Modifying Norco frame.. need advice
Re: Modifying Norco frame.. need advice
Postby iovaykind » Mon May 21, 2012 10:09 pm
I'm running 16s lipo (~66.5v fully charged 4.16v/cell) and this controller is running around 50amps on my 5ah pack. Thinking about making a removable 16s5ah pack to fit onto the bottom of the frame.
Used 4s hardcase packs and had to rewire it into 3s packs, with 1 cell by itself near the controller
Winter needs to end already!
iovaykind
Postby smudger1956 » Tue May 22, 2012 10:36 am
Well thought out mate, well impressed with your 'stealth install'.
Commencal Supreme FS
X-Lyte HS3540
X-Lyte 72v-45 amp sensorless
8 - 5s1p PolyPower Lipo
ABS - 2 fingers and a brain...
smudger1956
Postby BATFINK » Tue May 22, 2012 11:21 am
Thanks man, I'm going to follow your lead with this with a little more modification of the frame and pack loads a lipo in there, I need about 20/30amps or I might do 15amps and I have a battery in my backpack at 48volts 20 amps I can hot swap if going longer distances. Well done. Looking forward to seeing it all closed up and stealthy so post your pix soon :-)
Sent using Endless-Sphere Mobile app
BATFINK
Postby BATFINK » Tue May 22, 2012 11:23 am
I have a freeload rack, that can fit on the rear of the bike and you could easily clip it off and on if you needed to carry more battery on longer journeys, my rack is like this: http://www.freeload.co.nz/store/0/3/Sport-rack
BATFINK
Postby veloman » Sun Aug 26, 2012 11:52 pm
Talk about smart use of space. Great job.
Mush! Mush you electrons! Push harder!
Main ride: Old School Specialized Stumpjumper FSR, Clyte HT3525, 74v lifepo4, 12fet Infineon set to 26amps. And a bunch of others... viewtopic.php?f=6&t=34236&p=497325#p497325.
veloman
Postby BATFINK » Fri Sep 21, 2012 8:32 am
Any updates on your finished bike?
BATFINK
Previous
Users browsing this forum: Bing [Bot], garfong, Google [Bot], mabman, MD., Tpower and 12 guests
