Kinni420 wrote:So i took a good look at methods post and his site.
great price, great kit, just have a few questions for him and will PM him here after this.
gonna go with the 18s2p setup for this kit (2810R 72v with the 40A upgrade you suggested dog.) Any further condiserations? (torque arms etc?)
Got the marin bike for $16.11. Its too small for me(17 1/2"), needs a different gooseneck so I dont feel like im gonna fall over the front will post a decent pic in a bit here.
BTW since it hasnt been mentioned yet. For the above battery set up can you reccomend a charger and anything else I might need to keep these batteries running at best maintenance? (outside of anything in the kit?)
also, any idea of shipping times for batteries?
To be honest I dont like your charger choice one bit. There are two reasons:
1) You will have to charge your pack in steps - 3 steps - that sucks and leads to imbalance. Dont even think about taking your pack apart to charge in parallel and discharge in series. This always, always, ALWAYS leads to mistakes that cost you a lot of time and burnt fingers.
2) That charger is only 200W. 66V 10Ah = 660Wh so that means it will take a minimum of 4 hours to charge your pack. More likely much longer. 750W is a nice charge power.
I understand you are making due - but please try to get away from changing pack configuration to charge ASAP. At least 1 in 3 of my customers who try this end up making a big mistake. At least 2 in 3 make a small mistake. Take it from a guy who has burnt the skin off his fingers many times..... and I dont make mistakes.
Kinni420 wrote:so, youre charging 4 or 6 battery packs at once on two chargers? If not how do I balance all those cells perfectly? Im still a little fuzzy on how to charge everything properly.
Kinni420 wrote:im spent the day burning my brain trying to figure out how to go from series to parallel for charging. Im pretty smart but wtf? I could use a lot more wires and some switches, would rather not. currently working on a pattern for building a battery/controller box in the triangle out of plastic. Ill post some drawings later
BTW methods wife kit is on the way to my door.
Voltage Cutout: A low voltage cutout is used to protect a battery pack from being discharged too deeply, which can cause cell reversals in NiMH/NiCad packs, permanent cell damage in Lithium packs, and sulfation in Lead Acid batteries. The programmable low voltage rollback allows you to set an appropriate low voltage point tailored to your pack.
Users browsing this forum: Bing [Bot], Google [Bot], Kabbage, melodious, WhatcomRider and 20 guests
