bigmoose wrote:Arlo as you get into the dspPIC you can set the dead time in software.
Lebowski wrote:Have you guys thought of using a class D audio driver like this:
http://www.silabs.com/products/audiovid ... i824x.aspx
if you look at the datasheet you'll see that a class D audio circuit is very (very !) similar
to the circuits that we use to drive one pin of the motor. See the datasheet (under documentation)
figure 38/39 on page 23. A class D amplifier uses square waves (like we do) of a few 100 kHz
to drive a speaker (which is like a linear motor).
With this particular IC the dead-time between the high and low side can be programmed by
chosing an external resistor, everything is taken care of inside the IC.
Interesting bit about this IC is that isolation is obtained not by using optocouplers but
by using radio signals.
Luke wrote:Little cell phone chargers (from modern USB based charge phones) tend to output a stable 5v (at 500mA-1A), and handle an input range of ~80vdc to 250vdc. Methy found some vendors on ebay selling them for $1 shipped from China... And about 3/4th of the types he tried we NOT isolated, so they shock your face with 110vac if you answer the phone while it's charging. lol He let me find that out for myself when I asked if I could charge my phone.
BUT... a couple types were fully isolated, and $1 each shipped from China. Otherwise you can get known-good-isolated units for like $4-5 each.
You would need Methy to confirm (he has a box of every type offered on fleabay), but I think this model was indeed fully isolated:
http://cgi.ebay.com/1000mA-5v-USB-Unive ... 4108wt_905
This one also was isolated i think... but I can't remember exactly, they all look similar:
http://cgi.ebay.com/USB-AC-Power-Supply ... 152wt_1139
Unfortunately, while a genuine apple usb charger is totally isolated, all the units on ebay in the apply charger-cube format were unisolated face-shockers.
oldswamm wrote:Arlo, I just discovered this thread.
You should look at the dsPIC30F4011. I don't THINK you lose anything. The extra memory might find a use, it usually does.
The CAN interface is easy to implement, and might be useful for an automotive ap?
The Runner will get 4wd, right?
I love it. I too am jealous.
Bob
I know, I read the whole thread. I'm thinking down the road. The CAN would only require 1 8 lead IC added to the boardArlo1 wrote:I already ordered 2 dspic30F3010-301/SO and have the 2 pic18f2431 chips in my box.
The Road Runner will burn something as long as I can hold out. The SRT4 is gettng hybrid assist electric rear wheels asap.
and I want insane power!
oldswamm wrote:]
Actually I was going to suggest something similar to that for the Road Runner. It NEEDS front wheel assist, doesn't it?
I knew that to.
Njay wrote:It's a piece of cake Arlo, you'll see
Njay wrote:I was referring to learning to develop software
Lebowski, try an AVR, you'll like the 4x+ speed increase over the PIC
Users browsing this forum: gwhy!, PowerPedro and 6 guests
