Shortening Wires
Shortening Wires
Postby jasonf150 » Mon May 14, 2012 1:19 pm
Hey I wanted to see if anybody was doing this. Once I find the final location of all aspects of my ebike, mainly the controller, I'd like to remove all the excess wire. Does anyone else do this? Right now I have the wires wrapped around the velcro straps for my frame bag. I think it'd make a much cleaner look to get rid of all the extra wire.
2012 Specialized Hardrock DISC 29er
Crystalyte HS3540 Rear
40A 12fet 72V controller
16S4P LiFePo4 triangle from cell_man
Cycle Analyst
jasonf150
Re: Shortening Wires
Postby motomech » Mon May 14, 2012 2:34 pm
Until you gain more experience, I would recommend against it.
I shot myself in the foot "shortning" the wires on my first build.
I had hidden the controller under the seat and while it was totally out of sight, but I had to stuff the assortment of "cheap kit" connectors and extra wire into a camera case and I didn't like the look of that.
Rashly, I started clipping the connectors, only to find that I needed to learn what connectors I wanted to use, then get them and various accessories and tools ordered, etc. I got side-tracked and when I got back to it, I had forgotten where all the "rat's nest" of wires went. That controller was somewhat unique and I couldn't find a diagram, so I was trying various combo.s when I fried the Hall sensors in my motor :roll:
This time around, A little wiser, I'm stuffing everything into a small mesh handlebar bag.
Even though I am now more versed and supplied with connectors, etc., I'm not going to mess with them until I'm sure on the final configuration. Which motors, controllers[I have a bunch now], controller locations, etc. Depending on which controllers I settle on and what features of the C.A. I end up using is going to change some things, I'm sure. I may even want to "beef" up some phase wires which would be the time to re-do the entire harness.
I am assembling and testing this week and should have some pic.s towards the end of the week.
Can you coil the extra wire up and pplace it the frame bag for now? Or does the controller location prohibit that?
Motomech(reformed I.C.E. enthusiast)
2003 Rocky Mountain Edge w/2WD. , Dual Ananda Q100 "fast wind" W/stk. controllers modd'ed to 17A, 28 mph on 12S Lipo, Stand Alone CA, Cycle Lumenator
2007 GT Idrive 5 3.0, MXUS geared mini/Lyen Mini-Monster on the frt.
viewtopic.php?f=4&t=40567&p=592630#p592630
viewtopic.php?f=6&t=235&p=651777#p651777
motomech
Postby neptronix » Mon May 14, 2012 2:35 pm
No problem doing it, this is basic electrics :)
Make sure you have some heat shrink beforehand to keep it clean. If you are dealing with power wires ( thick stuff ), you will want to solder up things or find a good securing method to link up the shortened section.
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby jasonf150 » Mon May 14, 2012 2:44 pm
I can't fit the wires into the bag because the battery takes up about 98% of the space in the bag.
Cycle Analyst
jasonf150
Postby motomech » Mon May 14, 2012 3:02 pm
Nept.
You have at this for a while and have forgotten what it's like to be noob. And you have a bunch of "stuff" lying around
Even once I decided what connectors, there was the matter of ordering them. One store might have the 4 mm bullets, but not the wire I wanted, etc.
So here I was, trying to consolidate my order and as I work down my list, I keep running into "out of stock". Now, I know that when ordering from the US suppliers, EP Buddy, RC Dude, etc., not to worry about shipping as it doesn't amount to much anyhow. Some stuff I wanted from Hobbyking, but that takes forever.
Soldering I can do, but everything else is a learning experience. Last nite, I spent several hours practicing how to install Andersons on thick[12 ga.?]silicone wire.
Yeah, I suppose I could "twist and tape", everything will be hidden anyhow, that it wouldn't be any big deal. But I thought that if I'm going to be cutting off the kit supplied connectors, that I might as well try and use some quality stuff and do it neatly. And that takes time for a Noobie, at least this one.
motomech
Postby Drunkskunk » Mon May 14, 2012 3:05 pm
Cut them. No problems there. If you need longer wires later, solder on longer wires.
Drunkskunk
Postby neptronix » Mon May 14, 2012 3:22 pm
motomech, you will eventually have a lot of stuff around. I suggest you start buying said stuff, then you can find yourself in my same situation :). Heatshrink, flux, and solder are all you really need here.. all available at your local radio shack in the worst case scenario. You will end up building a stockpile over time if you really get into this.
I've ran out of 4mm bullets like 3 times now and finally learned that i need to keep a few packs of 10x lying around at all times.. but i also have 3 eBikes, possibly going on 4.. okay, yeah i AM abnormal, but remember i came on here knowing zilch, ordered up a 250w cell_man MXUS kit and lipos.. nearly crapped myself the first time i hooked it up when i saw that spark coming out of the battery connector :mrgreen: :lol: :lol:
The best way to learn is to do :)... yeah i've done a lot of doing.. but you can too! this isn't rocket surgery, you can definitely mess up and find your way back.
motomech wrote:Nept.
neptronix
Postby dogman » Mon May 14, 2012 4:52 pm
Those that are doing it, I bet they are Virgo's. I never have, but being a virgo I've been tempted to shorten a few, especially throttle wires that tend to have some extra length. You can tidy up pretty nice just by making one big fold back, and then taping the three wires into a tight package. locate it where it can tuck along the frame in the most inconspicuous spot.
Battery wire or phase wires way too long should be shortened. But I never ran into any all that long. That's the wire with expensive copper in it, so they don't make those so long.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Postby Tench » Mon May 14, 2012 5:03 pm
dogman wrote:Those that are doing it, I bet they are Virgo's.
Spot on!! and glad i am the way i am! :D allthough i like to think it is by concious decission 8)
Making the wires just the right length is all part of a clean neat build, you can always cut and solder with heat shrink sleeves if you dont want to source new connectors. A multi pack of assorted size and colour heat shrink is only a couple of quid.
Simon.
Project Two viewtopic.php?f=6&t=37489
Project one viewtopic.php?f=28&t=20304&hilit=tench
The uk's first Stealth Bomber
Tench
Postby Drunkskunk » Mon May 14, 2012 6:57 pm
Not a Virgo here :D
I cut all mine short and resoldered them inside the controller so I wouldn't have to redo the connectors.
Drunkskunk
Postby MadRhino » Mon May 14, 2012 10:03 pm
I'm not a Virgo either. I'm a Lion, thus didn't feel the need to discuss something so obvious, and just did it. :mrgreen:
Norco A-Line, 50+ Mph dirt bike and winter commuter... sold
Specialized Demo 8 performance dirt bike
http://img715.imageshack.us/img715/5824/dsc03417ae.jpg
Santa Cruz Heckler, lightweight road racer
Santacruz V-10, performance dirt bike
Work in progress:
Trek Session 10
Fatboy
MadRhino
Postby amberwolf » Tue May 15, 2012 3:52 am
jasonf150 wrote:Hey I wanted to see if anybody was doing this. Once I find the final location of all aspects of my ebike, mainly the controller, I'd like to remove all the excess wire. Does anyone else do this? Right now I have the wires wrapped around the velcro straps for my frame bag. I think it'd make a much cleaner look to get rid of all the extra wire.
Once you are really sure you want to shorten the wires, and are ready to do it, let me know. We can work out a time you can come over here and I can help you cut and splice all the bundles together, either by installing connectors at the splice points, or by splicing and covering in heatshrink to protect them.
You would just need to get the heatshrink and/or connectors; I already have the tools needed to do it. If my hands aren't working right at the time I might have to just show you how to do it and then you actually do it, but it's not too hard to do.
The tough part is figuring out exactly how long you want the wires to be, and being *sure* that is how long you want them. Harder to add wire back in than take it out, but possible to do either way.
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby nechaus » Wed May 16, 2012 9:38 pm
you can buy super cheap 75 amp anderson style connectors from hk..
you dont need to solder, just crimp.
Magic pie Dual Suspension
Peak 6kw Air cooled
Kelly controller (mini kbs series, smaller than a coke can, can do 80+ battery amps peak, Favorite small controller. Really punchy)
20s 16ah
60 kmh,
Safe, Beautiful handling.
nechaus
Who is online
Users browsing this forum: Bing [Bot], Google [Bot], OCMike and 22 guests
