We have BRAND NEW Lyen 12x 4110 Controllers for sale to those that are interested. We have:
2pcs. 48V-72V version for use with BMC motors- Direct Plug and Play!
12 FET 4110 Mark II sensored controllers
Cycle Analyst connector, external USB-TTL connector for USB-TTL programming adapter, regenerative braking enable/disable jumper
12" extended phase & motor set
black wire sleeve
Anderson 45A connector set for motor phase (all black color)
Anderson 45A connector set for battery lead(red & black color)
5 pin JST black connector for hall sensors
1 Pc. Direct Plug and Play Crystalyte HS/HT, 5 series 36-55V
12 FET 4110 Mark II sensorless controllers 36-55V
8" extended phase & motor set
black wire sleeve
1 Pc. Direct Plug and Play Crystalyte HS/HT, 5 series 72-88V
black wire sleeve
We only have 2 pcs. BMC controller and 1 pc. of each Crystlayte controller available, so first come, first serve! We are selling since we are going to go with black controllers instead of silver. These controllers are top quality! Thanks.
PRICE IS $130/EACH! Message us if interested. Thanks!
