Electric Surf Board
Boats, Jet Skis, Kayaks etc., including hovercrafts
Re: Electric Surf Board
Postby Bazaki » Tue Jul 31, 2012 9:37 am
Very nice video ! I hope you will continue this project. Does anyone know the rpm of a jet prop of a jetski ? A boat prop is about 2500 rpm I thought
http://www.elektrischeMTB.nl/
Ebike parts and more
Bazaki
Postby Ratking » Tue Jul 31, 2012 10:16 am
Bazaki wrote:Very nice video ! I hope you will continue this project. Does anyone know the rpm of a jet prop of a jetski ? A boat prop is about 2500 rpm I thought
I know that most of the stand up jet skis using 701-750 ccm motors have rpm limit around 7500 rpm.
Thats why someone have to link a few of the 80-100 180kv motors togheter and try combined with hv160. That gives 8500 unloaded. That's perfect for a ice replacement.
Ratking
Postby Bazaki » Tue Jul 31, 2012 1:45 pm
So a jet motor is directly to the crankshaft ? Then we don't need to rewind the Turnigy's, that is good
Bazaki
Postby Hillhater » Wed Aug 01, 2012 12:56 am
Bazaki wrote:So a jet motor is directly to the crankshaft ? Then we don't need to rewind the Turnigy's, that is good
If you expect anything like effective performance or efficiency, the waterjet impeller pitch and diameter needs to be carefully matched to the motor power and target hull speed ...just like a prop drive.
Also be aware that impeller and housing condition, and peripheral gap, is absolutely critical to a jetdrive operation. A worn impeller or housing can result in total loss of performance, so be careful when buying a used jet unit
Hillhater
1.21 GW
1.21 GW
Postby Matthias_S » Thu Aug 02, 2012 7:52 am
I bought a kawasaki 550 jetpump. I will test how much trust I get with one turnigy 80-100.
My goal is to reach planing speed. Dont know how much trust I need to reach it? I think more than 200lbs..?
Does anyone know how much trust a kawasaki 550 produce?
Matthias_S
Postby Ratking » Thu Aug 02, 2012 11:25 am
Matthias_S wrote:I bought a kawasaki 550 jetpump. I will test how much trust I get with one turnigy 80-100.
Some guy that supposedly know his stuff said that you will get 1hp out of the pump for every 1kw you put in. I don't know if that is spot on, but may be.
The kawaski 550 have 37hp stock and put out 360lbs of thrust. If we divide the thrust produced by motor hp we get 9.2 lbs of thrust per hp. Maybe you motor can provide peaks of 8hp, so let say max thrust out of the pump will be 73.6 lbs, or 33.4kg of thrust. That's not a lot, but may be enough for a surfboard?
Ratking
Postby Ratking » Thu Aug 02, 2012 11:31 am
I would like to say hat maybe you can use the torque that the electric motor have to your advantage by using a steeper pitch on the impeller. I have not been able to find what kind of torque a original 550 motor produces, so his is highly experimental :wink:
Ratking
Postby Matthias_S » Thu Aug 02, 2012 6:30 pm
Thank you :D Cant wait to get this thing tested! Its really hard to tell how much trust to get out of this combo but your informations are really interessting!
btw this is the pump I bought: http://www.ebay.com/itm/140808392811?_t ... IT&vxp=mtr
Yes I hope that the produced trust is enought to reach planing speed..
Does anyone know what happens on planing speed, because of the much lower friction the motor amps must be also lower, isnt it?
Matthias_S
Postby Hugues » Fri Aug 03, 2012 12:27 am
Hi Matthias,
I'm following your project, very interesting, I might try this too.
Have you thought about using foils to lift the board out of the water ?
It does not take so much power i think. There is a kayak with foil and a well trained person can lift it out of water with paddling only, I think it called the flyak or something like this.
Great idea you have !
Hugues
Switzerland
Mountain bike
XC-204 -> Crystalyte HT3525/Infineon ctrlr 40 A EB712XC board/LiPo 88 V 10ah
All Terrain Vehicle
Hanebrink -> Crystalyte HS/Infineon ctrlr 20 A/Allcell Li-ion 36 V 10ah
Motor bike Cruiser
My build thread here
Hugues
Postby Bazaki » Fri Aug 03, 2012 4:58 pm
Just when I thought I have seen it all....
http://www.boreme.com/posting.php?id=18518
Amazing with how less energy these speeds can be reached at the water, new food for new idea's here :D
Bazaki
Postby Matthias_S » Sat Aug 04, 2012 6:19 pm
There is a lot of potential in hydrofoil but whit my jet pump it is not so easy to realize this.
There is already an electric hydrofoil out there..
http://www.youtube.com/watch?v=jh_RhkejWLw&pxtry=1
Matthias_S
Postby Hugues » Sun Aug 05, 2012 4:12 am
Matthias_S wrote:There is a lot of potential in hydrofoil but whit my jet pump it is not so easy to realize this.
thanks for the link, this is the kind of project i had in mind,
they say it's only 1 HP ??
i tried to find more technical info on their site, but one of them is returning an error,
and the other does not return any results
but thanks a lot for the video.
Hugues
Switzerland
Mountain bike
All Terrain Vehicle
Motor bike Cruiser
Hugues
Postby Matthias_S » Sun Aug 05, 2012 6:05 am
Matthias_S
Postby Bazaki » Sun Aug 05, 2012 12:52 pm
Very nice, it can be done for sure ! Keep on going and I hope you will end up like this or I hope a bit faster :D http://www.youtube.com/watch?v=hwG3qxtI ... el&list=UL
Bazaki
Postby Matthias_S » Sun Aug 05, 2012 1:05 pm
kymera is absolutely amazing :D
I hope so much to get similar results
Matthias_S
Postby parmenps » Thu Nov 15, 2012 4:09 pm
how machts watt is that motor?
parmenps
1 W
1 W
Postby dirkdiggler » Mon Dec 10, 2012 7:25 pm
What is the latest on this project? I watched the videos and it looked like it would work well. I am curious what battery and motor setup you are using. After finding out the price and performance of the gas powered surf board, I want to build one for myself.
Thanks,
Digg
dirkdiggler
Postby pendragon8000 » Sun Dec 16, 2012 5:06 am
well done Matthias_S, good luck with the new pump.
keep us posted :)
pendragon8000
Postby dirkdiggler » Mon Jan 28, 2013 11:41 pm
Here's an old vid someone linked me to on one of my other projects (mini RC surfers). Sorry if it has been posted before.
http://www.youtube.com/watch?feature=pl ... NfwuM99mrk
dirkdiggler
Postby Beachcruzer » Tue Jan 29, 2013 12:26 am
Here's a guy surfing a 45-foot face with an electric-powered board. $4,000 but if you surf waves this big they'll give you one for free.
Beachcruzer
Postby dirkdiggler » Tue Jan 29, 2013 10:55 pm
If I was Garrett, I wouldn't bother. It's probably a bit more fun to ride that 100 footer in Portugal. :lol:
That WaveJet is a nice setup. The 4k throws me off and the speeds are just meant to get you out in the surf though. I want something that will go 20mph or more to ride lakewater not waves. I think the wavejet only goes around 12. You might be able to change out the motors/batteries on them though, which could make it worthwhile.
I do think these big wave surfers would love to not have to be towed into waves. If they had a board that went 20mph they could paddle into more of them.
dirkdiggler
Postby sk8norcal » Wed Jan 30, 2013 12:27 am
dirkdiggler wrote: I want something that will go 20mph or more to ride lakewater not waves.
this one is from Taiwan
http://www.justwin.com.tw/products_detail.php?id=24
Last edited by sk8norcal on Wed Jan 30, 2013 12:29 am, edited 1 time in total. View post history.
sk8norcal
PreviousNext
Return to Electric Watercraft
Who is online
Users browsing this forum: No registered users and 3 guests
