Wye did I do it?
Wye did I do it?
Postby dontsendbubbamail » Sat Jul 25, 2009 6:00 pm
Jermey Harris made me do it. :wink:
I decided to try a wye configuration on my 3KW motor so that the KV would be about the same as my 6Kw motor. This allows me to use just one jack shaft and to be able to switch motors without changing the gears.
Will this cause me a problem? As you can see, I broke a couple of wires while teasing the wires apart. It was a pain in the butt because there was a glue at the junctions where the wire were twisted together.
What is the best way to remove the varnish from the wires?
Bubba
dontsendbubbamail
Re: Wye did I do it?
Postby rkosiorek » Sun Jul 26, 2009 2:50 pm
dontsendbubbamail wrote:Jermey Harris made me do it. :wink:
<snip>
What is the best way to remove the varnish from the wires?[/b]
Bubba
heat it quickly with th hot end of a propane torch. not too much you want to charr the lacquer without heating a big chunk of wire. clean off the charred lacquer with a wire brush that has either copper or brass bristles. all wire brushes shed particles of the bristles. steel or stainless particles can infiltrate the copper and make it more difficult to solder later.
rick
DISCLAIMER:
We will not be responsible for damage to equipment, your ego, blown parts, county wide power outages, spontaneously generated mini (or larger) black holes, planetary disruptions, or personal injury that may result from the use of this material.
- Samuel M. Goldwasser -
rkosiorek
Postby Jeremy Harris » Mon Jul 27, 2009 11:47 am
Sorry, Bubba.......................... :oops:
Hope you fix it OK.
Jeremy
PS: I've done a couple now and they've both been OK, maybe I was just lucky.
Jeremy Harris
Postby ron van sommeren » Mon Jul 27, 2009 4:16 pm
dontsendbubbamail wrote:... What is the best way to remove the varnish from the wires? ...
Use real Aspirin. First post, tip #27
http://www.rcgroups.com/forums/showthread.php?t=240993
Vriendelijke groeten ;) Ron
• brushless motor building tips & tricks • diy brushless motor discussion group
• Drive Calculator download & discussion group • int. electric fly-in, Nijmegen, the Netherlands
ron van sommeren
Postby dontsendbubbamail » Mon Jul 27, 2009 7:05 pm
Thanks for the help. OOPS!!! I did something wrong. I got it wired up in the wye configuration and gave it a try. It was running good on 12S for about 30 seconds. There was a spark and then that wonderful smell of burning wires. Now the motor turns with resistance, so something is shorted. Oh well shit happens.
I am just going to blame it on Jermey for making me do it. :wink:
Maybe I will try and rewire it. Where is a good place to get the multi-strand wire that Turginy uses?
Bubba
dontsendbubbamail
Postby ron van sommeren » Mon Jul 27, 2009 7:10 pm
Single strand gives you a better copper fill factor.
ron van sommeren
Postby 12p3phPMDC » Mon Jul 27, 2009 8:24 pm
Sounds like fun......
So, the Kv is supposed to drop considerably,
130 to 70 perhaps?
"If you don't follow your dreams, you might as well be a vegetable." Burt Munro
The reasonable man adapts himself to the world;
the unreasonable one persists in trying to adapt the world to himself.
Therefore all progress depends on the unreasonable man.
-- George Bernard Shaw
12p3phPMDC
Postby Miles » Tue Jul 28, 2009 12:58 am
12p3phPMDC wrote:130 to 70 perhaps?
130 to 75, I think.
Miles
Postby dontsendbubbamail » Tue Jul 28, 2009 10:58 am
This was my 3kw motor. It was 230kv to 131kv.
Bubba
dontsendbubbamail
Postby 12p3phPMDC » Tue Jul 28, 2009 11:27 am
Is it a 12 pole stator?
What kind of winding pattern are you gonna try...?
(thanks to Ron for posting all the winding info!)
LRK (interesting variant, uses less wire, possible with 12p not 9) ?
Distributed LRK ?
Are you gonna copy the original winding?
12p3phPMDC
Postby ron van sommeren » Tue Jul 28, 2009 11:59 am
12p3phPMDC wrote:... LRK (interesting variant, uses less wire ...
LRK was the original diy winding diagram introduced by Christian Lucas and Ludwich Retzbach in their ElektroModell magazine articles, back in 2000. It's easier to wind because you don't have to deal with neighbouring coils. dLRK uses less wire, due to the fact that the winding heads are smaller. But Kv is 10% higher.
Original EM articles at bottom of page, in English:
http://www.aerodesign.de/peter/2001/LRK ... x_eng.html
12p3phPMDC wrote:... LRK ... possible with 12p not 9) ? ...
For SPS/LRK you need on even number of statorpoles:
http://www.aerodesign.de/peter/2001/LRK ... oclaw.html
Motor_rewinding_101
http://www.gobrushless.com
-> knowledge base
-> basic overview (1-5)
Tips and tricks, checks and tests, may keep you from frying yer ESC and/our controller:
12p3phPMDC wrote:... So, the Kv is supposed to drop considerably ...
By a factor 1.8. If the powersignals were sinusoidal- instead of trapezoidal-shaped, the drop would be sqrt(3)=tan(60).
full throttle power signals
part throttle, with PWM chopping
Last edited by ron van sommeren on Thu Jul 30, 2009 9:02 am, edited 1 time in total.
ron van sommeren
Postby dontsendbubbamail » Tue Jul 28, 2009 2:00 pm
12p3phPMDC wrote:Is it a 12 pole stator?
Distributed LRK ?
I would copy the existing winding, but for now I think I will put this project last in line. My hxt 80-100 is still going strong, so I will use it for build 3. Build 4 will be creating a lighter setup, assuming I like build 3. The smaller motor will save me almost 2 pounds over the hxt 80-100 and still should have all the power I need.
Bubba
dontsendbubbamail
Postby 12p3phPMDC » Tue Jul 28, 2009 2:05 pm
Ron,
Thanks for the correction re: LRK and dLRK.
Lots of reading to do!!
Bubba,
It'll be interesting to see what the current winding style is when the time comes.
12p3phPMDC
Postby ron van sommeren » Thu Jul 30, 2009 8:42 am
dontsendbubbamail wrote:... Where is a good place to get the multi-strand wire that Turginy uses? ...
http://www.mwswire.com/
http://www.planetengineers.com/
Mind you, multistranded wire is easier to wind but gives a lower copper fill-factor. If wire gets to thick to handle comfortably, I'd go for 2-3 wires in parallel, but not multistranded (=litze) wire. See
translate.google.com...www.aerodesign.de/peter/2001/LRK350/Skin-Effekt.html
and
http://www.powercroco.de -> English
-> theory
-> Solid or stranded?
ron van sommeren
Postby dontsendbubbamail » Thu Jul 30, 2009 9:07 am
The more I read the more I want to rewind the motor. Ron, thanks for all the links.
Bubba
dontsendbubbamail
Postby ron van sommeren » Thu Jul 30, 2009 9:16 am
ron van sommeren wrote:... LRK was the original diy winding diagram introduced by Christian Lucas and Ludwich Retzbach in their ElektroModell magazine articles...
Christian Lucas, the 'L' in LRK, earns his money working on 'slightly' larger motor designs at www.magnet-motor.de (English).
Ludwich Retzbach, the 'R' in LRK, an EE too, is a renowned German e-flight author, www.elektromodellflugpraxis.de
• brushless motor building tips & tricks • diy brushless motor discussion group • int. electric fly-in, Nijmegen, the Netherlands
Image Image
MagnetMotor ship propulsion motor
Last edited by ron van sommeren on Thu Jul 30, 2009 9:51 am, edited 2 times in total.
ron van sommeren
Postby ron van sommeren » Thu Jul 30, 2009 9:28 am
dontsendbubbamail wrote:The more I read the more I want to rewind the motor ...
Hook, line and sinker :) I'm pure evil :mrgreen: :mrgreen:
Last edited by ron van sommeren on Thu Jul 30, 2009 11:44 am, edited 2 times in total.
ron van sommeren
Postby GGoodrum » Thu Jul 30, 2009 10:31 am
Holy crap, that's a big-ass motor! :shock: I'm sure Luke is already trying to figure out how he can mount two of these on something... :mrgreen:
GGoodrum
Postby Miles » Thu Jul 30, 2009 10:46 am
GGoodrum wrote:Holy crap, that's a big-ass motor! :shock: I'm sure Luke is already trying to figure out how he can mount two of these.....
:mrgreen:
Miles
Postby ron van sommeren » Thu Jul 30, 2009 11:21 am
ron van sommeren wrote:Single strand gives you a better copper fill factor.
Which leads to higher efficiency :)
Higher efficiency does not only mean that the motor makes better use of the batteries' power, it also means the motor is able to handle a higher power input before hitting its maximum temperature mark i.e. a the power/weight ratio will be higher.
An example:
Say the motor has an efficiency of 70% and it can handle 500Watt input. That means it can get rid off 30%*500=150Watt excess heat. Now, by cramming in thicker wire (and/or using better stator-iron, segmented magnets), efficiency increases to say 75% (I'm a bit optimistic here). The motor's ability to loose those 150Watts has not changed (by radiation, convection and conduction). This means the motor now can handle 600Watt before it hits the 150Watt (25%*600Watt) losses mark. An efficiency increase of 5% gives an increase in the power to weight ratio of 20% (from 500Watt to 600Watt). That's why efficiency plays such an important role, in any motor design: efficiency governs maximum power. The motors weight may have increased a bit due to more copper.
If you increase efficiency of a 80% efficient motor to 90%, specific power would increase by factor 2, i.e. 100%more.
ron van sommeren
Postby rkosiorek » Thu Aug 20, 2009 9:33 pm
thanks for the tip ron. tried it toay ant it works great. now i don't need to haul out the propane torch.
i had to re-do the leads on a motor and a big 48V CT. 8A transformer. and i decided to try out the aspirin. i first used up my last 2 pils of name brand stuff. having a few more leads to do i used up some really cheap no-name stuff from a discount store. and it worked even better. less smelly smoke and less residue to clean up.
later i mentioned this to the pharmasist and he was not surprised. according to him the cheap stuff has a higher concentration of the active acid and fewer fillers and buffers.
rick
DISCLAIMER:
rkosiorek
Postby dontsendbubbamail » Mon Oct 05, 2009 11:37 am
As I sit here dead in the water with all my controllers blown and waiting for the new stuff to arrive, I decided to take apart my dead HXT 80-85. This one is the newer design that has the large bearing supporting the front of the bell. It was cooked when I blew my last CC controller.
I wanted to try to tease apart the winding leads so that I could practice rewiring it in the wye configuration. Getting the motor apart was not hard. Once you get the large support bearing for the bell off, you are left with the bearing tube assembly and the stator. This seems to be held together with the same glue that was used for the magnets. The good and bad news is that they didn't spare the glue. It was all over the wires and that is no way they could be seperated and rewired as a wye.
Now my thought was that maybe I could rewind the motor. Getting the wire off was not too bad. Except for the fact that some of that glue was holding the wire to the stator and I bent up a couple of the top stator plates while pulling the wire out. I put the stator and bearing tube assembly in the oven and heated it to about 220 F, but could not separate the two. It may not be necessary to separate the two as this design has more space to work with on the motor mount end.
Bubba
dontsendbubbamail
Postby etard » Tue Oct 06, 2009 4:49 pm
Hey Bubba, you got any pics of that motor teardown, or at least of the empty parts? I am interested to know this. It seems if the process is not too complicated and parts are easy enough to find, then it would be cool to always have a spare bolt on motor, in case one gets fried. Heck it might be wise to have an extra controller on you ( even a cheap one) the are so light and small. But if your batteries go, might as well call it a day. :wink:
etard
Postby dontsendbubbamail » Tue Oct 06, 2009 7:14 pm
Here be the pics.
Bubba
(97.08 KiB) Downloaded 515 times
dontsendbubbamail
Postby etard » Tue Oct 06, 2009 7:38 pm
Dang, ask and ye shall receive. Thanks man. :x
Wind it up dog!! That motor could be an opportunity to make it better. I wonder how much a rebuild costs, also wonder if you could try to wind it for a lower KV. Put some nice bearings in there and your back in biznass!
etard
Next
Return to Motor Technology
Who is online
Users browsing this forum: Google [Bot] and 2 guests
