
I think the real difference the fairing makes is in that the slightly forward angle of one's chest when riding makes a rather large "pocket" much like if you had a piece of cardboard about the same width facing the wind, this makes a very high drag "sail".
The fairing eliminates this largest section of drag from the equation, and all the rest is really insignificant by comparison, so that is why I notice a big gain (this is just my thoughts, not anything specifically told me by Karl at Zzip Designs).
Thank you Justin_Le for your selfless act of kindness! We all are in your debt.
My latest build: Vision R40 with Golden Motor "800W" Trike motor as mid-drive, NuVinci N171B rear wheel as transmission, 30 MPH on 12S (46V) 12 AH Turnigy Nanotech LiPo (25-50c) able to climb tall hills on a single Amp Hour! :grin:
http://www.endless-sphere.com/forums/viewtopic.php?f=3&t=29810&p=475990#p475990
LI-ghtcycle
1.21 GW
1.21 GW
Postby Gordo » Sat Mar 12, 2011 12:16 am
AussieJester wrote:
amberwolf wrote:If you happen to find that the ABS wears quickly, try finding an old kitchen cutting board made of the white slippery type of plastic.
Its polyethylene AW....
KiM
AW, Kim;
We have found that the 55US GAL plastic food grade barrels are made of the same stuff (HDPE) and are almost indestructible. The food industry can only use them once so they sell for $5-$10 from yogurt or jam makers. We used it for ski-skins on snow machines to slides on lumber chains. The links of a lumber chain are 1.5" X 4", run 24 hrs per day carrying lumber in a mill. A strip of barrel last @ 10 years.
X-treme 3KW Scooter...OFF ROAD ONLY....Giant 1KW 48V 24" Hubmotor....E-Apex 1KW 48V 26" Hubmotor, built 2012-05-26
Thanks Justin, for saving ES. May Grin Tech grow and prosper.
Gordo
Postby LI-ghtcycle » Sat Mar 12, 2011 12:35 am
KiM
AW, Kim;
Perfect!! Thanks for the tip!!
I just happen to have a black 55 GAL drum of that stuff! Good thing I didn't find a cutting board at goodwill! :D
LI-ghtcycle
1.21 GW
1.21 GW
Postby AussieJester » Sat Mar 12, 2011 8:42 pm
KiM
AW, Kim;
I actually have a couple of meter square 10mm thick sheets of polythene i bought it for my DiY CNC build
I think i sent a couple of strips of it to AW in a package too IIRC? Slippery stuff and wears well is good for chain guides for sure. Don't know of the drums you speak of though Gordo don't think we get them like that in OZ.
KiM
AussieJester
Postby amberwolf » Sat Mar 12, 2011 9:11 pm
AussieJester wrote:I actually have a couple of meter square 10mm thick sheets of polythene i bought it for my DiY CNC build
Yep; if I hadn't already had the cutting board pieces in place, I'd've used some of what you sent for that. However, since it's still intact I can use it for other guides on whatever middrive I come up with for CB2 or it's descendant. :)
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby Gordo » Sat Mar 12, 2011 11:34 pm
KiM
The other source of HDPE I just recalled was natural gas line. Comes in many sizes and colors. Very thick wall. I have pushed a piece of AL pipe inside the HDPE and then a bearing in the pipe. With a grove in the plastic you have a good guide roller.
Gordo
Postby LI-ghtcycle » Wed Mar 16, 2011 12:18 pm
I'm really glad that I have this recorded in the "Efficiency" thread, so that I can be sure that I'm not just excited and exaggerating!
http://endless-sphere.com/forums/viewtopic.php?f=3&t=6615&start=60
Here is the trip I took to Portland to have the Nuvinci built, using the Amped 9 x 7 rear hub motor while it was still in the rear wheel, and the efficiency was about 13 Wh/Mile, and now with the mid drive, 7 Wh/Mile!
I did want to correct something however, I confused myself thinking that at one point I had a 30A controller with 9 x 7, I think this is because I tested a different kit recently that does indeed have a 30A controller, so some of my conclusions were incorrect based on that, however, I am still using a watt meter, and that will keep track of the watts properly no matter what the controller's amps.
I have switched from getting a disc front brake hub to a Sturmey Archer 90mm Drum Brake hub for the longevity of the brake shoes more than anything, but being sealed from the weather, I think this will be a huge asset as well, since not even freezing rain would prevent normal operation of the the front brake, not to mention I won't need adjusting/servicing for many thousands of miles!
Don't get me wrong, I have nothing against disc brakes, but for the lack of maintenance and still have comparable stopping power to good front V-Brakes (when they are in ideal weather/operating conditions) and a proven track record being used on heavy cargo bikes, AND allows me to avoid the whole QR skewer dilemma since it has a solid axle, it's a perfect choice for me. :)
LI-ghtcycle
1.21 GW
1.21 GW
Previous
Who is online
Users browsing this forum: gmaiella, justforfun, mdd0127, pchen92, thewmatusmoloki and 17 guests
