New Crystalyte 5403 Review by Doc
Re: New Crystalyte 5403 Review by Doc
Postby Doctorbass » Wed Apr 04, 2012 12:40 pm
wojtek wrote:what is the hub spoke hole size please?
I will take the mwasurement tonight :wink:
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby Doctorbass » Wed Apr 04, 2012 12:42 pm
sn0wchyld wrote:
Drunkskunk wrote:Thanks for posting this! I feel like a kid waiting for Christmas morning, waiting for mine to arrive.
I wounder if the added width is due to these being a special run of the motor? Perhaps its easier to produce a small run by hand, and not get them compressed as tightly as a normal production run would be?
I feel a bit the same, even though I've dropped out of the buy! I'm glad I did, because I'm more interested in offroad, something these things are simply to big for, but I'm defiantly looking forward to seeing what people are able to do with 'em!! Who's going to be the first to force air through 'em? with the acre or 3 of space you have inside I'd be thinking a custom heatsink on one side to increace the internal surface area by a few 1000 percent or so, and some whacking great fans on the other to suck as much air though as possible... 10kw continuous anyone????? :twisted:
also, it appears from the pics that it might be possible to fit a array of holes around the edge of the magnet ring, on the outer side of the spoke flanges. that way, and internal fan would be drawing air in directly over the windings, and pushing it back out on the other side (ignoring a bit of loss from going between the magnets and stator). that should result in some pretty epic cooling levels! like this (please forgive my crude paint skills!)
That's a good idea! but the holes will be drilled in nearly 10mm of steel :lol: .. i just wonder if it would accect the magnetic field return from the rotor magnet...
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Doctorbass » Wed Apr 04, 2012 12:43 pm
Drunkskunk and Oatnet,
thanks for teh appreciation :wink: it's always my pleasure to share these info.
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby zombiess » Wed Apr 04, 2012 2:05 pm
Doc, you still have the inductance listed in mH vs uH :wink:
Stop the other projects and get this thing in one of your bikes, we want to see if you can set a new record!
Greyborg Hub Motor, Lyen 18FET, Customized full suspension kids MTB. Top Speed 61 MPH
9C 8x8, 24S2P LiPo, Lyen 12 FET, Diamondback Recoil Comp. Top Speed 42 MPH
GreyborgUSA Dealer
zombiess
Postby John in CR » Wed Apr 04, 2012 2:59 pm
I'm not being hard on you Doc, just pointing out that maybe this thread should be something like "dimensions and pics of the guts of new Xlyte 5403", which is useful info and appreciated by everyone. Then put your performance review in the Ebike review section. Please try to be a bit more humble with the claims, especially when using the word "continuous". How long are you calling "continuous" with your 5303 at 111kph and 11kw? 1 minute or did you get on the highway and ride many kilometers to another town WOT all the way?
A couple of reminders for you, since you're shooting for max potential, I'm sure you want maximum cooling air flow. Keep the left and right covers identified when angling the holes. Also, I firmly believe the angled stator slots on the X5's are an important aspect of their cooling, because the spinning air of at the magnets is caught by the angled slots of the stator causing an air flow through the magnetic gap from one side to the other. If you have fans or one sided air intake, take advantage and enhance that natural flow, or at least be sure you aren't fighting against it like happened with your forward angled perimeter exhaust vents on the earlier motor that killed the cooling.
I can't wait for the videos you produce so well, so I have something to shoot for. :mrgreen:
John
John in CR
Postby Doctorbass » Wed Apr 04, 2012 3:53 pm
John, I am planning on making a review. But from now it’s time that is missing me.. the motor is still opened ready for the mods but yes I could modify the name of the thread.
For the 113kmh, I can say 100% sure it was temperature stabilized because while riding I saw the temp rising from 95 celsius and than staying at constant 121 celsius for about 2km at WOT power was 11kW and at that speed the motor efficiency is 80% so 2.2kW of heat to evacuate with a drilled side cover and airflow at 113km/h.
That’s a great observation about the stator angled tooth that improve cooling I never thought about that fact.
I’ll see what can I do with that.
Next for me is to remove the axel and machin it for having wider slot for the 10 gauge phase wire width
For sure i'll make a video of that!
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Doctorbass » Wed Apr 04, 2012 8:08 pm
Update: Drilled Side cover!!
I made 16 holes carefully positionnned so that the rehenforced structure part of the center of the side cover is not affected.
The idea is to have the max drilled surface area directly in front of the stator winding to minimize the side cover to reflect the heat produced by the winding and alo to allow more air to circulate.
All holes are 1 inch diameter and are right aligned on the winding :wink:
These side cover are 1/4 inch thick! :shock:
I think i removed 103 cubic centimeter of aluminum ! = 278g total
Well this is the first step for the cooling mod.
Next is to find a hydraulic press to remove the axel to be able to machin it to be able to cary the 3 gauge 10 phase wires.
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Doctorbass » Wed Apr 04, 2012 8:09 pm
hub spoke hole size : 211-212 mil :wink:
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Hyena » Wed Apr 04, 2012 8:35 pm
Doctorbass wrote:These side cover are 1/4 inch thick! :shock:
Wow! I was about to comment about the holes being so large and close together but I guess with a cover that thick you can get away with it.
This thing should take a bazillion amps with those cooling holes 8)
www.HyenaElectricBikes.com
Aussie high powered and custom e-bike kits
My build and HD video thread__. My youtube channel
Hyena
Postby itchynackers » Wed Apr 04, 2012 9:20 pm
My spoke holes are 3.57mm diameter. What am I missing here?
9c 9x7f w/ 12awg phases
9c 8x8r w/ 10awg phases, temp sensor, vented
9c 6x10r w/ 10awg phases, temp sensor, liquid cooled, 3rd Place Pikes Peak 2012!
"Don't argue with the galactically stupid...they drag you down to their level and beat you with experience"
itchynackers
Postby Doctorbass » Wed Apr 04, 2012 10:51 pm
a mil is a thousandh of an inch :wink:
a mm is a thousandh of a meter :wink:
It's 39.37mil per milimeter
so in milimeter it's 5.37mm :wink:
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby neptronix » Wed Apr 04, 2012 11:54 pm
LOL... haven't even ran the motor stock yet, or got it spoked.. and you already got holes in the covers.
I love this forum.
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby wojtek » Thu Apr 05, 2012 2:27 am
:D
thanks a lot gentlemen!
3.57mm diameter vs 5.37mm .. hmm i would expect all of 54xx having the same size?
Doc
WIRES AND CONNECTORS
viewtopic.php?f=31&t=30176
http://endless-sphere.com/forums/viewto ... 31&t=32244
http://endless-sphere.com/forums/viewto ... 31&t=32152
Go-One Evo tested with HS3540, now working on Cromotor
BATMOBILE - Astro 3220 / Nuvinci in progress
Velokraft e-VK3 / Max speed 90km/h downhill - EVKA [for sale]
Steintrike Mungo Sport HS3540-SOLD
Scorpion FS HS3540-SOLD
Kona Dawg BMC v2-SOLD
wojtek
Postby o00scorpion00o » Thu Apr 05, 2012 6:44 am
LOL nep yeah, I'm thinking, DOC get that on a bike and test it quick!!! :mrgreen:
Back to pedal only power.
o00scorpion00o
Postby itchynackers » Thu Apr 05, 2012 7:13 am
I guess I'm used to you posting in metric. Anyway, I guess I got the small spoke hole version. :wink:
Anyone know how many parsecs it is from spoke hole to spoke hole? :wink:
itchynackers
Postby grindz145 » Thu Apr 05, 2012 7:45 am
Cromotor Vs 5403 drag race.... :mrgreen:
Seriously, this whole hubmotor thing... where will it end :twisted:
http://www.endless-sphere.com/forums/viewtopic.php?f=18&t=19548 - Ebike Nerd Podcast
Thanks to Justin @ ebikes.ca! Go there, buy stuff. Support the Revolution :D
grindz145
Postby esoria » Thu Apr 05, 2012 8:34 am
WONDERFUL!!!!
Beautiful motor DOC, i'm really curious to see the difference with Cromotor, in performance! :)
I remember my 5404 and this is a great motor, only a bit heavy, but POWERFUL, this 5403 i think is VERY fast!
esoria
Postby Doctorbass » Thu Apr 05, 2012 8:53 am
For your pleasure: :lol:
5.37 millimeter = 1.740298479e-19 parsec
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby o00scorpion00o » Thu Apr 05, 2012 8:58 am
Ah Doc, you got out of bed at last! :lol:
Now please lace that motor up, get it on a bike and test. pleaseeeeeee :mrgreen:
no more motor pics and data bla bla hurry up man! :twisted:
o00scorpion00o
Postby Andje » Thu Apr 05, 2012 9:38 am
guys, its not going to "go faster" then the 5303... the advantage will be seen when doc goes to a higher voltage AND amperage because it will last longer at those levels, but it's mostly thermal sinking that this extra motor width offers. It will give someone like doc an advantage since he was pushing that barrier before and can now push it harder, but at most it will survive and perform extreme amperage accel better because of a higher saturation point. Anyway, I'm just saying, i want a vid of it on the bike too, but jut watch docs old vids and pretend it's a thicker stator; it will be exactly the same to see everything but the temp sensors, which is just data anyway! The cool thing would be seeing how long it could MAINTAIN say 120km/h. I can put 95km/h WOT (10kw controller) through my current 5304 for my entire battery pack, but it heats up a lot more under hard accel/deccel, enough that at higher energy levels (120km/h prbly 20kw) it might burn up using a 1.5kw hour pack. Going to a 5403 wind and a higher voltage will get me the extra speed I want, and this thicker heavier motor is for lasting through that instead of burning. But just chucking it on my current bike would literally decrease performance due to the extra weight, and gain me only heat sink and maybe some acceleration if I changed my controller; as it is putting out 10kw would remain 10kw in the new motor.
Im actually most interested to see how disk brake callipers will be to fit on there. For some reason the dimensions look tight to me :).
Norco 125 Dirt Jumper
100v 15ah Lipo Backpack
lyens 18 fet, 100v 100 amps, R12 Regen
x5304- 95km/h
http://endless-sphere.com/forums/viewtopic.php?f=3&t=24594
Norco A-Line Park 2009
144v Kelly 300amp
5403/ future HS60
http://endless-sphere.com/forums/viewtopic.php?f=6&t=35652
Andje
Postby Floont » Fri Apr 06, 2012 3:26 pm
Andje wrote:...Im actually most interested to see how disk brake callipers will be to fit on there. For some reason the dimensions look tight to me :).
I, too, am very interested in what kind of clearance difficulties we will be running into... especially on the disk brake side.
Build 2: (present build): Rear x5304 on full suspension Mongoose, 127v 30s3p 10aH Turnigy Lipo, Lyen 24FET 100amp controller, CA2.2, 26" Hookworm front, 26" Crazy Bob rear, 203mm disc brakes, Airzound horn, twin Blaze 2 watt front lights - ~54MPH top speed
All my posts on this site are licensed under the Creative Commons Attribution-Noncommercial-No Derivative Works 3.0 License
Floont
Postby scriewy » Fri Apr 06, 2012 9:18 pm
doc why you wanna put 10g phases if 2.74mm is already over 10g, 2.588mm = 10g
it's a pitty i wont stay to see the world crumble, u jedi Scum
clyte 405,
went through battle, bloody resurected Dewalts 4x28v 2s2p usable 2.7ah, 52v drops to 44v at 54kmh
78v 2ah Vdrop to 58v at max 66kmh.
72kg rider + 23kg bike.
keywin 20a 30-70v mod to 6 4110 as methods advised for noobs, shunted 38a
clyte 24-72v 40a mod 4310 to 4110, shunted to 77a
17.5.11 - 5000km
at 78v 4ah 72.7kmh Vdrop to 68v
10.11 - 82.1kmh
30.8.12-17000km
a place for lasers as ES is for e-vehicles - laserpointerforums.com
scriewy
Postby Doctorbass » Fri Apr 06, 2012 9:50 pm
scriewy wrote:doc why you wanna put 10g phases if 2.74mm is already over 10g, 2.588mm = 10g
It's because the existing wire are 11 gauge, not 10... also, the high resistant silicone skin of the wire is better than the existing fragile teflon wire :wink:
I never had any problem with the silicone wire used on phase wie.. but the teflon frafile thin skin can puncture easy and make short... or at high temp it become soft and even more fragile.
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby gensem » Fri Apr 06, 2012 9:59 pm
Doc
Doc I very unlikely that you ll have trouble with teflon wires before roasting your winding.
I personally test all my wires in a 180c direct fire and they all survive, being silicon or teflon. I also find teflon coating weak, but the silicon is just as bad under pressure it just looks thick.
A decent 25mph bike will cost around $1000.
A decent 35mph bike will cost around $2000.
A $1000 35mph bike will get you killed.
Justin we really appreciate what you did!
gensem
Postby Doctorbass » Fri Apr 06, 2012 10:11 pm
Doc
I guess we probably had differents experience with these two kind of wires, but what i'm sure is that it's a good move. The silicone can be twisted have torsion, etc so when it exit from the axel, it's way less sensitive from puncture or skin damage!
I already had too many problem with the teflon wire. the tefon endout to crack easy after it had high temp. It become less flexible.
180 celsius is nothing fompare to the 260 celsius my 5303 had last summer!.. the guy that used my ebike came back from his ride and the motor was smoking alot!.. when i saw the stator temp on the bbq thermometer i saw 260 celsius and it was decreasing.. assuming that before i saw it, it could have been higher temp! :shock: ...
but guess what... it still work fine today!.. same inductance, same DC resistance, same fun!
the silicon wire are ok.. :wink:
the teflon wire melt curiously at 260celsius... and the silicon are rated 200 celsius.. but from my own experience the turnigy silicon wire solved all my problem since i use them.
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
PreviousNext
Return to Motor Technology
Who is online
Users browsing this forum: No registered users and 3 guests
