Marin Muirwoods eBike (3RD BUILD)
Re: Helmet
Postby TonyReynolds » Fri Dec 30, 2011 4:38 pm
Just scored one of these hummers on close-out:
$63 plus shipping from Dennis Kirk. This helmet got a good writeup earlier this year from another member. Not full-face, but far better protection than my current bike helmet and should be quieter as it goes over the ears. Positive reviews from buyers.
EDIT: Excellent helmet, see Kingfish's review over here: http://endless-sphere.com/forums/viewtopic.php?f=4&t=23862
Third Build: 2012 Marin Muirwoods 4130 Cromoly, 7 speed 11/32 with 500/1000W MAC geared rear motor, 48V System, 52V, 11.5Ah 16s5p A123 lifepo4 triangle battery, DP CA; 20-30+ MPH... GRIN! Build Thread: http://www.endless-sphere.com/forums/viewtopic.php?f=3&t=33819
cell_man... Supplier of A123 Cells and MAC Hub Motors: http://www.emissions-free.com/id47.html
TonyReynolds
Re: Painted Rim
Postby TonyReynolds » Fri Dec 30, 2011 4:56 pm
Rim is now much closer in looks to what came with the marin:
Obviously not as durable as anodizing, but at least I won't have a bright silver rim on an all black bike...
TonyReynolds
Re: Issues, issues...
Postby TonyReynolds » Tue Jan 03, 2012 12:32 pm
I spent yesterday evening swapping the tire, tube and rotor from the stock Marin wheel to the Chinese hub-motor wheel. Both measure 20mm on the inside of the rim, which is good for holding larger tires...
All went well until I tried to get the rotor off the stock wheel. I was finally able to do so with a 1/4" drive socket and the correct 'star' drive tip, the only combination that allowed me enough torque to break the blue Locktite that'd been used to secure the six machine screws. When I tried to install the rotor on teh hub-motor wheel, they bottomed-out in the provided holes and one broke off trying to back it out to add washers. Sooooo, now I have to figure out how to extract a very small broken screw. Will be studying "Screw Extraction 101".
Even with washers as spacers, I ended up with interference between the inside portion of the rear caliper and the hub-motor. I removed that portion of the caliper and used a pattern-maker file to dress the set/adjustment screw (steel) and the aluminum caliper body to try to get clearance. I only need a couple millimeters, so hopefully this will work. I also removed one of the six small screws holding the hub-motor cover, used a bit to increase the countersink and replaced the screw, as they weren't flush, but proud of the surface. I'll repeat this for the remaining five screws/holes.
I'll be taking a tracing of the rear dropouts to develop a CAD drawing to send out for laser-CNC torque plates. Not a lot of room around the dropouts what with racks, fenders and disc-calipers. I can see how (in some ways) a bike with rim brakes can be easier to work with. My previous two attempts were certainly a piece of cake compared to this one...
TonyReynolds
Re: Marin Muirwoods eBike (3RD BUILD)
Postby TonyReynolds » Thu Jan 05, 2012 2:31 pm
Last evening was spent massaging the rear disc caliper to create clearance for the hubmotor, as well as trying to extract to broken machine screw from the hubmotor coverplate. Never having had bike disc brakes before, I was able to figure out how to get some adjustment to move the cliper outboard. My rotor now fits and the motor housing doesn't rub on the caliper. I was however, less than succesful at removing the screw. I wasn't able to drill a pilot hole directly on-center, but tried left-hand threaded drill-bits as well as an extraction set to no avail. At this point I'm looking at tapping new threads for a slightly larger screw for that position and (most likely) ordering another coverplate from cell_man to replace the one I messed up.
:cry:
Oh well, at least the rear brake now works! Now on to creating a torque plate!
TonyReynolds
Postby TonyReynolds » Fri Jan 06, 2012 5:04 pm
Coming along:
Rear wheel and motor are installed. Waiting for Nordlocks to come in the mail. Not certain how to get the Nordlock washers over the motor harness as the wire clip that goes to the controller will have to be dismantled to get the Nordlock threaded over the harness to the axle.
The center stand came in the mail from Velo Orange and is installed (sort of). It looks like it will work, but there's interference between it and the control cables that are routed underneath the bottom bracket. Looks like it's Dremel time... The nice thing about this center stand is that it gets more narrow as it swings into the stowed position, yet is wide when on the ground for good stability. Relatively light too. I don't care too much that it's not steel; I won't be sitting on the bike when it's on the stand. I just wanted it to be stable when parked.
Probably pretty ho-hum to most around here, but it's exciting for me to get something that more closely meets my needs, and the total cost is still WAYYYYY less than I would have spent had I gone with the Ohm 750 last spring, with more watt-hours available, higher speed and much more scaleable and user configurable than a Bionx-based system.
Hope this ends up being useful for someone.
TonyReynolds
Re: Controller Location
Postby TonyReynolds » Sat Jan 07, 2012 2:20 pm
I thought the controller might fit on the support arms for the rear rack. Test fit shows it to be a perfect fit:
The advantage of going with a larger-framed bike shines here. The DiamondBack has a compact-road geometry with a shorter wheelbase. There's much more room on the Muirwoods. The rear holes of the controller line up with the rack support rails; I'll have to use zip-ties or fab a bracket for the front holes. I'll most likely prime and paint the controller black before mounting it. I'm going for stealth, and a largish, bright aluminum box with wire doesn't help me there.
Now to get all the stuff off the bars of the old bike and onto the new...
TonyReynolds
Re: Major Set-Back
Postby TonyReynolds » Thu Feb 09, 2012 9:40 pm
Well, major disappointment today, when I tried to fit the Schwable 622x60 tire to the rear of the Muirwoods. The 622x60 on the front had been almost impossibly tight (not with the frame, but with the front fender), so when I looked at the rear, I assumed there might be a clearance issue with the front derailler and sure nuf, there is:
I was really hoping to get more float for comfort from the fatter tires.
I looked at the diameter specs on Schwable's website, and going down the a 622x50 would *probably* work, but that's another $100 for two tires. I got a deal on the Big Apples: $55 for the two, including shipping, like new with 25 miles on the tires. Yes, I could have checked the Schwable website BEFORE buying the Big Apples, but the frame looked like it had tons of room around the stock tires, so it seemed like they'd work. Looks like I'll have to go back to the 622x42 Continentals that came with the bike.
I'll just have to suck it up and eat the bumps.
TonyReynolds
Re: Major Set-Back
Postby LI-ghtcycle » Thu Feb 09, 2012 10:39 pm
TonyReynolds wrote:Well, major disappointment today, when I tried to fit the Schwable 622x60 tire to the rear of the Muirwoods. The 622x60 on the front had been almost impossibly tight (note with the frame, but with the front fender), so when I looked at the rear, I assumed there might be a clearance issue with the front derailler and sure nuf, there is:
622 x 60 Big Apples, so these are 28 inch tires? Sorry to hear your tires don't fit! That is still my favorite tire, but a good less expensive tire with similar performance is the CST Cyclops for about $15, might even be able to get them at your local bike shop.
Also, I am curious if your hub motor came with screws for the brake disc? It seems most of them are a very different size than standard, I would guess generally shorter.
Sorry to hear about that screw breaking! That is one bear of a problem to fix, especially in aluminum. Have you looked at a heli-coil? You might be able to drill out for the larger size, add heli-coil and then still be able to use the standard sized screw.
Nice looking set-up! I like the black-out look. 8)
Thank you Justin_Le for your selfless act of kindness! We all are in your debt.
My latest build: Vision R40 with Golden Motor "800W" Trike motor as mid-drive, NuVinci N171B rear wheel as transmission, 30 MPH on 12S (46V) 12 AH Turnigy Nanotech LiPo (25-50c) able to climb tall hills on a single Amp Hour! :grin:
http://www.endless-sphere.com/forums/viewtopic.php?f=3&t=29810&p=475990#p475990
LI-ghtcycle
1.21 GW
1.21 GW
Re: Major Set-Back
Postby TonyReynolds » Thu Feb 09, 2012 11:37 pm
Yeah, "28", "29er", 700c are referencing a 622xXX rim, where XX is the tire cross section and 622 is the rim diameter. Confusing, which is why I like the metric sizing system. I'll look into the Cyclops...
As for the disc screws, yes, the motor came with them. At this point, sometime I'll need to take e cover plate off the motor and drill it out from the back side in a drill press and yes, the helicoil nods like a good way to go. That or get a new cover from cell_man.
Glad you like the all-black look, wasn't sure I would but it looks really sharp. Good thing it's crummy rain up here so I don't have to feel bad about taking so long getting his thing on the road.
TonyReynolds
Postby BATFINK » Fri Feb 10, 2012 8:45 am
Nice build Tony. Nightmare with the tyres. I have 2 of the big apples sitting waiting to go on the right bike but I was a little disappointed with how thin the sidewalls of those tyres are. Maybe you should invest in some sort of seat suspension. I have been recommended one of those suspension seat posts by cloud 9. maybe that would do the trick for you.
What is your battery setup and weight if batteries?
How will you hide the cables from your controller and make it waterproof?
Sent using Endless-Sphere Mobile app
BATFINK
Postby TonyReynolds » Fri Feb 10, 2012 11:41 am
BATFINK wrote:Nice build Tony. Nightmare with the tyres. I have 2 of the big apples sitting waiting to go on the right bike but I was a little disappointed with how thin the sidewalls of those tyres are. Maybe you should invest in some sort of seat suspension. I have been recommended one of those suspension seat posts by cloud 9. maybe that would do the trick for you.
I have a Brooks B17 Flyer that is sprung and actually works quite well for butt fatigue. Forearm fatigue relief was what I was hoping to get from the Big Apples.
The controller has been painted black and will bolt to the silver straps that secure the rear rack to the frame.
The wires from the controller go through the opening in the rear frame stay to the battery and points forward. Not much shows. As for waterproofing, the rear fender protects the electronics from spray.
The motor control harness that comes out of the axle was nicked and now the insulation is completely cut. I will have to mark the wire locations for the five-way plug that goes to the controller, remove the clip and slide a section of heat-shrink tubing down over the harness to the axle to protect the wires. The inside edges of that axle are SHARP. I'll see what I can do to de-burr them before applying the heat-shrink.
Oh yeah, battery is an 11.5Ah A123 52V (57V HOC) from cell_man in a frame bag. Motor, batteries and controller add about 18 lbs. to the bike. The Muirwoods is really light for a steel bike. All said and done, bike, electrics, fenders, lights and racks should be about 50 lbs. all told.
TonyReynolds
Postby BATFINK » Fri Feb 10, 2012 12:07 pm
Excellent thanks, great work
BATFINK
Re: Major Set-Back
Postby TonyReynolds » Fri Feb 10, 2012 5:02 pm
LI-ghtcycle wrote:...a good less expensive tire with similar performance is the CST Cyclops for about $15, might even be able to get them at your local bike shop.
Here's the CST website: http://www.csttires.com/Bicycle.aspx
Looks like the Cyclops is no longer in production, but they do have some other tires that looks very nice, in sizes up to 622x50.
Most seem to have reflective sidewalls (NICE!) and some sort of Kevlar puncture protection...
TonyReynolds
Postby joe tomten » Fri Feb 10, 2012 5:17 pm
Other than aesthetics - no reason you couldn't leave the big apple on the front and go with something smaller on the rear?
joe tomten
Postby TonyReynolds » Fri Feb 10, 2012 5:50 pm
joe tomten wrote:Other than aesthetics - no reason you couldn't leave the big apple on the front and go with something smaller on the rear?
Yes, I thought of that. Not sure of how it would look, but perhaps looks don't matter that much...
There's another solution: Remove the front triple ring, crank and derailleur and replace it with a single chain-ring and crank. Not sure i want to go that way, but it's a valid option.
TonyReynolds
Postby Racer_X » Fri Feb 10, 2012 7:12 pm
+1
Do you really use all 21 of your gears? Can you live with 52front and 7 speed in back?
Schwinn Heavy Duti Beach Cruiser, 9c 9x7, Ping 48v 10ah (Retired) NOW 12s3p Lipo, Maxxis Holy Roller in the summer and Schwalbe Ice Spiker in winter.
Racer_X
Postby BATFINK » Fri Feb 10, 2012 8:45 pm
That is exactly what to do, I just did the same thing but I did it by choice, what do you want with all those gears? A lot of road bikes are only 2 cranks at the front nowadays and a lot of downhill mountain bikes are being converted to single cranks. You will never miss those gears, you will save a smidge of weight, lose a cumbersome gear changer and make room on the handlebars and also fit your big apples.
BATFINK
Re: Great Ideas Guys!
Postby TonyReynolds » Sat Feb 11, 2012 12:04 am
I think I'm going to look into this... Not sure how to do it myself, I might have to have my LBS do it.
I know that a 52T front ring is about the biggest. I think I can live with that no problem when the motor's going, but what about peddling it home with no battery? Would 7 gears be enough spread?
It would be nice to eliminate the front shifter and free up some real estate on the bars...
TonyReynolds
Postby DCMotorworks » Thu Feb 23, 2012 8:47 pm
The build is looking Good. What did you end up doing with the front derailleur? I was thinking you could just remove it but leave the original triple ring crank. you can always just stop and manually switch the chain to a different ring as needed. Assuming you would just be using the lower gear ratios on the rare occasion you need to peddle home w/out electric assist this may not be as much of a hassle as it initially sounds.
If, however your riding style has you shifting the front chain ring frequently maybe a top-pull style derailleur would give you the clearance you need? I was going to dig through some parts boxes and find one to snap a picture of but the image of the silver Kona on page 2 of this thread shows the type I am suggesting. A thumb shifter mounted to the seat tube could be used to actuate it eliminating the need to braise on new cable stops and freeing up some handle bar space on the left side.
I know everyone has their own ergonomic preferences so take this w/a grain of salt but I have always tossed the stock brake-lever/shifter combo units so I could mount ebrake cut-off levers to kill the throttle or disengage cruise control or activate a brake light or all three. I find that a twist style shifter controlling the rear derailleur on the left and just the throttle on the right makes for a clean and functional set-up. I don't use a front derailleur on any of my Ebikes at the moment but last time I did I used a twist shift for the rear gears and an old school thumb shifter for the front, both mounted on the left side of the bars. Just my 2 cents.
DC
DCMotorworks
1 W
1 W
Postby TonyReynolds » Thu Feb 23, 2012 11:06 pm
DCMotorworks wrote:The build is looking Good. What did you end up doing with the front derailleur? I was thinking you could just remove it but leave the original triple ring crank. you can always just stop and manually switch the chain to a different ring as needed. Assuming you would just be using the lower gear ratios on the rare occasion you need to peddle home w/out electric assist this may not be as much of a hassle as it initially sounds.
DC
DC, some good stuff here.
I've not gotten any further on the build due to WORK and cold temps in that garage. I *could* live with no front derailleur and change the front chainrings by hand, and thought of that, but looking at the front derailleur, I can't figure out how to get it off without splitting the chain?
As for the handlebar setup, going to a rear derailleur setup only would mean that I could free up some real estate on the bars. I have a gear drive motor, so no ebraking...
Tony
TonyReynolds
Re: Tire/Derailleur Interference
Postby TonyReynolds » Wed Mar 21, 2012 10:09 am
So, I was looking at the bikes I had in my garage...
It turns out that my prior bike, a 2008 Diamondback Century, has a front derailleur that is very compact PLUS, its largest chain-ring is 52-tooth; PERFECT!
I'd asked my LBS what it would cost to have the crank and chain-ring replaced on the Muirwoods with a new crank and a single chain-ring and they said $100+.
Since I have now know I have the parts, I'll take BOTH bikes in and have them do a simple swap of front derailleur, cranks and chain-rings between the two bikes. They *may* have to swap the front shifters, but I doubt it, as both bikes are 3x9, or 27 speeds.
I'll let everyone know how this works, but for right now, being short on time, this is the best solution. Pictures at 11...
EDIT! This didn't work, as there was problem with the bottom brackets. Oh well, a slightly smaller set of tires works. Shoulda gone that way from the beginning...
TonyReynolds
Postby TonyReynolds » Mon Mar 26, 2012 12:31 pm
BATFINK wrote:That is exactly what to do, I just did the same thing but I did it by choice, what do you want with all those gears? A lot of road bikes are only 2 cranks at the front nowadays and a lot of downhill mountain bikes are being converted to single cranks. You will never miss those gears, you will save a smidge of weight, lose a cumbersome gear changer and make room on the handlebars and also fit your big apples.
What are you using to keep the chain jumping off the chain-wheel?
TonyReynolds
Re: Tires...
Postby TonyReynolds » Mon Apr 02, 2012 10:31 am
I bought a set of 29x2.0 (622x50) Big Apples yesterday and mounted them. Though the fit is tight in the rear, they still fit and I have adequate clearance when the rear axle (motorwheel) in in place.
Th ebike just looks so much better with the larger 50mm tires compared to the 42mm tires it came with.
Now I have to sell two brand-new sets of tires, a set of Continentals and a set of Big Apples...
I also had to take a Dremel to the rear fender to hog-out clearance for the front derailleur so that the fender wouldn't interfere. Managed to finally get that done so I could suck the fender closer to the seat tube and away from the tire.
The derailleur hanging off the back of the seat tube is the reason I couldn't run 622x62's on this bike.
Last edited by TonyReynolds on Tue Apr 03, 2012 10:44 am, edited 3 times in total.
TonyReynolds
Re: Bad news...
Postby TonyReynolds » Mon Apr 02, 2012 10:36 am
The cable cover for the wire bundle (harness) coming out of the motor-axle on my rear wheel was already split. Yesterday the wheel fell over and completely split the outer cover, as well as exposed some of the copper in the individual wires that come from the motor:
DAMN!
Now I'm going to have to take the 5-way connector off the motor harness, strip the outer cover completely and run shrink-tubing down each one of the wires to insultae them and then a larger piece over the entire bundle.
The end of the axle is sharp, nevertheless I'm still disappointed that the outer insulation for the harness was so fragile that it split so easily. Guess there's no excuse for stupid...
Anyone else had to deal with this? What was your solution?
Tony
TonyReynolds
Postby Racer_X » Mon Apr 02, 2012 3:47 pm
TonyReynolds can you upload some pictures? might be able to give you some better solutions.
The cable cover for the wire bundle (harness) coming out of the motor-axle on my rear wheel was already split. Yesterday the wheel fell over and completely split the outer cover, as well as exposed some of the copper in the individual wires that come from the motor.
EDIT* I see now you have uploaded some pictures, now it looks crystal clear what the problem your facing is.
Racer_X
PreviousNext
Who is online
Users browsing this forum: Bing [Bot] and 7 guests
