liveforphysics wrote:You can burst 45hp from each Agni motor for the 8seconds your pass is going to last. They are 24lbs each, and you only need a small sprocket and chain and a 3lbs bracket to mount each one.
http://www.electricmotorsport.com/store ... i_b95r.php
A controller like this, with the motors powered by it in series would work well for your 8second bursts.
http://kellycontroller.com/kdh14800d24- ... p-742.html
Then you want to run this 5s pack 8 in series, for a total of 40s input to that controller. It will be 148v nominal voltage, does your 144v class rules allow that much fudge room? Otherwise you buy 6s packs of the same series cell and run them 6 in series.
You will want to run those packs 3p, which will average about 50-60C discharge on the cells, and keep them happy.
So, that means buying 24 of this pack:
http://www.hobbyking.com/hobbyking/stor ... _Pack.html
Now buy a light Kart chassis on craigslist. Get a non-shifter kart, like a rotax-max series kart chassis, because you don't need the front brakes and extra linkage and crap.
That above formula will reach your desired goals.
howler45723 wrote:WOW, great stuff you guys are way ahead of me, I was looking at some forklift motors, lots of torque and 5500 rpm, what do you think about these batteries
EnerSys Genesis Pure Lead XE16 24v 15 lbs. ea
our class is 144v, but can read at batt 158v at meter
thanks again for all your suggestions and knowlege
liveforphysics wrote:Worst possible battery choice on earth for drag.
zombiess wrote:Cheap, fast or reliable. Pick two.
liveforphysics wrote:howler45723 wrote:WOW, great stuff you guys are way ahead of me, I was looking at some forklift motors, lots of torque and 5500 rpm, what do you think about these batteries
Users browsing this forum: No registered users and 7 guests
