SamTexas wrote:Can you use a Dremel to make one or two deep notches? Then use a big flat screw driver and a hammer to unscrew it? That's how I would do it.
TylerDurden wrote:SamTexas wrote:How do you take it apart?
viewtopic.php?f=30&t=40351&p=589626#p589626
ian.mich wrote:Yeah im gonna order a pin wrench asap. thanks everyone.
chvidgov.bc.ca wrote:One can often remove a freewheel by putting the freewheelin a vice and then turning the wheel itself the correct direction. The leverage does it.
amberwolf wrote:I wonder if they put it on backwards? If they did, then the notches used for the removal tool are on the motor side....
But the good news is, if it's on backwards, you can just use whatever will grab the sprocket teeth and turn counterclockwise, and it'll take it off, becuase it will freewheel in the other direction.
TylerDurden wrote:chvidgov.bc.ca wrote:One can often remove a freewheel by putting the freewheelin a vice and then turning the wheel itself the correct direction. The leverage does it.
That technique is generally used with the freewheel tool:
Tool facing up in the vise, set wheel onto tool, grab rim and turn normal rolling direction.
Users browsing this forum: No registered users and 3 guests
