Hi all, need some help from you. I already have an electric bike, but i don't know much technical details cause i bought it all made.
Now I want to build an electric bike. The main requirements:
1- Easily remove de motor, for this, I think front wheel is better, right?;
2- Light weight;
3- clean design, something like a non-electric bike.
The kit i'm looking at:
http://www.bmsbattery.com/controller/564-q75-front-driving-hub-motor-with-s06p-controller.html
http://www.bmsbattery.com/accessory/231-thumb-level-throttle.html
http://www.bmsbattery.com/ebike-parts/49-pas-pulse-padel-assistant-sensor.html
Do will I need anything more? Cables? Is there a smaller controller that works with Q75 motor?
About the battery, I'm planning to use 6S lipo, which is 22,2v, but the motor and controller are 36v, how does it works? Can I use 6S, will it works?
I also plan to but batteries and controller inside a case under the seat, any suggestions about the case?
Thanks!
2- Light weight;
Thanks!
