Custom Lipo Series Parallel Harnesses & More!
Re: Custom Lipo Series Parallel Harnesses & More!
Postby BATFINK » Thu Sep 15, 2011 7:19 pm
Obviously I meant lipo and not lipoprotein :-)
Sent using Endless-Sphere Mobile app
BATFINK
Postby BATFINK » Thu Sep 15, 2011 7:22 pm
Obviously I meant lipo and not lipoprotein apples predictive typos are amazing at times :-)
BATFINK
Postby icecube57 » Thu Sep 15, 2011 8:22 pm
icecube57
1 GW
1 GW
Customer Support Problem
Postby icecube57 » Thu Sep 15, 2011 11:59 pm
icecube57
1 GW
1 GW
Postby icecube57 » Fri Sep 16, 2011 11:49 am
icecube57
1 GW
1 GW
Postby ambroseliao » Fri Sep 16, 2011 11:54 am
I thought the JST plugs were keyed to prevent reverse insertion, or am I mistaken?
Ambrose
http://www.ebikes.ca/ for the best in ebike knowledge and equipment.
Tidalforce S-750, TidalForce iO Cruiser, 2x TidalForce M-750. Crystalyte HS3540 sensorless, 72V 45A Crystalyte SL controller, ebikes.ca DrainBrain & Cycle Analyst meters. GoPro HD Hero2 camera. A123 20Ah batteries. 88.2V 10Ah LiPO. My blog: http://ebikerider.blogspot.com
Remember LiFEPo4 HVC is 3.65V and LVC is 2.7V
ambroseliao
Postby wojtek » Fri Sep 16, 2011 2:13 pm
last week i plugged JST plugs backwards and smoked my balance leads completely.
I was just tired and almost done with building a pack. One moment of carelessness is enough...
Yes it is possible to insert them reversed if you are not careful.
WIRES AND CONNECTORS
viewtopic.php?f=31&t=30176
http://endless-sphere.com/forums/viewto ... 31&t=32244
http://endless-sphere.com/forums/viewto ... 31&t=32152
Go-One Evo tested with HS3540, now working on Cromotor
BATMOBILE - Astro 3220 / Nuvinci in progress
Velokraft e-VK3 / Max speed 90km/h downhill - EVKA [for sale]
Steintrike Mungo Sport HS3540-SOLD
Scorpion FS HS3540-SOLD
Kona Dawg BMC v2-SOLD
wojtek
Postby Deutch420 » Fri Sep 16, 2011 5:43 pm
ambroseliao wrote:I thought the JST plugs were keyed to prevent reverse insertion, or am I mistaken?
Ambrose
mine are. They have 2 notches on the top of each JST so you cannot plug them in up-side-down. The male notch must slide into the female knotch or it simply wont plug in. I have gotten very small sparks before from my balance plugs, however. This is usually when i kinda slide the plug sideways wile plugging it in. i assume some pins that shouldnt touch are touching for a split second. Happened about 5 times now on about 50 charges. no damage in any way. spark is very very tiny.
GM Rear, 12 FET Lyen @ 45A, 24s2p Turnigy LiPo, 1999 Mongoose: 49MPH.
5304 rear 18FET lyen @ 80amps, 24s4p Kona Dawg: 52mph | 5403 rear @ 80amps 100v = 58mph
Winter build *5403 rear 24FET Lyen @ 100amps, minimum of 100v 20ah. Phasor 4130 frame
Deutch420
Postby icecube57 » Fri Sep 16, 2011 5:57 pm
icecube57
1 GW
1 GW
Postby mrdavies » Sat Sep 17, 2011 8:42 pm
Just want to to say "Two Thumbs Up"" for Ice cube and his custom harnesses! He puts out a great product and is very passionate about his work and quality of his harnesses. Don't think twice about purchasing products from him. His advice and support is fantastic, as I plan to do more business with him. "Thanks"
Mark D.
1)29er Diamondback, Mac 7t 1000w-14s lipo
2)E+1000w mtn,NiMH
3)Direct drive tandem bike, 17s lipo
4)Tidalforce m-750, Mac 8t 17s, 12 fet
5)Cyclocross road bike, front, 14s (17kg.)
NYC
mrdavies
Postby RallySTX » Sun Sep 18, 2011 7:07 am
Yup, I was gonna say you can plug them in backwards partially. Probably just enough to destroy something, or stain your underpants permanently! Can't wait to order my 4s5p harness for 50 amps. My eyes are bigger than my wallet! :cry:
Brian L.
Brian Larson CST. KC9DAK.
Janesville WI.
2005 Schwinn Stingray Spoiler
2004 Schwinn Stingray OCC. The Stripper.
Build thread
viewtopic.php?f=2&t=22134&p=322312
Web. http://www.wix.com/brian_larson/rallystx128hhj
RallySTX
Postby icecube57 » Sun Sep 18, 2011 9:29 am
icecube57
1 GW
1 GW
Postby icecube57 » Sun Sep 18, 2011 4:10 pm
icecube57
1 GW
1 GW
Postby icecube57 » Sun Sep 18, 2011 4:18 pm
icecube57
1 GW
1 GW
Postby icecube57 » Wed Sep 21, 2011 10:09 pm
icecube57
1 GW
1 GW
Postby icecube57 » Thu Sep 22, 2011 9:20 am
icecube57
1 GW
1 GW
Postby icecube57 » Thu Sep 22, 2011 10:15 am
*Reserved.
icecube57
1 GW
1 GW
Postby icecube57 » Thu Sep 22, 2011 12:46 pm
*Reserved.
icecube57
1 GW
1 GW
Postby icecube57 » Fri Sep 23, 2011 5:04 pm
*Reserved.
icecube57
1 GW
1 GW
Postby icecube57 » Fri Sep 23, 2011 11:22 pm
icecube57
1 GW
1 GW
Postby icecube57 » Sat Sep 24, 2011 8:40 am
icecube57
1 GW
1 GW
Postby ohzee » Sat Sep 24, 2011 10:27 am
All I can say is I am very happy with the service and use my well made Harnesses every day.
I'm sure I could do it myself , but until I made 10 or more they are would all look like solder city and probably
melt when I up the amps.
Look forward to my next order.
ohzee
Postby dogman » Sat Sep 24, 2011 11:56 am
I've been getting good crimps on the crimp sleeves just using a cheap crimper. The first crimp makes the sleeve into a deep V shape, then the second one folds further closing the V shape super tight. I've been just doing two into one crimps though.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Postby Xanda2260 » Sat Sep 24, 2011 2:50 pm
While I am sure i could produce a harness that would do the job, I'd much rather have the job done by someone who knows what they're doing, and can solder worth a damn. Looking at dogmans review and your vids, your product is easily worth the money. As soon as I need it for my trike, you'll have my business.
Keep up the good work mate,
Alex
The White Warrior - viewtopic.php?f=6&t=33918
Homebuilt 40mph+ tadpole!
Xanda2260
Postby ohzee » Tue Sep 27, 2011 9:15 pm
So as I have ebike issues every payday I make sure to order additional lipo to increase my ah as I just can not seem to get enough.
I ordered a larger harness from icecube and WOW he is sure making these things pretty.
I am now going to send back my original so I can have it upgraded into something substantially larger.
Thanks for including the extra anderson connectors along with all the spare parts - they do come in handy.
Keep up the good work I don't think I will be happy until I have a few harnesses for different types of applications.
Attached is my v1 which is 48v 10ah along with v2 is 48v 15a.
Thanks Again m8
V1 vs V2 haness
ohzee
PreviousNext
Return to Items for Sale - New
Who is online
Users browsing this forum: No registered users and 5 guests
