georgefromvt wrote:Busettii bike review. Bike looks ok, just wished I could take one for a test drive before I commit 2 grand.
http://electricbikereport.com/electric- ... #more-2075
grindz145 wrote:Can we all just agree to never use the word invented again, unless one of the following circumstances arises, and a single person comes up with the design:
1. Teleportation
2. Time travel
3. World-food producing machine
4. No-fat no-carb spicy chicken sandwiches
I will consider adding up to 3 more entries, but there just aren't that many things left to "invent" Cripes.
jmygann wrote:Normal Li--ion batteries have a 50% safety shut off setting so you are not
allowed to use the other half of the stored charge. This is to avoid damage to
the battery caused by heat and low voltage. BYI soft pack strip cell
technology solves this problem by not having any metal structure inside the
battery which allows BYI to use 95% of all power in the battery every time.
grindz145 wrote:jmygann wrote:Normal Li--ion batteries have a 50% safety shut off setting so you are not
Huh? Not true.
TheFlyingHandlebar wrote:Hey guys. I recently started a bike rental company in San Diego. http://bikefleets.com/. I attempted to create an electric bike fleet using Busettii. Busetti offered me a 3 year warranty and wholesaled me 12 bikes. It's been less than a year and my whole fleet has failed.
1. The rear wheels will fall apart. They come with wrong sized spokes and wrong lace pattern. The rims and spokes are Garbage as well.
2. The axles might spin in the dropouts. When the axles spin they will rip out the harness and split the aluminum dropouts. These bikes don't have proper torque arms.
3. The hub motors will fail. The spragg clutches will start clattering away within a few months.
4. Motor controls and battery chargers will randomly quit.
5. The batteries will go 50-350 cycles.
6. The battery is not a true 48 volt. The batteries were shorted a cell. The Chinese used 13 cells rather than 14. And the battery manufacture (SYL) closed their doors and changed their name.
6. The alloys of the components such as brake levers, brake calipers, stems, handlebars, racks and forks are the worst of the worst. I had a brake lever snap off in my hand and I also had a customer shear a stem. It snapped right at the neck.
7. The Bottom bracket bearings are misaligned.
8. The head sets are missing ball bearings.( A few of the ball bearing rings were even installed upside down)
9. Every bolt was cross threaded. Including the bolts for the motor control boxes, the racks, and clamps.
I replaced and reinforced every failed component until the motor and the batteries started to go, then I gave up. Busetti didn't warranty a single item.
http://www.youtube.com/watch?v=hXeBZT0f2_w
