Hello all,
i just continum with my build now. i was too busy.
as i told you, i start with painting,
- 1.jpg (193.03 KiB) Viewed 272 times
this is after painting, need to dry. also i connected aluminum legs ped (BMX style).
- 2.jpg (183.29 KiB) Viewed 272 times
This the front end back light, LED 10W for front, 1W LED for rear.
- 3.jpg (116.41 KiB) Viewed 272 times
Frame after dry.
- 4.jpg (109.7 KiB) Viewed 272 times
I make mix between Black color with Metalic Silver, to create Dark metalic Gray.
- 5.jpg (115.96 KiB) Viewed 272 times
Second picture of frame
- 6.jpg (136.87 KiB) Viewed 272 times
Battery:
My cells are 16pcs of 15Ah Headway 40152. total 53V.
All the BMS are waste of money, not reliable, and do not do the work properly And with them you can get stuck in the middle of the road without a logical reason, and I do not want it to happen.
so, in order to save the life time of this cells, i need to add some components.
1)to balance cells, i was order 16 units of balance boards. it balance with 1400mA, (in BMS board it about 85mA to 150mA). the balance is only when i charge !.
2)to protect over discharge or short cells output, i add Fuse of 50A.
3) to protect low voltage, my controller cut the power off when the voltage is 41.5V, and for me, to know when my batteries are low, i add some device, from the RC toy world,
this device, for 8 cells, so i connected 2pcs, it can programmable, when voltage below then 2.7V, of some of cells. it start to make alarm.
- Untitled.jpg (119.28 KiB) Viewed 272 times
- 7.jpg (142.78 KiB) Viewed 272 times
- 8.jpg (141.17 KiB) Viewed 272 times
start to assemble all:
- 9.jpg (135.36 KiB) Viewed 272 times
- 10.jpg (111.32 KiB) Viewed 272 times
- 11.jpg (127.43 KiB) Viewed 272 times
- 12.jpg (129.5 KiB) Viewed 272 times
- 13.jpg (144.69 KiB) Viewed 272 times
soon, test ride results.
