DeathBlade
- Joined
- Oct 18, 2008
- Messages
- 111
Or maybe DiamondPie...
Well I got a new bike to replace my DiamondBack Response that I had with a Yescomusa 48v 1000watt hub on it. I think the hub was a PRO901, ( I have that for sale sans batteries) Since I'm putting the batteries on my new Diamonback XTS, That I scored that from a friend for $300 And I just ordered a MagicPie III from goldenmotor.ca which should be here soon.
Now for the plan I just bend up a set of batteries boxes out of .0625" aluminum tread plate I'll weld those up tomorrow. These boxes will hold four 6s 5ah zippy packs each . I'm going to mount each box on the upper swing arm(?) of the rear suspension with some threaded nut inserts. (if anybody want a semi nice nut insert tool try harbor freight its one of their decent tools). With these boxes I'll have (for now) 12s4p for a 48v 20ah pack for the time being I plan on run the internal MP3 controller and later if the stock controller survives. I'm thinking of putting in some new FETs and caps in it and seeing if I can run it at 24s2p for a fun 88v 10ah pack I got some 120v 60amp mosfets in a free sample a while back.
Now for the pictures,
And now a quick question, how to you think I could lower the bike a bit? my old Diamond back was a 19"~20" frame this is a 21" If I could lower it 1" it would be perfect. I know I have a bit of adjustment if the fork but looking at the rear? I see a bolt slot listing 6" and 7" (travel?) on the rear shock, thought looking at it I think adjusting it from 7" to 6" might make it higher. Any thoughts?
My evil robot for makerfair detroit
