C washers from Ebikes-Ca pictures replaced
Re: C washers from Ebikes-Ca
Postby mwkeefer » Sun Jul 25, 2010 3:22 pm
Dogman,
After placing the C washer into the cup, all that remains is finding some normal steel washers (don't need to be keyed) to build up which will fit within the space (the hex adjustment bolt on the pre-load) and then torque it down :)
-Mike
Regards,
Mike
{My Rides]
2010 Dahon Jack - GNG v1 - LYEN 6FET - 20/40A - 18S2P10AH - Nom:66.6v,1332w
2004 Hard Rock Pro Disc - Recumpence ms eDrive v4 - Astro 3220 4T - 12S2P16AH - HV110 - Left Side Drive - Gearing: 38mph
Nominal Peak Power @ 60 seconds: 5328 watts - Maximum Power: 49.8v, 120A, 5872w
2010 Downtube 8FH - Stock GNG v1 Stock Controller - EB809XC - 12-16S
2012 Downtube Nova 7spd - Stock GNG v2 - 12S2P10AH - EB809 - 12S-16S - 20A/30A,Nom VCC: 44.4, 888w
mwkeefer
Postby amberwolf » Mon Jul 26, 2010 3:16 am
RTLSHIP wrote:Can somebody explain whether a "C" washer will hold this axle in place?
All the C washer is for is to fill the space in some dropouts (especially alloy suspension forks) so that all the washers and torque arms in the stack all sit perfectly flush and perpendicular to the axle. AFAIK the C washers aren't intended to actually secure anything in place.
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby RTLSHIP » Mon Jul 26, 2010 6:38 am
How complicated to swap out hub axles? My hub axle is under 9.5 mm as it has been stripped , mangled etc. I'm using tape to would add bulk to the axle. Once an axle is worn down, it will slip out of the grasp of the torque arm 10 mm slot. The torque arm doesn't move; rather, the axle gets loose. It can happen again.
The bike is still ridable as I have opted to add tape to the axle. Also, I had to take hammer and vise grips to the torque arm
to get back original form.
two Aotema Brushless & Sensorless Kits
two 7 speed bikes 26"
36 & 48 volt packs
RTLSHIP
Re: C washers from Ebikes-Ca pictures replaced
Postby dogman » Wed Jun 27, 2012 4:18 pm
A bit late to reply to that question now, but if anybody else has the same problem, pinch dropouts would be the best solution. Here is my version.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Return to E-Bike Reviews & Testing
Who is online
Users browsing this forum: Bing [Bot] and 3 guests
