Pulling extended wheelies gets some help from the control system, with a "Power Wheelie" mode for less skilled riders that oversees an adjustable wheelie angle, and a "Balanced Wheelie" mode for more experienced riders where the balance is maintained electronically. The latter mode sees the motor either accelerating or slowing down the e-bike as the rider's weight shifts forward or back.
jateureka wrote:The Audi e-bike looks cool but that seat looks very uncomfortable.
rjoe wrote:that guy should really strap his helmet on
Phoebus wrote:He had a bit of exposure on that bridge climb in the Netherlands.
One of the highlights on the Audi stand at the 2012 Wörthersee was the bicycle technology concept known as the Audi e-bike Wörthersee - a sport bike that does not fit into any of the usual categories. It is neither a pedelec nor a conventional bike, but is best described as a high-end pedelec made by Audi for sport, fun and tricks. The Audi e-bike Wörthersee combines the Audi brand's principal competences - design, ultra, connect and e-tron - and explores the limits of what is technically feasible in terms of design, lightweight construction, networking and electric mobility.
This show bike is futuristic at the very first glance - a bike for tomorrow and beyond. All its components, even the pedals, have been shaped by Audi's designers, for instance the 26-inch wheels made from CFRP that weigh only 600 grams (1.32 lb) each and have innovative large-area blade-pattern spokes.
The Audi e-bike Wörthersee's ultra-light carbon-fiber frame weighs only 1,600 grams (3.53 lb). It makes use of bionic principles derived from nature. Material reinforcements are needed only at the points where loads actually occur. The swinging arm for the rear wheel is also made of CFRP. All in all, the Audi e-bike Wörthersee represents the full extent of the brand's expertise in ultra-lightweight design.
The rear wheel is driven by a chain. The electric motor is a permanent magnet synchronous machine; it is located at the lowest point on the frame and drives the bottom bracket shaft directly. Maximum torque at the rear wheel is in the region of 250 Nm (184.39 lb-ft). Peak output from the electric motor is 2.3 kW - a new top value on the e-bike scene. The complete bicycle weighs only 21 kg (46.30 lb), equivalent to a power-weight ratio of 9 kg (19.84 lb) per kilowatt, or 7 kg (15.43 lb) per horsepower - another record-breaking value
...Peak output from the electric motor is 2.3 kW - a new top value on the e-bike scene. The complete bicycle weighs only 21 kg (46.30 lb), equivalent to a power-weight ratio of 9 kg (19.84 lb) per kilowatt, or 7 kg (15.43 lb) per horsepower - another record-breaking value
MadRhino wrote:rjoe wrote:that guy should really strap his helmet on
That guy is one of the best trial champions of the world. This ride was no more risk to him than walking the sidewalk is to you.
rjoe wrote:MadRhino wrote:rjoe wrote:that guy should really strap his helmet on
Fair enough. I never strap my helmet when I'm walking the sidewalk.
The problem is that it will have less than half the available power that it would have in the wheel (assuming that it's to be run in series with the pedals).rjoe wrote:Would this be do-able with hub motor? I think it's a really elegant solution for mid-drive.
Miles wrote:For those that haven't seen it before: http://www.endless-sphere.com/forums/vi ... 28&t=27132
Miles wrote:The problem is that it will have less than half the available power that it would have in the wheel (assuming that it's to be run in series with the pedals).rjoe wrote:Would this be do-able with hub motor? I think it's a really elegant solution for mid-drive.
Power is the product of torque and speed. Torque output is pretty much determined by motor size. If a motor that runs at >200rpm in the wheel is restricted to running at <100rpm in order to match pedalling cadence, it's speed and therefore its power is halved. If you have a motor in the bottom bracket, it needs a lot of reduction gearing to generate enough torque. Optibike do this with multi stage planetary gearsets, the Audi bike uses a harmonic drive.rjoe wrote:could you expand on this a little, please?
Users browsing this forum: Eskimo, rick-c, wesnewell and 11 guests
