YUBA MUNDO TORQUE PLATES AND OTHER CONVERSION PARTS
Postby Kiwi » Tue Sep 13, 2011 6:01 am
Hi,
I have been converting Yuba Mundos for some time and have created a bunch of conversion parts.
See thread http://endless-sphere.com/forums/viewtopic.php?f=6&t=26413
Rear Torque plates for Mundo V2-V4. 4mm Stainless steel
US$35 a pair includes freight
AUS$35 a pair includes freight
NZ$35 a pair includes freight
Front torque plates for Mundo V2 from 4mm Stainless
(picture to come)
Front torque plates for Mundo V4 from 4mm Stainless
US$30 a pair includes freight
AUS$30 a pair includes freight
NZ$30 a pair includes freight
(picture to come)
Other things in the pipe line.
36v20ah / 48v15ah battery case for Ping batts.
Nuvinci Drop out adapters for yuba
Mid hub mount motor bracket for V4 yubas
Giant DH Comp dropout adapters (almost done)
Universal torque arm (done)
Tripple clamp fork battery rack (done)
Greyborg Torque arm and diskbrake mount (done)
...ask for something.
Kiwi
Re: YUBA MUNDO TORQUE PLATES AND OTHER CONVERSION PARTS
Postby Philistine » Sat Sep 17, 2011 6:13 am
Just going on the record for anyone considering these, I have these rear stainless torque plates installed on my V4 Yuba Mundo, and they are the real deal. Best torque solution I have ever used, on any of my bikes. You will simply not be able to find anything close to these in quality and functionality.
Philistine
Postby RallySTX » Sun Sep 18, 2011 7:15 am
Hey Kiwi, are you able to make other stuff? I have several pieces I need made.
For starters. Also I need disk brake caliper mounts, that I will design today. Those will be much more like your tourqe plates. They should be easier than half inch steel machine work. I would be willing to pay shipment from OZ. Let me know what you8 think.
Update here's the caliper mount, not to scale, but measurements are good.
Brian L.
Brian Larson CST. KC9DAK.
Janesville WI.
2005 Schwinn Stingray Spoiler
2004 Schwinn Stingray OCC. The Stripper.
Build thread
viewtopic.php?f=2&t=22134&p=322312
Web. http://www.wix.com/brian_larson/rallystx128hhj
RallySTX
Custom Torque Plates - Lazer cut.
Postby Kiwi » Mon Sep 19, 2011 3:34 am
Regarding custom torque plates/arms/brake adaptors,
I can lazer cut from 0.5mm, 1.0mm 1.2mm 1.5mm 1.8mm 2mm,3mm,4mm,5mm,6mm,8mm,10mm mild steel.
I can lazer cut 1.0mm 1.2mm 1.6mm 2mm, 3mm, 4mm, 5mm,6mm stainless steel.
I can lazer cut 1.2mm, 1.6mm 2mm, 3mm, 4mm, 6mm aluminium
If you can provide a .dxf file from a cad program of the cut profile, perfect.
If you can provide a sketch with dimensions, i will create a drawing and send it back to you, you print it out on paper 1:1 scale and test it on your bike. Once happy I will cut.
$50 for me drawing up the part ready for the laser.
I will cut custom parts once a month, this way I can gather everones parts and cut them at once to obtain the best price. Usual custom torque arm $30 - $50. I will give you a cost estimate before cutting.
I will only do 2 dimension, eg what comes off the lazer, side holes or machined steps, counter sinc or counter bore you will have to have done locally. Atleast at this stage. Once you get into custom machining the price rockets up as does the risk of error.
I can have steel parts zinc plated.
If you do not have cad, make a cardboard cut out of the part, take a photo straight on, and label holes sizes and major dimensions. I can scale it and make a drawing.
If you have ooodles of money, I can build custom battery cases, racks, dash boards, frames, cnc aluminium parts, anything, but it will be super expensive as it takes lots of my time and I charge one trillion dollars an hour.
Also, open source rule, I can add you part to a library of files so others can use the file or have me cut a part.
Kiwi
Postby RallySTX » Mon Sep 19, 2011 8:29 am
Thanks Kiwi, I will convert the brake plate to metric, and reduce the thickness to match your specs. I will let you know when I can pay for your time. It may happen in two weeks, or a month later, but I NEED IT, so it is pretty much a given that you will hear from me soon.
Brian L.
Janesville WI.
Build thread
RallySTX
Postby snowranger » Tue Oct 04, 2011 6:51 pm
Kiwi,
I just put in an order for a Mundo V4 frame and am thinking about using the Nuvinci for this. Do you have an axle adapter for that?
Electric: 400 watt BMC Hub Motor w/disc brake/Infineon 48V 30A controller/Dead 48V 20Ah Ping replaced with Headway 48V20ah
Bike : Generic mountain with xtracycle long tail
Accessories: homemade led lighting, 48V horn
Miles: 13,000 miles, 8,000 on the headway and counting.
http://www.ebikecommuter.com
snowranger
Postby Kiwi » Wed Oct 05, 2011 5:31 pm
I will get back to you on that, I dont have a nuvinci, but have a cad model. Will see what I can do.
Kiwi
Postby neptronix » Wed Oct 05, 2011 9:36 pm
kiwi, it is very cool of you to offer these. I don't have a yuba mundo but i wanted to give you a high five for bringing these suckers to market. Torque plates are a pain in the ass to get made and these are a good deal.
Now... for the sake of proper marketing.. could you put up a proper pic of these on a bike? :)
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby Philistine » Wed Oct 05, 2011 9:48 pm
They look like this installed (obviously the nut etc. has not been put on yet in this photo). As you can see, the axle is stopped from turning either way, so it covers you for regen. I recommend using Nordlock washers though, I ended up getting those as the thrust of the motor can push the axle down/away from the drop out, but with nordlock washers on tight it is sweet):
Philistine
Postby Kiwi » Wed Oct 05, 2011 10:09 pm
Funny thing is I had designed the plates with help from Philistine before I had a bike to take photos! Now I have a V4, though I have lent it out allready. I actually have a bunch of adapters and a unversal torque arm for X5's and NC motors that I just need to make time to take photos! My camera is at camera hospital. When it comes back, lots of juicy photos of conversion parts.
Kiwi
Postby ryan » Mon Nov 28, 2011 2:11 am
Hi Kiwi. Is your updated Yuba Mundo v4 torque arm ready for action, or is the current version solid enough for the torque power of the X5404? I just updated my v2 to a v4 and I'm putting my shopping list together.
UPDATE - Ahh, I see those are only for the Nuvinci hubs. I'll PM you for the standard torque arms.
Marin DH Electric Mountain Climber. Crystalyte 5304. 72v20Ah (Dual 36v20Ah 12S2P LiFePO4 Headways). 18 FET Low RDS MOSFET Overclocker Ready LYEN Controller. (See Build Thread)
ryan
Postby Kiwi » Sun Jun 10, 2012 6:31 pm
Hi,
Here are pictures of the adjustable and fixed nuvinci adapters for the yuba.
The set will come with inserts for the developer kit and the standard nuvinci hubs.
Adjustable Nuvinci adapter
Fullscreen capture 7122011 81552 p.m..jpg (61.62 KiB) Viewed 939 times
Fullscreen capture 7122011 81749 p.m..jpg (74.51 KiB) Viewed 939 times
Fixed Nuvinci adapter
Fullscreen capture 7122011 81823 p.m..jpg (48.85 KiB) Viewed 939 times
Fullscreen capture 7122011 81916 p.m..jpg (51.73 KiB) Viewed 939 times
Kiwi
Postby Kiwi » Sun Jun 10, 2012 6:33 pm
Also, I have new heavy duty 2kw-5kw adapters for hub motors.
Kiwi
Postby ohzee » Sun Jun 10, 2012 6:42 pm
Kiwi wrote:Also, I have new heavy duty 2kw-5kw adapters for hub motors.
Look forward to getting a hold of mine thanks.
ohzee
Postby RallySTX » Sun Jun 10, 2012 7:04 pm
Wow, nice work Kiwi.
Brian L.
Janesville WI.
Build thread
RallySTX
Postby ohzee » Sat Jun 23, 2012 9:43 am
Anyone else recently order yuba hub motor adapters from kiwi ?
Yesterday mine showed up. They look great nice and thick , but the axle hole is to small. I can barely fit the tip
into the whole (Phillistine really ?) but with threads there is no way.
I sent kiwi the exact mm measurements.
Tried my 3525, 5404 and a 10t mac axle all the same ;(
ohzee
Postby chroot » Sat Jun 23, 2012 11:18 am
Hi- I received kiwi torque plate for my Mundo v4 and it fitted either 9c and MPIII nicely.
ohzee wrote:Anyone else recently order yuba hub motor adapters from kiwi ?
Thank you Justin Lemire-Elmore - You are a HERO!
Tidalforce, Yuba Mundo V4 Cargo bike, Juiced Riders ODK V1 Cargo bike
English is my secondary language - ASL (American Sign Language) is my primary.
chroot
Postby teklektik » Sat Jun 23, 2012 11:43 am
ohzee wrote:...They look great nice and thick , but the axle hole is to small. I can barely fit the tip
Sounds like a PM is in order.
I'm wondering if you got sent 12mm plates by accident....
teklektik
Postby ohzee » Sat Jun 23, 2012 11:47 am
Thanks just wanted to make sure it was not an error on my side.
I did pm kiwi just waiting for a response.
ohzee
Postby Kiwi » Sun Jun 24, 2012 10:07 pm
Hi.
I grabbed another set from the same run, I got 10.00mm exactly and 14.26mm.
There is a bit of slag from the lazer on the inside of the hole on one face, you will need to file that out (if I didnt do that, sorry?)
Otherwise, ..thats odd.
Grab a small square file and run it over the flats, should fix it.
As long as you have only 14mm axles you should be ok. If its 16mm like the greyborg, we need to design yet another.
If you cant file a solution, then I will send you another.
Kiwi
Postby ohzee » Sun Jun 24, 2012 10:33 pm
9.83 and 9.84.
Other measure is right around 14mm. Problem seems to be getting over the threads.
I have a 3525, 5404 and a 2 mac 10t's.
Nothing to file other then the flat surface. Did you measure just one random set or
the entire batch ? Will post pics tomorrow in the axle and from there will mail the set
back to you. They are sexy.
ohzee
Postby Kiwi » Mon Jun 25, 2012 12:25 am
Sometimes the threads on the motor axle are cut after the flats, so the edge of the threads flares out beyond the 10mm pays to run a flat file on the axle flats too.
Kiwi
Postby ohzee » Mon Jun 25, 2012 9:42 pm
Verdict is out I am crazy :)
ohzee
Postby Gordo » Mon Jun 25, 2012 10:39 pm
You are only 0.17 of a millimeter tight. A couple of strokes with a file and it will fit.
Please measure your axle with your digital caliper and show the results?
X-treme 3KW Scooter...OFF ROAD ONLY....Giant 1KW 48V 24" Hubmotor....E-Apex 1KW 48V 26" Hubmotor, built 2012-05-26
Thanks Justin, for saving ES. May Grin Tech grow and prosper.
Gordo
Postby ohzee » Tue Jun 26, 2012 7:54 am
So this morning I used the only small file I had and tried to shave some down. The metal is just to hard I gave it
5 minutes couple on each side with no luck. I have 3 axles I can measure Ill do that when I get home today.
I agree on the one that's .7x I may be able to file some down , but the other one is even smaller.
ohzee
Next
Return to Items for Sale - New
Who is online
Users browsing this forum: The Mighty Volt and 7 guests
