arkmundi
Yes, its possible to over-volt a motor, since the controller will in most instances limit the power delivered and according to a power input signal - throttle. 48V makes sense, where more makes less and less sense. Its more typical for the same wattage to configure in parallel.Gatzloc said:.. A 48v15ah Li-Po battery and The Alloy 07 case + rack
Will this work with the 36v 500w motor (read that it should; ready to replace motor if it doesn't),
You're almost certainly likely to head into the danger zone on this. Ultimately its the amperage delivery into the motor that will be the problem. Current, like a river, flows where it will until it meets resistance - a force that limits current flow to less than its upstream component. You've got greater amperage flowing into the motor and may ultimately fry it. Depends on the motor and how much it was over-engineered.and did I order a bad controller (as in should have gotten the S12SH 800w 35a one).
My thoughts on the controller were that 35a + 800w will be too much for a motor that was 500w + 20a before (Prodeco controller is 36 v + 20a).
The one I got is 750w + 29a I think (read on google somewhere).
You need to work the other way - from motor through wire to controller and battery. You can keep your motor and match components to it, or go ahead and fry it, having to replace it to then upgrade to something that then can handle the power. Its not what I'd do, but hey, if you've got the money and want to do this experiment, go for it! A simpler experiment would be to plug a 110V appliance into a 220V outlet and see what happens (kids, please don't try this experiment at home).
This is just a mish-mash of confusion and completely unnecessary. Most hub motors will have a label. You can also look at a posted datasheet, or call a vendor of the motor and talk it out. The key thing to remember is that for a motor, it has a stated power in watts for a rated voltage (what the battery will deliver) and amperage (current, so what wiring, controllers, etc. are rated to handle). So over-amping will ultimately find its point of resistance and melt that component. Could be a wire, a connector or some internal component to the motor.I figured if I multiply the v * a * w I would get something like a motor power draw.
The default would be: 360,000
The S12P (@48v) : 1,044,000
S12SH (sine wave @48v): 1,344,000
So I would already be putting 3x the current or w.e so I thought not to push it.
I also like a bit of noise 8)
Good luck with that, so this little experiment is just a learning exercise, huh? Alright then, go ahead and fry something. Just remember not to touch the hot thingee.Am I correct in my thinking? Part of the reason I am trying this, is because I am going into electrical eng. in sept so I want to familiarize myself.
Oh, I was mistaken - seems like the cost of things does matter to you (usually does). So I take that back, don't fry anything.I thought of just getting a new lighter 36v battery, but when I looked at how many watt hours I was getting for my money the 48v one was the most cost efficient.
I figured I should get a new battery because at full throttle the 12ah runs down fast. I've seen it run out in under 16k during winter. I did take it for almost 20k last wed. but that was definitely not at full throttle more a 30% motor thing.
