Is it possible to just parallel 2 identical brushless motors to one controller ? Assuming the controller is able to handle the current of both motors.
The motors will be linked by a chain , and only one motor would have hall sensors , would this work or would one motor go out of sync slightly ? Hence would this only work if both motor shaft were mechanically connected ?
Also is it possible to change the hall wire phaseing so one motor is going forwards and one backwards with only one controller?
