arcticfly said:
I´m trying to get my head around how this really works.
Lets say you have 2 identical bikes, both with a 4 turn motor, same sine wave controller, everything the same except the battery. Bike A is set at 80V 100A, top speed 90 km/h, and bike B is 50V 100A. top speed 65.
The use is hooning around in the bush, lots of acceleration and breaking. speed mostly around 50 km/h max speed 65. Since we will never use the extra speed Bike A is capable of, Is Bike B the better more efficient choice? Will bike A accelerate faster up to 50-60 because of the extra Volts?
Not like I will go for bike B
But I´d like to know how it works
Simple generalizations are useful but the devil is in the details, and some understanding of those details is important to answer these types of questions. Perhaps the best way is to spend some time with a good simulator, such as the one at ebikes.ca, our forum owner's business website.
The Motor Controller is a power converter, it converts the battery power (voltage and current) to the (mostly lower) effective voltage and current to drive the motor, as well as other secondary things like making AC and commutating the motor, which we will ignore for this discussion.
The most important value was not mentioned, that is the motor current (also called phase current) limit. Motor current does essentially two things, it creates heat (via I squared R of the windings), and it creates the magnetic field that produces torque. At low speeds the back EMF of the motor (that's the voltage the motor makes as it turns that opposes the battery power) is low, so the power required to make motor current is low. Assume for a moment that the motor current limit is 250 amps just to have a value for this discussion, and using the Clyte 5403 mentioned later in the thread with the simulator.
The operation of the motor can be divided into different regions where different parameters limit the performance. In the lowest speed region, from 0 up to some value, the limiting factor is the motor current limit. This is determined by the motor current limit setting in the controller. This is the highest torque region. If we look at the simulator in this region we see that this particular simulator doesn't implement the motor current limit feature (Justin you might want to add that to the simulator, it is important in the higher power systems). So the reality is that the torque from 0 to some speed the motor current and the torque produced will be flat at this maximum torque value. This is the constant torque region. Increasing battery voltage or battery current will not change the torque in this region, but the battery voltage and current, or power limit will change the speed at which this region ends. Higher voltage has no effect here. This region ends around 5 mph for this setup, when the motor current drops below the motor current limit, assumed to be 250 amps here.
In the next region the torque falls as the limiting factor is power. This is the constant power region, and it extends from about 5 mph to 41 mph in this example. In this region the battery voltage and battery current limit set a maximum power, and this limits the system performance. As the back EMF of the motor increases with speed, the motor current drops, so the motor power input stays essentially constant as the torque drops. This region ends when the motor back EMF rises to the point that the battery voltage can no longer push the battery limit current into the controller. You can clearly see this on the simulator as a small inflection in the torque curve, as well as the peak motor power point. The speed at which this occurs can be raised by increasing the battery voltage or lowering the battery current limit.
The third region is the diminishing power region where the system doesn't have enough battery voltage to fully utilize the battery current limit. The actual maximum velocity typically occurs in this region at the point where the motor output power crosses the system load line. This occurs just over 48 mph in this example.
Now if we drop the voltage to 50V and change nothing else in the simulator we can see what happens.
Now the motor current at zero speed is only about 210 amps, so the constant torque region disappears altogether. The constant power region extends to about 23 mph (instead of the previous 41). The maximum speed drops to about 33 mph (previously 48).
It is no surprise that an 8KW system has higher performance than a 5KW system. It also stresses the controller more, in both voltage and current. The losses at higher voltage and higher current in the controller are slightly higher, but these are not a significant fraction of the system losses, most of those are in the motor at the high torque end of things that occur at low speeds.
Making torque requires current which makes heat in the motor. The battery voltage and current don't change the heat the motor makes for a given torque. Only the motor or gearing can change that. There is a detailed discussion covering the heat to make torque factor here on ES, if you want to dig deeper into that.
