I've been fortunate enough to be able to build a cromotor powered hardtail bike this summer. With a kelly controller it behaves nicely at low throttle, but twist the throttle and it most certainly will try to throw you off. Now it looks as if I will have another chance to build something absolutely crazy, but the question remains; What?
My budget is the equivalent to ~6000 USD and while I do want to build another motorized bike - this revision should be rideable for just about everyone. I live in Norway and in the winter it is icy and snowy. Four wheel drive cars are very popular. I've yet to see an all wheel drive trike completed.
I would therefore like comments on this setup:
Dual front direct drive motors will allow torque vectoring, while the rear motor only is added for peak power output. I'm just about done with a M.Sc EE, so I'm fairly certain that if I do not explore torque vectoring myself - I'll have someone else look into it. High power hub motors will allow swift acceleration, but the trike will go into 60+ kg territory.
As said, any hints and tips are greatly appreciated.
- 2x direct drive front motors
Geared rear drive, MAC
Kelly controllers all around, working in balanced/torque mode
Powerful battery. Power before range
Tadpole trike as starting point
