olaf-lampe wrote:I don't see a reason, why you couldn't put them 120° apart... anyone?
Just make sure they see the whole diameter of the magnets, otherwise you waste precious dutycycle.
-Olaf
1) Can you explain the 120° theory? I'll give it a go now actually...I pieced this together from various sources so I won't be surprised if it's very wrong.
To place Hall sensors properly in a motor, you have to know how many electrical degrees each tooth occupies:
°elec = 360 * p / t where p = number of pole pairs & t = stator slot count. For my motor °elec = 360 * 6 / 9 =
240°The first sensor is placed anywhere - this becomes zero degrees. I will place mine dead center of a tooth as this is "timing neutral". The second sensor must be °elec ahead of the first sensor. Each tooth is 240 electrical degrees. Begin at the position of sensor A as this is 0°. Add the °elec to each previous position until you reach 120° (this is the desired location of the sensor). Obviously each time you pass 360° you subtract it.
So you end up with:
1) 0 + 240 = 240.
2) 240 + 240 = 480. Subtract 360 = 120. The number of iterations is 2 and seen as you are at 120° the second sensor should be placed
2 slots away from the first.
You now treat the second sensor as the starting point in order to place the 3rd sensor 120 elec° from it. You get the same result for sensor 3. So according to my maths my sensor placement should look like this:
If I was to do as you have suggested Olaf, there would be 2 empty teeth between each sensor.
Can someone clarify this? What's right!?!?!
