Quajochem wrote:
You have to use this one with the BMC as it is not a Direct Drive motor. AFAIK the speed only calculates properly with a DD motor. I know I have the CA-DP and wish I would have bought the CA-DPS as I like to use it with my 9c and my BMC setup. The CA-DP works, but the speed shows you as going much faster than you really are....
The gears in a geard motor have a typical ratio of 5:1. So it should show you your speed x 5
Have you tried to feed in 1/5 of the true wheel diameter when programming the CA?
That should do the trick or not?
I cannot try it because I haven't got it yet.
And I am really curious if this might work!
Clever! I will try it and post back! Right now I am using the mini motor?????????which is also geared!!! If this works it would be great, but isn't the freewheeling aspect a factor as well?
