Jozzer wrote:Your already the guy to go to for the guys that other guys go to..
sangesf wrote:Can they be toned down to 20a and have regen enabled?
grindz145 wrote:sangesf wrote:Can they be toned down to 20a and have regen enabled?
I imagine regen is going to be tricky running sensorless...
pchen92 wrote:How much for shipping to France ?
thanks
methods wrote:sangesf wrote:Can they be toned down to 20a and have regen enabled?
You can use your CA to set the current limit anywhere you like. As far as regen - I cant say for 100% certain but I *think* I tried it some time back and did not get any. That does not mean it cant be done - just means that in my half-ass test it did not happenSo dont count on regen.
-methods
sangesf wrote:IF I had a CA... I dont.
Are they PURE sensorless or do they have the halls?
Ive used a few sensorless controllers and the ones I bought did have regen..
Are these programable at all?
NeilP wrote:I just had to fix an Xlyte 72 volt 40 amp sensorless controller from Electric rider, a 12 FET unit with FB4310 Mosfets
the data sheet shows them good for 100volts, and the caps are 100volt also
i have run it at 98volt quite happily for a few miles, so assuming this is the same controller then it will be good for up to 24s LiPo
motorino magnet wrote:Hi
Would your controller work with my bike
http://www.motorino.ca/motorinoxpn.php
to bump up to 72 volt lipo ?So I can dump my sla bricks.
Thanks
motorino magnet wrote:PS-are the hvc boards that you have designed going to be used to check the voltage from a charger so i wont have to buy a bms and use my CA as a lvc?
If yes to both questions,i think my dealer will buy some too.
Cheers
Return to Items for Sale - New
Users browsing this forum: badhorsie and 5 guests
