Geared hub motors: BMC vs MAC Shanghai
Re: Geared hub motors: BMC vs MAC Shanghai
Postby Spacey » Mon Jan 03, 2011 1:55 pm
I've done that lot's of times..... you need the large washer to go between the wheel and the freewheel.
Spacey
Postby jonescg » Mon Jan 03, 2011 6:39 pm
Ahah! Thanks for that Spacey!!
Voltron the Electric RG250 - Dual Agnis, Kelly 1200A controller, 6 kWh of A123 cells from Cell_Man and a shitty old chassis from 1985 :| Top speed 180 km/h, max current 600 A @ 100 V.
VoltronII 8)
Say no to spaghetti junction LiPo! Assembled Hi-power LiPo packs of any size!
Come on Casey! If you want prototype racing, throw your leg over something with lithium in it :D
jonescg
Postby cell_man » Wed Jan 05, 2011 4:38 am
jonescg wrote:Hey Paul,
The motor we bought for Katherine's e-bike is a direct drive, but when I tried to thread a Shimano 7-speed freewheel onto it did OK until the last bit where it tightened up but now it won't freewheel :( Hope I haven't stuffed it...
CHRIS
Hey Chris,
That's a bit strange, nobody else has reported any issues like that and I've sold a few of them. Best to send me a PM or email if you have an issue as this thread is not related to the direct drive motor. I'll try to take a look at 1 of the motors with a freewheel and see if I can see anything amiss.
cheers
Paul
http://www.emissions-free.com/ has just come online. It's a bit naff at the moment, but it can only get better :)
Drop me a line on emissions-free_worldwide(at)hotmail.com if you want to discuss any products I stock or you would like to source in the future.
cell_man
Postby jonescg » Wed Jan 05, 2011 4:52 am
No worries.
Cheers,
CHRIS
VoltronII 8)
jonescg
Postby USMC7578 » Mon Feb 28, 2011 9:39 am
Good Morning. I have the V2 I lost power to the rear wheel. The motor is running but no power to the wheel. I have it apart to the 3 green gears. I believe they may be worn (although I see no signs of plastic in the hub). Are those gears replacable?
Mike
USMC7578
Postby neptronix » Mon Feb 28, 2011 5:07 pm
usmc; the gears are replaceable.
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby ebikes-sf » Thu Mar 03, 2011 8:53 pm
USMC7578 wrote:Good Morning. I have the V2 I lost power to the rear wheel. The motor is running but no power to the wheel. I have it apart to the 3 green gears. I believe they may be worn (although I see no signs of plastic in the hub). Are those gears replacable?
Mike
Gears are rarely a problem, it sounds like a separated V2 clutch:
http://ebikessf.com/V2-vs-V3-clutch
It can be fixed by welding two pieces together - very carefully though, to avoid overheating. Something I can do for $20. Or new V3 one-piece clutch and gears is $110.
ilia
ebikes-sf
Postby IIIHorseman » Wed May 23, 2012 12:43 pm
There is another benefit of the BMC motor vs the MAC that has not yet been mentioned. The clearance and fitment of the BMC motor is superior. If you look at the motor case of each of the motors, you can clearly see that the BMC version is not as elevated and actually is contracted by the case screws. On my MAC motor, the stock disc caliper rubbed up against the casing; and even when I took off the disc brake, it was still rubbing up against the motor screws. I had to eventually buy another caliper and slightly modify it to get it to work. There also doesn't appear to be enough room to add a 8 speed freewheel (even with a spacer), short of bending the frame. If I knew this before hand, the added expense for the adjustments pretty much off-set the cost to prefer the BMC. The BMC axle and connectors also appear to be of better quality. Fortunately Ilia, from EbikesSF, is one of the few vendors that have both options to choose from.
IIIHorseman
1 W
1 W
Postby Spacey » Tue May 29, 2012 12:03 pm
Gotta say, I've never really had a problem fitting the Mac motors with disc brakes. You've just got to get the right amount of spaces on the right side of the axle. Have done about 4 Mac builds so far.
Spacey
Postby neptronix » Tue May 29, 2012 1:54 pm
Kinda sad that the main difference, functionally, is rear disc brake fitment.
Supposedly they have better water seals? i have not seen pictures of these seals..
Is that worth $200 to you, is the question!
I didn't have problems with the disc brake caliper rubbing against the cover. But i agree that disc brake fitment is a little on the painful side. These are pretty wide motors after all.
neptronix
Postby ohzee » Tue May 29, 2012 1:58 pm
I noticed that the BMC motor has holes on the cover between stator and gears. .Does anything think drilling similar holes
in the MAC would be beneficial for cooling ? Running my mac near the limits I am trying to figure out some way other then
filling it with oil to help keep it cooler or reduce cooling times between runs.
ohzee
Postby neptronix » Tue May 29, 2012 2:22 pm
ohzee wrote:I noticed that the BMC motor has holes on the cover between stator and gears. .Does anything think drilling similar holes
The new magnet assembly in the MACs has these holes.
It might help, but it also opens up the possibility of getting grease on the stator.
You also end up shedding stator heat towards the gears.
I don't know if it's really beneficial at all. The benefit might be more in shedding weight from the motor.
neptronix
Postby ohzee » Tue May 29, 2012 3:19 pm
Good point that the heat will go the wrong way. I just liked how BMC had the holes there.
Leaves me with drilling holes in the covers then. Mine is a mid kit so at least it's a bit safer from road debris.
ohzee
Postby cal3thousand » Tue May 29, 2012 3:24 pm
All this talk makes me itch for the new 7T that's (hopefully) on the way soon from cellman
#1: Diamondback Menona 700c (Commuter)
M/C: e-BikeKit geared rear w/BB7 with 12FET 40A Infineon ebikes.ca
GM 48V LiFePO4 10Ah racked; moving to 12S Turnigy 10Ah framed
+ Speedict, XC30TK disc, Alex Adventurer 700c Disc, Tektro 180mm hyd. with 42mm Kenda Urban
#2: Norco VPS Six DH (Fun) WIP
M/C: Clyte HT3525 (Thanks Meth!!!) http://Methtek.com with Lyen 18FET 24S Regen
Battery: 24S Turnigy 10Ah frame (ABS)
#3: Wifey Bike, Giant eSuede fully customized WIP
cal3thousand
Postby neptronix » Tue May 29, 2012 3:40 pm
Prepare to have to do regular oil changes if you do that :(.. the grease inside will get dirty over time due to dust and other stuff in the air.
cell_man seems to be working on producing a larger MAC motor soon, FYI.
neptronix
Postby RyanTo » Thu Jun 28, 2012 1:03 pm
Any truth to the BMC being better in the rain. Is the Mac that bad? I live in the PNW but I have covered parking at work and at home. Still, sometimes it will be raining on the way. I was thinking about buying a MAC..
RyanTo
Postby teklektik » Mon Jul 02, 2012 7:04 am
Talk to Ilia at Ebikes SF - he now sells both.
teklektik
Postby MalcyW » Tue Dec 04, 2012 11:16 pm
Has anybody been able to compare the noise levels between a BMC and a MAC?? Are they much noisier than direct Drive hubs?
MalcyW
Postby DAND214 » Wed Dec 05, 2012 12:13 am
My MAC"S are as quiet as most of my DD's since they have a growl under load.
They also seem to quiet down after a feww hundred miles or less.
Both are 8t in 26" wheels running 15s LiPo's great power for such a light motor.
Dan
It sure would be nice to know where we are all located, ON THIS WORLD.
Fill in your profile. It doesn't hurt.
I know some worry about being found.
I wish someone would find me.
DAND214
Postby veloman » Thu Dec 27, 2012 4:34 am
My Mac hubs are quieter than my 9c hubs. There is a slight 'whine' with the Macs, but it's less noticable than the DD noise - which is still very quiet. They are worlds quieter than that gear reduction Currie motor I used years ago :D
Mush! Mush you electrons! Push harder!
Main ride: Old School Specialized Stumpjumper FSR, Clyte HT3540, 63v lifepo4, 12fet Infineon set to 26amps. And a bunch of others... viewtopic.php?f=6&t=34236&p=497325#p497325.
veloman
Next
Return to E-Bike Reviews & Testing
Who is online
Users browsing this forum: No registered users and 5 guests
