Eurobike 2012 & ISPO 2012
Miles
100 TW
London UK
http://www.eurobike-show.com/
Latest press release:
http://www.eurobike-show.com/eb-en/press/press-releases-detail.php?obj_id=309&sMode=detail
....................The Taiwanese company TranzX, which is already one of the leading manufacturers of front-mounted motors, is also gearing up to present mid-mounted motors at Eurobike. Its new M07 system comes in two models of differing strengths, with a range of up to 75 miles...................
The Korean manufacturer Mando will be presenting its Footloose drive system at Eurobike, which is perhaps an even more visionary technology. This system features an important detail that might not be noticeable even at second glance: there is no visible means of transmitting power between the bottom bracket and the rear wheel, such as a chain, belt or Cardan shaft. The key to this riddle is a generator contained in the bottom bracket, which feeds a battery that powers the rear-wheel motor. If desired, the Mando can operate like a conventional bicycle. In this case, the electronic system powers the motor according to the power that the rider applies to the crank by pedaling. The system can also be used like a moped by turning up the throttle. Some e-bike experts believe that this technology is the future of drive systems.
http://www.advancedtechnologykorea.com/11299
http://www.advancedtechnologykorea.com/5452
http://www.bikebiz.com/news/read/eurobike-2012-benchmark-drives-introduces-protanium-shaft-drive/013551
  • Shaft_motor_specs.pdf
Evation detachable battery/drive unit.
http://translate.google.com/translate?sl=de&tl=en&js=n&prev=_t&hl=en&ie=UTF-8&layout=2&eotf=1&u=http%3A%2F%2Fwww.ebike-news.de%2Fneuheit-2013-evation-e-bike-antrieb-fur-e-mountainbikes-zum-anbringen-per-klick%2F2282&act=url
Loving that protanium unit. Thanks for posting these Miles.
We have a local company (Mono pumps) that makes long/thin pumps in a shaft shape for mining applications here in Australia. I saw one deconstructed in the past - a shaft with magnets right up the length of the shaft. I'm a bottom bracket owner/fan but it never occurred to me that a shaft drive bike could have the motor built into the shaft drive. Makes good sense. I guess if that power could be reliably fed into a rear internal gearhub, and the batteries in the frame as shown then the product really does start to look like a traditional pushbike again.
Nice to see design evolving and mainstream companies like Mando picking them up. I deal with them in my work - they are quality obsessed. Let's hope it carries through...
That is just one of their show bikes, they called it a prototype, hence the slack belt.
http://translate.googleusercontent.com/translate_c?depth=1&hl=en&rurl=translate.google.com&sl=de&tl=en&twu=1&u=http://www.ebike-news.de/eurobike-2012-pg-bikes-stellt-blacktrail-2-prototypen-des-exklusivsten-und-schnellsten-ebikes-vor/2586&usg=ALkJrhhkbbfZ6XR74s-I-znqGydZRYka6Q
Some videos of the Mando Footloose:
Apparently it was designed by Mark Sanders.
[youtube]phiDu6gH9zY[/youtube]
[youtube]bW8J9OBageE[/youtube]
[youtube]2w-Uru3hg7o[/youtube]
That gold award ebike pretty much sums up what most people in the EU see an ebike as. Hopefully the speed pedelecs gain a bigger market share. There were great examples on show. I'll post some photos soon.
One of the best looking eBikes I saw on display. The M1 Sport Technik Secede.
It integrated the battery into the mudguard region. It even has a party piece of being able to split in in two for transport. See second image below.
http://www.m1-sporttechnik.de/bikes/secede/bikes.php?type=secede&antrieb=spedelec&farbe=3
Secede S pedelec
The S-SECEDE pedelec goes off like a rocket! It is a sporty urban traveling to Carbon Lifestyle S-pedelec with pedal up to 45 km / h and with a unique appearance and innovative technology - equipped with the latest technology and newest S-Pedelec/Ebike brake / shift technique. With it, you are unbeatable mobile and tremendously fast if. By plane, boat, train or car
save weight and stiffer "full carbon monocoque" frame made ​​by the pioneering M1 carbon technology .
advanced pedelec / Ebike technology with 250 watt e-rear engine and persistent, light 10 Ah lithium-ion battery; pedal assistance up to 45 km / h
Large individualization potential by the configurator.
Integrated management and linking the brake and derailleur cables.
Simple and clean transport through the M1 SECEDE - bags (optional)
