Here is the list of all the things gone wrong with my ebikes
ebike 1:
1) Phase wire fused (Probably my fault for going up hill without pedaling assisting)
2) Clutch locked up (Probably due to the bike being a hardtail and the city's crappy infrastructure with crumbling roads)
3) LiFePo4 Battery gives 1/2 capacity the original capacity after 100 cycle. (This is due to buying from conhismotor on ebay. DONT BUY Lithium battery on Ebay from China)
4) 2 58.4V LiFePo4 charger failed. One came with the original ebay battery and from evassemble. No support from either. (Again probably because I buy from ebay and china without support)
5) Sensor gave out (No idea why, probably due heat? But no idea because the motor has been hotter and it still works. Probably crappy sensors)
6) Controller died (Have no idea why it died, one day, it just stop working. Probably too much vibration on the PCB from the hardtail? Definitely NOT because of heat or overpowering it)
7) 3 racks failed. (This is because of the company false advertisement and my fault for trusting them. I think they since changed the specs)
ebike 2:
1) Spoke broke after 2K miles on a Full Suspension ebike. (Again crappy infrastructure)
2) Spoke broke again after repair (Probably due to poor relacing job and crappy infrastructure too)
3) Sensor died at 2.222K miles (No idea why, it just died all of a sudden. This time the motor was cold when it died)
4) 3x Power supply died. 1 loss 1/2 of it FET capacity, the other 2 just died. (No idea why they died but maybe electronics just fail sometime)
5) Torque arm fell out. (This is my fault by buying fake DP420 epoxy on ebay)
Some of the things have gone wrong was my fault, some it because of where I am using it. And some of it is out my control, i.e. the electronics failing for no reason.
But I guess it partly depends on where you live.
Note I did not list getting flats or other bike related problems because it's related to bike itself. If it was not electrified, I would ran into the same problem.
