LewTwo
I have seen pictures of Bicycles where someone put a small holes in the bottom of the bottom bracket tube (of course I can not find one now).
The chain stays, seat tube and down tube are all open to the bottom bracket tube. If any condensate, moisture or water accumulates in these tubes then it would drain into the the bottom bracket tube. Assuming one has a sealed cartridge bottom bracket or a sleeved cage bearing bottom bracket, does it make sense to put a small hole (maybe 1/8 inch diameter) to allow it to drain?
