No. Learn more about gears and their inherent losses.Mark_A_W wrote:"Gears: planetary gears are lossy compared against direct drive."
You are kidding me right?
Absolutely true; no argument here.Mark_A_W wrote:Direct Drive motors are bogged down in inefficient low RPMs for ~4x longer than Geared motors.
Yes, because the tiny motor itself is spinning at a high and efficient rpm, as you well know.Mark_A_W wrote:A Bafang on 48v 10A will accelerate as hard as my big DD motor on 60v 30A with 1/4 the power used...we just tested them. I have more top end, but the bafang is amazing for such a small lightweight motor. My motor doesn't light up till ~25kmh, then it pulls till ~45kmh. The bafang pulls from standstill till about 40kmh.
In my real world I drive on level ground at 20mph,Mark_A_W wrote:Yes there is a RPM, which if you just *sat* there forever, the DD motor is more efficient. But in the real world we stop and start.
Reid Welch wrote:[color=#FF0000]No. Learn more about gears and their inherent losses.Mark_A_W wrote:"Gears: planetary gears are lossy compared against direct drive."
I spoke of planetary spur gearing: the most inefficient, nearly, of all gears other than bevel gears.
Then prove it, mate, with words and or piccies? You can get almost any data in a trice from the WWW.Mark_A_W wrote:I am a Mechanical Engineer Reid. I know a reasonable amount about gears.
I hope this was of general interest.840. Bakelite Micarta-D Gears and Pinions. - T. D. Lynch and R. E. Talley. (Elect. J. 13. pp. 368-371, Aug., 1916.)â€â€Noise represents in itself a loss of power, but the chief reason for giving it serious consideration is that it is necessarily associated with vibration. Direct loss of energy due to vibration is of particular importance at high speeds. By eliminating noise, the wear and tear on machinery is reduced and the efficiency of workers is increased. A suitable non-metallic gear material must have sufficient strength to keep the face width reasonably narrow ; it must be hard enough, to wear well, and must not shrink or swell. Metallic reinforcement should be unnecessary, so that two muting gears can be made of equal width to obtain uniform wear. A product of heavy duck bonded with bakelite by heating under very high pressure goes by the trade name of Bakelite Micarta-D. This material is as strong as cast iron ; it is proof against oil, atmosphere, and vermin, and, unless conditions arc unusually severe,, it can be used without bush or flange. The teeth need never be shrouded, and the width of the gear is determined only by the power to be transmitted. The physical properties of this material are: Tensile strength, parallel to laminations, 10,000 Ibs. per sq. in.; compression strength perpendicular/parallel to laminations, 35,000/17,000 Ibs. per sq. in. ; transverse strength, max. fibre stress perpendicular or parallel to laminations, 17,000 Ibs. per sq. in. ; coefficient of expansion (per in. per 1 deg. C., 0-00002 in. parallel to, and 0-000085 in. perpendicular to laminations ; sp. gr., 1-4; weight per cub. in., 005 Ib.; shrinkage practically zero" up to 100° C. ; oil absorption practically zero ; water absorption (50 hrs. immersion at 21° C.), 0-25 to 2 % by weight, depending on relative amount of edge exposed. The same tools may be used as for steel when cutting teeth, but the cutting speed may be increased 25 % and the feed 50 % ; turning may be done at 400 to 500 ft. per min. with a tool of 30° cutting angle and 10° clearance. Metal end- plates should be used on heavy Micarta-D gears, and always when the pitch diam. exceeds 4 times the face width. The thickness of the end-plates is governed by the torque at the hub. With light torque the chief function of the end-plates is to act as washers, and J in. to J in. thickness is sufficient. With heavy torque the end-plates must strengthen the keyway, and should be J in. to | in. thick, or even be in the form of flanged bushings. Notes on design and applications of these gears are given in the original. Spur, bevel, spiral, and helical gears can be made from Micarta-D. In order that they may mesh properly with metal gears, both must be cut true, lined up accurately, and properly spaced between centres. The back-lash allowance should be double that usual for steel. Free lubrication with oil or grease is necessary. Generally Micarta-D gears can be substituted for steel (untreated), cast-iron, or bronze gears, and with the same dimensions as the metal gears which they are to replace ; they will outlast raw hide and other non-metallic gear materials, and, in some services, will outlast cast iron.
grandmasterE wrote:Does anyone have any experience with the BMC 1000W hubmotor yet? If so, give up the details (speeds, acceleration, betteries, and controler)
E.
GTA1 wrote:
The exceptions are brands based in the US etc. like Bionx that source their own components, insist on strict quality controls, and of course, charge sky high prices.
Anyone got any ideas as to how to move this forward?
DahonElectric wrote:All they have done is offer low cost kits with powerful motors at cheap prices. How could a normal Joe and Jane know what to do with it?
Reid Welch wrote:
.....Planetary spur gearing is perfectly efficient as any other sort of spur gearing.
....But it DOES tend to make noise. So "we" gear makers, that is, have long used silent materials for gears....
....Nylon: cheap, quiet, soft, thermoplastic that loses even more strength as heated, it then melts at some point.
....There are,.... a variety of moldable (cheap to make) gear plastics that are tough and forever. Whatever Honda uses in their one-lunger four strokes for the half time gear, is silent plastic, tough, heat proof and durable in this super-severe service. Wham, wham, wham, as the ICE engine explosions shock the gears with every ignition.
....There is no sense in using steel planets in motors of any sort.
Soft steel against soft steel (the ring) make a very poor wearing combination.
Hard steel against hard steel run in oil, like a proper auto transmission, preferably helical cut, is fine. But not soft steel running in grease, not for a long term of say, ten thousand miles. It won't/can/t wear well. And it may tend to be noisy as heck. Or quiet. Depends on the luck of the machinist. But metal against metal spur gears running at high speeds almost always are NOISE.
....Nylon is the worst plastic, practically, for this sort of ebike motor service.
It is not strong enough for long use, especially under shock loads and high temperature.
r.
Why use "cheap" non-metal gears?....64ragtop wrote:I've thought for years why such cheap, soft, high temperature intolerant plastics are used is because They're CHEAP!
No other reason has been presented, so there ya have it!
shady8282 wrote:I'm building a folder. Is there a geared hub motor out there that will go at a decent speed on a 20" wheel at 36v? Maybe I should just ask what is the fastest geared hub motor for a decent price? Advising me to increase to 48v, 60v or 72v is not necessary, I know what that would do. I'm looking to use materials I have on hand and just add the motor without having to double up batteries or buy new ones. So what's the fastest? Sorry to limit my question, but people on endless sphere go off in so many different directions that the original question often gets lost. Thanks.
Users browsing this forum: creatin, ev tocak, gtphanta and 14 guests
