Ypedal wrote:Holy crap... SF is an insane place for cyclists..
TylerDurden wrote:Ypedal wrote:Holy crap... SF is an insane place for cyclists..
You should see the messengers.
And what 6600 watt controller comes with the X5 ?Lowell wrote:Randy is just bitter that hardly anyone really appreciates or cares about his ebike drivetrain, while hub motors sell by the container load. I for one would have more respect for Randy if he presented his ideas in well written posts, without trying to put down others.
Randy: No matter how skinny the rider, and how efficient the motor, your 1600W has no chance against an X5 hub motor with 6600W. That's great for you that it climbs mountains at 12mph, but don't expect flatlanders to think that's useful.
Lowell wrote:Randy: No matter how skinny the rider, and how efficient the motor, your 1600W has no chance against an X5 hub motor with 6600W. That's great for you that it climbs mountains at 12mph, but don't expect flatlanders to think that's useful.
EbikeMaui wrote:And what 6600 watt controller comes with the X5 ?Lowell wrote:Randy is just bitter that hardly anyone really appreciates or cares about his ebike drivetrain, while hub motors sell by the container load. I for one would have more respect for Randy if he presented his ideas in well written posts, without trying to put down others.
eP wrote:Lowell wrote:Randy: No matter how skinny the rider, and how efficient the motor, your 1600W has no chance against an X5 hub motor with 6600W. That's great for you that it climbs mountains at 12mph, but don't expect flatlanders to think that's useful.
You are wrong Lowell.
It is not useful for you, but for most of bikers it is useful. The less power you need the more useful it is as you dont need spend a lot of money for powerful battery pack.
Before Currie came out with the USPD I already had reliable quality components made cost effectivly.You will not find ANY in production on Ebikes. Yet and mabe never! using what is already on some ebikes would be much harder because they are NOT designd to take much more without major modifications.knoxie wrote:Hi
Again Randy I have to agree with much of that, you pays your money you get what you pay for, the Chinese stuff is not a patch on the Sevcon and the Chinese stuff is only deigned for low power really, some of us are taking them to their limits to see what can be done with them and I dont doubt that a lot of people will be crossing their fingers as the controllers and the batteries and everything are so much more vulnerable on kit that isnt really designed well enough to cope.
The lipos are cheap but need improvement if you want to get good cycle life and better reliability and as you also suggested we are in contact with the battery and controller suppliers to get a lot of the shortcomings fixed in the motors and controllers and the batteries, we cant do this until we play with the stuff and make it smoke to see what needs fixing, its hard to change the Chinese way of doing things and quality control is always an issue.
I like trying all different kinds of systems and taking them to the limit then backing them down a little and using them, has been working well for me so far and I have fixed a lot of the short comings on the controller and have it running well and reliable, I think I can sort out a lot of the BMS problems between Mark and the lipo supplier.
If we lean on the Chinese enough they will pick up the quality and realise they cant cut corners as it wont wash with folks in the west esp when they stand next to the sort of quality that is made in the west, thats not to say all the Chinese stuff is substandard far from it and infact its the e-bike industry that is probably at the lower end quality wise.
We will all keep frying this stuff until we find what works![]()
Later
Knoxie
Nope, but two beefy 40 mm X 17 mm bearings on the other side preloaded with the sprocket or a nut or both.I personaly would use that fan for the rotorTylerDurden wrote:Wow... that's clean.
No bearing on the fan-end?
sO WHAT off the shelf controller comes with the X-5 and what are the specs? Most people don't want to void there warenty Or know how to solder circuit boards.Lowell wrote:EbikeMaui wrote:And what 6600 watt controller comes with the X5 ?Lowell wrote:Randy is just bitter that hardly anyone really appreciates or cares about his ebike drivetrain, while hub motors sell by the container load. I for one would have more respect for Randy if he presented his ideas in well written posts, without trying to put down others.
An off the shelf Crystalyte, modified with IRFB4110 MOSFETs. Total cost less than $200 plus a soldering iron if you don't already own one.
Return to E-Bike Reviews & Testing
Users browsing this forum: Google [Bot] and 1 guest
