Hi GuyH,
I am glad that you are building a similar project. From my previous experience at 8S the Mamba Xl2 works well. With 8S I was getting 20-22 miles/h but I wanted to stay in 30 miles/h range. That is why increasing voltage was the only way. 9S worked for a month with speed @27-30 miles/h. After 1 month the ESC just stopped working.
I talked to Matt (Recumpence) and he has been using the Castle Creations 160 Edge for @ 5 years with no issues. You only have to set the esc properly. The only problem is the $225 price tag.
Many people on the forum recommend me to use bike controllers because of the reliability and much better price. I have tried Lyen's controllers and both 6fet versions did not work with my SK3 6374-192kv motors plus Edward Lyen has the most horrible custom support ever. I tried 60 degrees, 120 and 17,14 deg. but the motor would stop when I passed 30-40% throttle. Tried various angles, wire combinations and still the problem persisted. Thank you so much to Gwhy whom always replied promptly to all my questions and helped me getting to resolve this issue.
I contacted Lyen over the phone, email and he never replied. ...Future buyers be aware!!!
Did you tried the motor with the 9 fet under load or it is still work in progress?
I mounted a fan propeller on the other end of the motor pulling air inside the tube and replaced the motor sprocket with one tooth smaller. Temperature dropped from 120 to 88-90 degrees. The motor was barely worm at high speeds. The fan pules a lot of air and cools the motor better than the heat sink (tried the heat sink at the beginning of the built). I also made some extra halls in the goped tube so the air could escape faster/easier.
