nieles wrote:hi,
i also added some hall sensors to my turnigy 6374 brushless motor.. and i am very pleased with it. much smoother than with a sensorless controller.
it is cnc'ed from some clear acrylic i had laying around.
Fabbe wrote:Hey guys,
If I use winding sequence AabBCcaABbcC for a 12 teeth/14 pole motor and I want to place the hall sensors with 120 mechanical degrees on the inside of the motor, does it matter where each Hall sensor should be placed? Can I for instance use this sequence: A H1 a b B C H2 c a A B H3 b c C ? Or is it dependent on the controller type? Is it trial and error then or is there a quick way to determine the right place?
Cheers!
odedelen wrote:Hi Guys,
I would also like to Add Hall sensors to my AXI 5325/18 ( http://www.modelmotors.cz/index.php?pag ... &line=GOLD )
Nieles, I see that you mounted 3 Hall sensors spaced at about 1 centimeter from each other (which is not 120 degrees between each sensor).
What does it mean when saying you mount the sensors at 120 or 60 degrees? Is it 120 degrees between each sensor? When 60 degrees, should 6 Hall sensors be mounted spaced at 60 degrees ?
How far from the can should the sensors be mounted? is there an ideal distance from the can?
Any answers or additional images would be greatly appreciated !
Thanks
mani9876 wrote:Hello!
Can someone say me, how I know the distance between 2 of the hall sensors for my motor ( Turnigy C8085 170kv )
Thanks
ATB,
Manuel
Whiplash wrote:Will this setup work with any hub motor controller? Just curious if controllers like Lyen's controller will work with these??
By the way I just read through all this stuff and I feel like I at least have a basic understanding of how it works, so THANKS! I think I might be able to do this after all! LOL! I am considering ordering my first motor to play with soon!
ONE MORE QUESTION. How are you finding this, 17.1* spacing? Are you putting a degree wheel on the motor or something? Is there a tool I need?
nieles wrote:i made this drawing for a forum memeber, so i will post it here also.mani9876 wrote:Hello!
Thanks
ATB,
Manuel
the distance between 2 sensors is 17.14 degrees with my setup (posted earlier)
Whiplash wrote:OK guys, I guess I didn't make the question clear, how do I actually determine the degrees on the motor? Do you use a degree wheel mounted on the shaft, or do you just use a protractor and more or less guess at the correct alignment? It can be quite hard to figure degrees on a round object without a degree wheel or something...
mwkeefer wrote:Jeremy - gwhy,
Is there some advantage with specific models of motors for different hall spacing, as in better performance, lower no load current, etc?
Just wondering if KISS still applies and putting sensors @ 120 degrees around the casing doesn't make more sense?
Sorry for being ignorant, I've actually modded a few outrunners now but I just counted off the slots and guesstimated 120 degree placement then tuned for lowest no load current....
Thanks in advance!
-Mike
gwhy! wrote:Whiplash wrote:OK guys, I guess I didn't make the question clear, how do I actually determine the degrees on the motor? Do you use a degree wheel mounted on the shaft, or do you just use a protractor and more or less guess at the correct alignment? It can be quite hard to figure degrees on a round object without a degree wheel or something...
Hi Whiplash,
How I done it was to draw a circle of the dia of the motor then divide the circle up Just like in the drawing in my previous post. There are no alignment issues because when the halls are mounted ( they are not fixed to the motor but to the mounting plate) they can be adjusted to give the correct alignment.
Thanks in advance!
-Mike
mwkeefer wrote:Luke,
I could be mistaken on this but... isn't the difference a matter of flipping the middle hall to take it 60 degrees out for delta?
I know that inverting the output of the B phase hall via will correct the issue for many controllers but I've never had timing issues flipping delta / wye with infineons and stock 120 degree spacing (experience only on DD hub motors).
-Mike
Users browsing this forum: No registered users and 5 guests
