Remove the front triple ring, crank and derailleur and replace it with a single chain-ring and crank.
Do you really use all 21 of your gears? Can you live with 52front and 7 speed in back?
DCMotorworks wrote:The build is looking Good. What did you end up doing with the front derailleur? I was thinking you could just remove it but leave the original triple ring crank. you can always just stop and manually switch the chain to a different ring as needed. Assuming you would just be using the lower gear ratios on the rare occasion you need to peddle home w/out electric assist this may not be as much of a hassle as it initially sounds.
If, however your riding style has you shifting the front chain ring frequently maybe a top-pull style derailleur would give you the clearance you need? I was going to dig through some parts boxes and find one to snap a picture of but the image of the silver Kona on page 2 of this thread shows the type I am suggesting. A thumb shifter mounted to the seat tube could be used to actuate it eliminating the need to braise on new cable stops and freeing up some handle bar space on the left side.
I know everyone has their own ergonomic preferences so take this w/a grain of salt but I have always tossed the stock brake-lever/shifter combo units so I could mount ebrake cut-off levers to kill the throttle or disengage cruise control or activate a brake light or all three. I find that a twist style shifter controlling the rear derailleur on the left and just the throttle on the right makes for a clean and functional set-up. I don't use a front derailleur on any of my Ebikes at the moment but last time I did I used a twist shift for the rear gears and an old school thumb shifter for the front, both mounted on the left side of the bars. Just my 2 cents.
DC
BATFINK wrote:That is exactly what to do, I just did the same thing but I did it by choice, what do you want with all those gears? A lot of road bikes are only 2 cranks at the front nowadays and a lot of downhill mountain bikes are being converted to single cranks. You will never miss those gears, you will save a smidge of weight, lose a cumbersome gear changer and make room on the handlebars and also fit your big apples.
Sent using Endless-Sphere Mobile app
The cable cover for the wire bundle (harness) coming out of the motor-axle on my rear wheel was already split. Yesterday the wheel fell over and completely split the outer cover, as well as exposed some of the copper in the individual wires that come from the motor.
DCMotorworks wrote:I've been potting the wires in place w/ some silicone or other sealant to prevent chafing. Also, on one of my builds I basically drilled a diagonal channel trough a black rubber stopper, fed the wires through and just shoved it on to the end of the axle.
Since you are doing surgery on your wires anyways, this could be a good opportunity to add in-line connectors closer to the axle just to facilitate flat repairs, tire changes etc. It may not be an issue for you but I don't like to have to disturb all my permanent wire routing just to change out an inner tube by the side of the road.
DC
hillzofvalp wrote:On my bike I just run the DC-DC off half the pack. The difference is usually 5Wh at most with my magic shine. It takes one pack about 1-2 seconds longer to charge (two halves).
Looking good. I've been looking for alternatives to the big apple because I want something with more protection. SChwalbe makes a 622 bike tire, but it's only like 1.75" wide or something like that--BUT with a ton of protection.I may ride a large 2.35" rear big apple with a smaller one of these bombproof tires in the front to make me feel safer.
I was thinking of coating my controller in black as well, what did you use? I was looking into this:
http://www.brownells.com/.aspx/pid=1119 ... -HYDE-reg-
Users browsing this forum: annisnumberone, Bing [Bot] and 15 guests
