Wye did I do it?
Re: Wye did I do it?
Postby ron van sommeren » Thu Jul 30, 2009 9:16 am
ron van sommeren wrote:... LRK was the original diy winding diagram introduced by Christian Lucas and Ludwich Retzbach in their ElektroModell magazine articles...
Christian Lucas, the 'L' in LRK, earns his money working on 'slightly' larger motor designs at www.magnet-motor.de (English).
Ludwich Retzbach, the 'R' in LRK, an EE too, is a renowned German e-flight author, www.elektromodellflugpraxis.de
Vriendelijke groeten ;) Ron
• brushless motor building tips & tricks • diy brushless motor discussion group • int. electric fly-in, Nijmegen, the Netherlands
Image Image
MagnetMotor ship propulsion motor
Last edited by ron van sommeren on Thu Jul 30, 2009 9:51 am, edited 2 times in total.
ron van sommeren
Postby ron van sommeren » Thu Jul 30, 2009 9:28 am
dontsendbubbamail wrote:The more I read the more I want to rewind the motor ...
Hook, line and sinker :) I'm pure evil :mrgreen: :mrgreen:
Last edited by ron van sommeren on Thu Jul 30, 2009 11:44 am, edited 2 times in total.
ron van sommeren
Postby GGoodrum » Thu Jul 30, 2009 10:31 am
Holy crap, that's a big-ass motor! :shock: I'm sure Luke is already trying to figure out how he can mount two of these on something... :mrgreen:
GGoodrum
Postby Miles » Thu Jul 30, 2009 10:46 am
GGoodrum wrote:Holy crap, that's a big-ass motor! :shock: I'm sure Luke is already trying to figure out how he can mount two of these.....
:mrgreen:
Miles
Postby ron van sommeren » Thu Jul 30, 2009 11:21 am
ron van sommeren wrote:Single strand gives you a better copper fill factor.
Which leads to higher efficiency :)
Higher efficiency does not only mean that the motor makes better use of the batteries' power, it also means the motor is able to handle a higher power input before hitting its maximum temperature mark i.e. a the power/weight ratio will be higher.
An example:
Say the motor has an efficiency of 70% and it can handle 500Watt input. That means it can get rid off 30%*500=150Watt excess heat. Now, by cramming in thicker wire (and/or using better stator-iron, segmented magnets), efficiency increases to say 75% (I'm a bit optimistic here). The motor's ability to loose those 150Watts has not changed (by radiation, convection and conduction). This means the motor now can handle 600Watt before it hits the 150Watt (25%*600Watt) losses mark. An efficiency increase of 5% gives an increase in the power to weight ratio of 20% (from 500Watt to 600Watt). That's why efficiency plays such an important role, in any motor design: efficiency governs maximum power. The motors weight may have increased a bit due to more copper.
If you increase efficiency of a 80% efficient motor to 90%, specific power would increase by factor 2, i.e. 100%more.
ron van sommeren
Postby rkosiorek » Thu Aug 20, 2009 9:33 pm
dontsendbubbamail wrote:... What is the best way to remove the varnish from the wires? ...
Use real Aspirin. First post, tip #27
http://www.rcgroups.com/forums/showthread.php?t=240993
• Drive Calculator download & discussion group • int. electric fly-in, Nijmegen, the Netherlands
thanks for the tip ron. tried it toay ant it works great. now i don't need to haul out the propane torch.
i had to re-do the leads on a motor and a big 48V CT. 8A transformer. and i decided to try out the aspirin. i first used up my last 2 pils of name brand stuff. having a few more leads to do i used up some really cheap no-name stuff from a discount store. and it worked even better. less smelly smoke and less residue to clean up.
later i mentioned this to the pharmasist and he was not surprised. according to him the cheap stuff has a higher concentration of the active acid and fewer fillers and buffers.
rick
DISCLAIMER:
We will not be responsible for damage to equipment, your ego, blown parts, county wide power outages, spontaneously generated mini (or larger) black holes, planetary disruptions, or personal injury that may result from the use of this material.
- Samuel M. Goldwasser -
rkosiorek
Postby dontsendbubbamail » Mon Oct 05, 2009 11:37 am
As I sit here dead in the water with all my controllers blown and waiting for the new stuff to arrive, I decided to take apart my dead HXT 80-85. This one is the newer design that has the large bearing supporting the front of the bell. It was cooked when I blew my last CC controller.
I wanted to try to tease apart the winding leads so that I could practice rewiring it in the wye configuration. Getting the motor apart was not hard. Once you get the large support bearing for the bell off, you are left with the bearing tube assembly and the stator. This seems to be held together with the same glue that was used for the magnets. The good and bad news is that they didn't spare the glue. It was all over the wires and that is no way they could be seperated and rewired as a wye.
Now my thought was that maybe I could rewind the motor. Getting the wire off was not too bad. Except for the fact that some of that glue was holding the wire to the stator and I bent up a couple of the top stator plates while pulling the wire out. I put the stator and bearing tube assembly in the oven and heated it to about 220 F, but could not separate the two. It may not be necessary to separate the two as this design has more space to work with on the motor mount end.
Bubba
dontsendbubbamail
Postby etard » Tue Oct 06, 2009 4:49 pm
Hey Bubba, you got any pics of that motor teardown, or at least of the empty parts? I am interested to know this. It seems if the process is not too complicated and parts are easy enough to find, then it would be cool to always have a spare bolt on motor, in case one gets fried. Heck it might be wise to have an extra controller on you ( even a cheap one) the are so light and small. But if your batteries go, might as well call it a day. :wink:
etard
Postby dontsendbubbamail » Tue Oct 06, 2009 7:14 pm
Here be the pics.
Bubba
(97.08 KiB) Downloaded 515 times
dontsendbubbamail
Postby etard » Tue Oct 06, 2009 7:38 pm
Dang, ask and ye shall receive. Thanks man. :x
Wind it up dog!! That motor could be an opportunity to make it better. I wonder how much a rebuild costs, also wonder if you could try to wind it for a lower KV. Put some nice bearings in there and your back in biznass!
etard
Postby dontsendbubbamail » Tue Oct 06, 2009 8:50 pm
Rewinding is something I would like to do, but my main goal is to get my bike running again. I have two 18 fet Infineon controllers on the way. One will be run stock and be my backup controller. The other will be modded and possibly destroyed, but I will not touch the backup controller. I have a blown 6fet and a 12 fet controllers that I may try to bring back to life with some of the 4110s that I got from Methods. If HobbyKing will ever get more stock, I will also buy an 2 extra motors. One to experiment with and one will stay stock as a backup. I am tired of not being able to ride because I have blown something up. I have lost at least two months or more of riding due to not having replacement parts.
Bubba
dontsendbubbamail
Next
Return to Motor Technology
Who is online
Users browsing this forum: No registered users and 6 guests
