Solar power house info
Solar, wind, hydro and other non-fossil sources of electricity.
Postby Arlo1 » Tue Sep 27, 2011 9:34 am
So I want to make this thread to cover whats important to know about powering your house with solar power. I will reserve the first few posts to update so people in the future can just read the good info from them. This is to help people know what to look for for solar chips price wise and quality. Its to help people understand how easy or hard a whole system is, and what the gains and down falls will be!
Thanks Justin of http://www.ebikes.ca/
Also a thanks to Methy at http://www.methtek.com/ :)
And Dave who has some good deals on STUF
RC lipo and most other types of Lithium batteries you MUST know your individual cell voltages while charging and discharging.
Batteries of all kinds need respect they can burn your house down, so don't sleep with them under your bed or any other were you cant afford smoke or fire!
[color=#FF0000][b][size=150]Never above 4.2v never below 2.7v EVER!!!
Arlo1
Re: Solar power house info
Postby Arlo1 » Tue Sep 27, 2011 9:35 am
This space is rewserved for the solar pannel info chips mirrors hot water heater ect.
Arlo1
Postby Arlo1 » Tue Sep 27, 2011 9:36 am
This space is for info on inverters and battery banks and will incl grid tied inverter info as well.
Arlo1
Postby Arlo1 » Tue Sep 27, 2011 9:37 am
This space will be for the info on power companys buying your exscess power from you vs just being off grid and hording your power :mrgreen:
Arlo1
Postby stingray17 » Wed Sep 28, 2011 3:54 pm
Here's some basic info to get started, the questions people often ask me. I work in solar power in the USA.
TERMS AND DEFINITIONS:
You need to understand the basic terms for energy and power to even understand the specifications of a solar electricity system. If you're an E-S forum regular you already do! But for anyone who's just joining us, I will try to make this as simple as possible, and you try not to let your eyes glaze over cuz the good stuff is coming:
Volts (V) = Electrical potential. I think of it like a "virtual" vertical distance from the top of a hill to the bottom of the hill. Um, don't worry if you don't understand voltage all that well, though, just try and understand how it fits in.
Amperes/Amps (A) = Electrical current. The rate of electrical flow, as through a wire.
Watts (W) = "Power". Basically, power is Volts times Amps (W = V x A). You have to have current flowing and an electrical potential, then you have "Power". Let's say you want a motor to go faster - you might be able to do this by increasing the Volts or the Amps, thus increasing the amount of power the motor was using.
AC, DC, Resistive, Inductive, and Capacitive Loads and Power Factor (PF) = Just kidding, I'm not going to try to summarize this stuff in a sentence, I don't want to start any flamewars with physicists :lol:
Watt-hours or Kilowatt-hours (Wh/kWh) = "Energy". Power times Time. This is the quantity you use and pay the electric company for. If you have a motor consuming 1000 Watts (1 kW/kilowatt) of "Power" AND you leave it on for one hour, then the TOTAL AMOUNT of "Energy" you have consumed is 1000 Watt-hours (Wh) which is 1 kilowatt-hour (kWh).
$ = "Money" which is one really good reason to get some of your electricity from the sun and pay the power company less. :D Here in the USA energy cost is represented as $/kWh. Lots of folks are paying somewhere around $0.15/kWh, but this varies a lot across the nation. People who use more than average amount of energy may be paying higher tiered pricing of $0.45/kWh or more.
THE SUN:
The sun provides energy in the form of light and heat. In the middle of a perfectly clear summer day, the sun casts about 1000 Watts of "power" per square meter of surface on which that light is falling. The amount of power varies a lot with cloud cover and the angle the sun is cutting through the atmosphere. In the middle of the summer you might expect the equivalent of 4-6 hours of "full sunlight."
Also, the sun is at very different places in the sky at different times of the day and year, so it is hitting your roof (and your solar panels) at a different angle. When the sun is shining sort of "sideways" to a panel, the panel is receiving less sunlight than when the sun is directly above it.
The idea of any kind of solar power is to convert some sunlight into usable energy. People in very cold climates with a black roof are using some of that power to help heat the house. Other ways to use that solar energy are to heat water, or convert the light into electricity and power your appliances etc.
HOME SOLAR ELECTRICITY:
Most home solar electricity systems today are "grid-tied photovoltaic systems". "Photovoltaic" means electricity from light. "Grid-tied" means you still get your electricity from the power grid, but when the sun is out, you also get electricity from solar panels. And if you generate more than you use, your system will "backfeed" and you will get credits from the utility company.
Even though many home users pay a flat rate for their energy, it's actually generally more expensive during the day when air-conditioners and factories and stores are all running. For home users who don't need much energy during the day, this is great. You can typically set up your utility company to bill you on a "time-of-use" schedule... Now your nighttime energy will be cheaper, and your daytime energy more expensive. Except because you have solar electricity, now during the day your solar system is actually generating credits at the higher daytime value. 8)
There are two basic conceptual parts to a grid-tied solar system: The photovoltaic modules and the inverter. The modules generate DC power at one voltage, and the inverter outputs AC power at a different voltage, plus it synchronizes its AC output with the power grid so that it can smoothly feed that power back out onto the grid. (more on these below)
If you are on the power grid, unless you have major reliability problems with your electric power, for most folks it makes the most sense to get a grid-tied solar electric system. This is because they are cheaper than off-grid systems, and you don't need to install/maintain/replace your batteries, and you can still get very close to zero payment to the utility if you get your system & usage just right. But for remote locations/etc, you can also go "off the grid". More on that below.
SOLAR WATER HEATING:
Aside from generating electricity, solar power can also be used to heat water directly, and this is actually a really efficient thing to do also. The idea is that instead of feeding cold water into your water heater, you feed in pre-warmed water. Now your water heater does a lot less work to provide hot water, and reduces energy costs.
In many climates, solar water heating is a really good way to save money. And compared to solar electricity systems, it has the advantage for some people of being much more DIY-friendly! Very few people would be able to build a grid-tied solar inverter and solar modules in their workshop (and you'd have a hard time getting it to pass city inspection if you did). But there are many people who have put together workable solar water pre-heating systems from recycled/re-purposed stuff, with cash outlay very close to $0.
Most of the stuff I'm talking about here is about solar electricity systems, but some of it applies to solar water heating too. Although I don't deal with solar water heating myself, I do think it's something good to consider as another way to save energy and money.
THE MOUNTING PLANE:
The angle matters. In the northern hemisphere, solar panels should ideally be facing south. The tilt should be at least 5 degrees or so, not flat - this helps rain water run off the panels and they will stay cleaner. In areas where there is snow, the tilt should ideally be steep so that snow will come off more quickly. The azimuth (compass direction) and tilt of your panels determine how much sunlight they will receive on average, assuming there is no shade.
You can use computer modeling tools to estimate how much electricity a photovoltaic system will generate at various times of year, given the location and the tilt and azimuth of the modules. These tools use the angle of the sun plus historical weather averages to figure out how much energy you'll get. One simple free tool is called PVWatts (version 1).
If installing on a roof, it's best to install on a new roof or one that won't need to be replaced for a few years. Structurally, it's important that the roof be able to support not only the extra weight of the solar, as well as lifting from wind blowing under the panels. Lots of rack options are available but be warned, getting up there and punching holes in your roof is not for the faint of heart...
SHADE:
Shade is really bad for solar systems. In the case of solar electric systems it's even worse. Sometimes just a little bit of shade on one corner of a module can cause a whole module or a whole string of modules to reduce output by 90%. So the best thing is to mount modules where they will not get any shade, or at least they will only get shade in the early morning and late afternoon, and/or in the winter when the sun is lower. It's important to KNOW how much shade a given spot is going to get all year round. Any solar installation company can come out and do an audit of your roof and tell you the good spots for solar, or if you want to audit yourself this is also possible.
PHOTOVOLTAIC MODULES:
Solar panels that produce electricity are called Photovoltaic or PV modules. Typically a module consists of a series/parallel array of individual solar cells, covered in glass. The cells may be made from slices of silicon crystals or from films created in different ways.
PV modules are a source of voltage and current, but they don't quite act like batteries. They have a characteristic current-voltage relationship when light is shining on them. If you leave them open circuit, they will sit at "open circuit voltage" but obviously no current will pass. Conversely, if you short circuit a panel to itself you will get obviously no voltage, but "short circuit current" will pass through them. There is a sweet spot called the "Max Power Point" where the load on the panel creates the most Power (where Voltage and Current are both pretty high). The Max Power Point changes as the amount of light hitting the panel changes, and as the temperature changes.
Temperature is important for PV modules. As the cells in the module get hotter, the voltage goes down, and the power along with it. Different modules have different levels of temperature response, and this can be rated in Volts per degree Celsius. But for all modules it's good to have some passive cooling. Wind and airflow underneath the modules helps; modules that are mounted very close down to the roof will get hotter.
Modules are rated in STC or PTC Watts. This is the theoretical maximum you'd see them generate in perfect conditions. Just because you have 1000 Watts of solar panels doesn't mean you'll be generating 1000 Watts of electricity all the time. That amount is reduced by your angle to the sun, dirt on the panels, hot panels, wiring losses, inverter inefficiency, etc.
GRID-TIED INVERTERS:
You can think of the grid-tied inverter as really three things, logically:
(1) a Max Power Point Tracker (MPPT) that varies the load on the PV array to achieve maximum power point
(2) a voltage converter to stabilize/convert the varying input voltage
(3) an inverter that converts the DC into AC and also synchronizes the AC waveform with the grid
Most of the time for home setups you will have one inverter connected to an array of modules. There are also "microinverters" where you install one inverter per panel or per two panels, and "remote" systems where you have a bunch of little MPPTs and voltage converters connected to separate panels or strings, but still only one central inverter.
Grid tied inverters are generally rated in AC Watts (output). This means that it isn't unusual to have 5,500 or 6,000 Watts of modules connected to a 5,000 Watt inverter. They also have efficiency ratings and some are a couple percent more efficient than others.
Grid-tied inverters do not work during power outages. You would need to also have a separate battery system if you want to maintain power during grid outages.
OFF-GRID: CHARGERS AND BATTERIES AND INVERTERS
You can't really run appliances directly off of a solar panel. Okay, you sort of can, like cooling fans and stuff. But normally when we're thinking off-grid solar, what that means is that you are running everything off of batteries, and using solar to charge your batteries.
Instead of a grid-tied solar inverter, you need a solar battery charger. Any decent solar battery charger consists of:
(3) a charge controller (to take good care of your batteries)
Unlike with wind and other systems, you don't need to worry about what to do with excess energy once your batteries are full. The charger can just get as much or as little energy from the modules as it needs.
Once you have batteries and a charger, you can either run DC lights and appliances directly off the batteries, or you can use a regular inverter to convert to AC and use normal appliances. You have lots of choices in inverters, but "pure sine wave" inverters will work better especially with motorized appliances.
SUN TRACKING:
By moving the modules throughout the day, you can keep them pointed more directly at the sun, and you can get more energy particularly in the morning and later in the day. Tracking can be one-axis (South-tilted modules rotating from East to West with the sun), or two-axis (Modules rotating up/down/left/right to face the sun directly at all times.)
Tracking arrays can provide 20-30% more energy every day given the same amount of modules, but also they are expensive and require annual maintenance. Care must be taken when designing a tracker array that adjacent rows of modules do not create shade on each other as they move. For most applications, it makes sense to just install more modules in an optimal but fixed location, rather than using a tracker.
MONITORING:
It's important to monitor how much energy is being produced by your solar electricity system, so you can be sure it's working right. Many solar inverter companies offer monitoring options for their inverters. These can take the form of monitoring boxes that upload your data to a website where you can view it from any computer, or local-only monitoring options that give you a remote display of energy production from the inverter. If you invest in a monitoring device of some sort, make sure it shows historical data day-by-day and month-by-month -- not just current totals.
Almost all grid-tied inverters (and some solar battery chargers) have an RS-232 or RS-485 serial port data interface option. If you're feeling ambitious, you might be able to create your own monitoring system using a microcontroller or a computer which is connected directly to the inverter.
You can also monitor your photovoltaic system by hand. At least once a month, look at the inverter and write down the "Lifetime Kilowatt Hours" reading from the display. Keep a historical log of readings from your inverter, so you will know how much it produces each month. Then, you can compare the daily/monthly kWh energy output to a computer model, and also to last year's performance at the same time of year. It's not really that useful to sit and watch the Watts ("power") output on the inverter, because it can change rapidly throughout the day as clouds pass, etc. To see whether a system is working as expected, it's actually better to look at the total daily and monthly kilowatt-hours ("energy").
FAQ:
Well those are a lot of my FAQs... What are yours? :mrgreen:
"Ardence Mark III" - Dahon Speed D7 / BMC V2S (ebikessf) / Lyen 6 FET Mini-Monster / Ping LiFePO4 16s3p 15Ah
"Ant" - Downtube 9FS / Crystalyte HS3540 (ebikessf) / Lyen 12 FET Extreme Modder / Zippy 30C Lipo 14s2p 16Ah
stingray17
1 W
1 W
Postby Arlo1 » Thu Sep 29, 2011 8:55 am
Thanks for that. Thats a very good post on the first page.
Arlo1
Postby stingray17 » Thu Sep 29, 2011 1:58 pm
PHOTOVOLTAIC (PV) MODULE "EFFICIENCY"
I think there are really two different kinds of PV module efficiency. Both are important.
(1) Watts Per Square Meter
If the sun is dropping 1000 Watts of raw sunlight power on a 1 square meter solar module, and that module is putting out 200 Watts of electricity at its Maximum Power Point, that would be a 20% efficient module. That's about typical. Some new technology modules have efficiency of 25% or more.
If you have very limited shade-free space for mounting PV modules, it might be important to look at high-efficiency modules so you can get more Watts into a smaller space.
It is not really possible to create a 100% efficient solar module, but imagine what it would look like... If it was 1 square meter in size, it would be rated at 1000 Watts. It would be blacker than the blackest night, with no glare or reflection, because every bit of light that hit it would be turned directly into electricity!
(2) Cost Per Watt
Panels that are more efficient in watts per square meter are generally less efficient in cost per Watt.
If money is more of a limitation than shade-free mounting plane space, it could make better sense to buy more Watts of cheaper "lower efficiency" PV modules.
stingray17
1 W
1 W
Postby Jay64 » Thu Dec 01, 2011 10:00 am
Great thread. Subscribed. When I move back home to Hawaii, I plan on building my own house, and I plan to incorporate as many alternative power, and energy saving techniques as I can. I'm going to start building some solar water heaters for my mom's houses to help her cut down on the utility bill in the mean time. I think to have an efficient house, you should definitely have a solar water heater system, not have the PV power used to power an electric water heater. It is a lot cheaper to make/buy a solar water heater system than it is to buy the xtra amount of PV panels it would take to power an electric water heater.
I've been finding a lot of good info on HomePower.Com
This particular page has one of the simplest, efficient systems I have come across yet. Less stuff to break in the long term, not wasting a lot of electricity to make it run.
http://homepower.com/view/?file=HP58_pg30_Bocci
Johnson64.Com "The stone age didn't end because we ran out of stones."
EV Bikes:
'13 Zero S 11.4kwh.
GS500, ME0913, Sevcon Size 6 Controller, 90v40ah Lipo, GSXR suspension..
'87 Hurricane 600, ME0709, 48v/50a SLA, Kelly KD72400, Magura Throttle, High Current Cycle Analyst.
http://www.evalbum.com/2275
Raleigh beach cruiser: 9C rear hub, stock controller, 48v10ah lithium, Cycle Analyst.
Phat Chopper: 9C front hub, stock controller, 48v12ah a123s, Cycle Analyst.
Jay64
1 GW
1 GW
Postby dogman » Thu Dec 08, 2011 7:56 am
One thing I saw over and over on solar power is that efficeincy of your use is the biggest bang for the buck. That means, better appliances, more insulation, and so forth cost less than more panels.
So for a home, the first step is always the obvious stuff. Insulate! Get rid of the old frige, get rid of the old air conditioner, etc. Anything 20 years old could be a horrible watt hog. Get a killawatt meter and find out what ghost power drains you have. Often the worst is the tv, cable box, dvd complex. Mine run about 100w when off, but plugged in. Computer is not so bad, but the tv cable box is horrible! But if you unplug it, you have to wait 15 min before the tv guide works because the memory gets wiped. Thanks comcast.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Postby Arlo1 » Thu Dec 08, 2011 10:26 am
Yup I agree we bought a new house in April which came with new efficient appliances. It has r40 in the attic and I plan to up that to r 60. I have been using LEDs as I can find them cheep enough to afford.
For example the under the cabinet lights that came with the house were xenon halogen and they run hot! I calculated what they would use for power for a year running 24/7 @$.08/kwh and it would be ~ $160 Then I found a set of LED under the cabinet lights on ebay for $27 shipped to the house! Found a 3 dollar 12v power supply and hooked them up measured them and in a year running 24/7 they will use ~$4 of electricity!!! And they are bright!
Arlo1
Postby Jay64 » Thu Dec 08, 2011 10:53 am
Does your 12v power supply plug into a regular outlet?
EV Bikes:
'13 Zero S 11.4kwh.
Jay64
1 GW
1 GW
Postby 1000w » Thu Dec 08, 2011 11:06 am
I have had 4.3kw (22 x 195w panels) on my roof for 10 months now and produced 5300kWh.
Best thing I ever did, especially with my government giving me 47c for each kWh that I send back to the grid.
Cheers,
Matt.P.
1000w
Postby Arlo1 » Thu Dec 08, 2011 1:28 pm
Jay64 wrote:Does your 12v power supply plug into a regular outlet?
Yup. I forgot to mention I was just at a local battery shop that sells solar systems and a 3.5 kw system is over $30,000 pluss tax!
Arlo1
Postby Jay64 » Thu Dec 08, 2011 1:33 pm
Do you think it would be possible to do the regular lighting in your house with these LEDs. You mentioned they were bright, are they bright enough for this?
EV Bikes:
'13 Zero S 11.4kwh.
Jay64
1 GW
1 GW
Postby Arlo1 » Thu Dec 08, 2011 2:10 pm
Jay64 wrote:Do you think it would be possible to do the regular lighting in your house with these LEDs. You mentioned they were bright, are they bright enough for this?
Yup. I will post links later i found screw in led bulbs for 15 at best buy and 5 on fleebay!
Arlo1
Postby liveforphysics » Thu Dec 08, 2011 4:41 pm
Arlo1 wrote: Found a 3 dollar 12v power supply and hooked them up measured them and in a year running 24/7 they will use ~$4 of electricity!!! And they are bright!
3.75w of power to light your kitchen ($0.12/kw-hr)? Best LED's made are ~130lm/watt, meaning sub 500lumens of light. About 1/6th the light made from a single florescent tube. Small kitchen or you've got good night vision. :-)
For ebike parts, don't be a douche, buy from http://www.ebikes.ca or http://www.MethTek.com
Justin saved the forum at great personal expense! The man is a legend and a hero!
liveforphysics
Postby dogman » Thu Dec 08, 2011 5:17 pm
I was looking at led lights, and led's labeled 20w equivialnt and compact flourescent labled 40w equivilant both were rated at the same actual wattage.
Wonder what the no lie numbers really are? Could be just misprinted, but maybe the screw in led's use more power than you'd think. Wasn't going to pay $15 to find out. In any case, compact florescents saved me enough watts to leave my tv box turned on.
Man, if somebody paid me 47 cents a kwh for power, I'd hock my afterlife for panels. nice!
dogman
Postby Arlo1 » Thu Dec 08, 2011 5:50 pm
These are just for under the cabnits bro not the whole kitchen!
Arlo1
Postby Arlo1 » Fri Dec 09, 2011 1:46 am
OK So I went down to my circuit board work room to test the current of a couple of my LED lights but I will have to bring my other meter home tomorrow.
I est all the POT lights to use ~ $32.75 if left on 24/7 for a whole year. @$.088/KWh Which is the high rate of our two tear scale here in BC. I will try to test them again asap. The under the cabinet lights use so little power its not even funny I only turn them off for the fear of my power supply in the corner of the kitchen hidden behind a cabinet having a issue!
Just under the cabinet
Under the cabinets and pot lights
All three sets of lights on incl the 2 fluorescent!
cold fluorescent driveway lights and 7.5w Led porch light
7.5w porch light
Phillips 7.5w porch light.
under the cabinet and pot lights
under the cabinet led
3w sink led
7.5w pot light
5w pot light
circuit room
LED experiment
5w vs 7.5 comparison!
Arlo1
Postby Kurt » Mon Dec 12, 2011 11:32 pm
1000w wrote:I have had 4.3kw (22 x 195w panels) on my roof for 10 months now and produced 5300kWh.
Cheers,
Matt.P.
Not bad. Quick calculations put that down as just over 18kwh a day :D That's spot on what the charts say for your system size in that area :D
Kurt
Kurt
Postby Arlo1 » Mon Dec 12, 2011 11:48 pm
SO 1000w you have got $2491 back from the gov for 10 months of power you sold them? 47c a kwh is aburd for what they give you!
Arlo1
Postby Kurt » Tue Dec 13, 2011 12:12 am
Arlo1 wrote:SO 1000w you have got $2491 back from the gov for 10 months of power you sold them? 47c a kwh is aburd for what they give you!
No... you get 47c for every kwh you feed back into the grid over what you consume. They charge you roughly 20c for every kw consumed .
for example over a 1hr period during the day you are consuming 1000w load and producing 3000w from pv . Over that one hr time period 2kwh would be accumulated on your export meter and you would be charged zero for the 1kw you consumed as your consumption meter wouldn't see any load. So basically you don't get paid for total pv kwh's produced. Only kwh's in excess of what you are consuming at any given time.
So a way to take full advantage of the system is don't use any power at home from say 8am - 4pm while the sun is out. Works great if your out of the house in the day at work as your base load is lucky to be 150w - 200w at any given time. I have a 1500w system at home and solar hot water. Even though the system only covers 1/2 my kwh usage it can be cost neutral over the year by getting 47c for every kwh exported effectively doubling its output on a cost scale as I am only charged 20c kwh. I keep my consumption(base load) low through out the daylight hrs usually around 100w while my system is producing 1000 - 1400w for 5 or so hrs a day I'm getting a good 40 - 70c an hr during this time.Then I can load up at night run dish washer, washing machine, watch big screen tv and so on.
Anything bigger than 2kw system on my conservative consumption and I would be making $ as well as having no consumption bill.
I will add to this to that on my contract i am assured this 47c buy back until 2028. One state in Au had a 60ish cent buy back but wasn't under the same conditions and it was recently withdrawn .
kurt
Kurt
Postby Arlo1 » Tue Dec 13, 2011 12:39 am
Wow your guys's power in Australia is expensive
Arlo1
Postby Kurt » Tue Dec 13, 2011 12:54 am
Arlo1 wrote:Wow your guys's power in Australia is expensive
Well for me at the moment its actually 18c kwh and 10c kw for controlled of peak load like hot water heater . But it varies across the state's and who your provider is. There has been some more increases recently . But working on 20c kwh is a good average perhaps even more soon for everyone in Australia as we now have a new carbon tax that is just being rolled out.
Although it might be expensive compared so some places like the USA where everything seems to be cheaper than it should be .This kind doesn't always work out to well or inspire energy efficient products Look at all the very economic turbo diesel small cars that come out from Europe inspired by there very high fuel costs.
Another point is over all electricity bill costs PA would likely still be much less in Au than many country's. Heating costs due to mild climate and the average house size is also being way smaller than the US . I remember reading some crazy fingers once what the average American consumed a day in kwh's. That said the average consumption is creeping up in Aust to as we take on the bad habits.
Kurt
Kurt
Postby 1000w » Tue Dec 13, 2011 3:34 am
Arlo1 Kurt has answered your question to me very well. I haven't got that full amount back due to some consumption both during the day and night plus some application fees and a new $300 two way meter purchased from the energy company (Western Power).
Here in Western Australia we pay 21c per kwh and I'm locked in at 47c for 10 years for my solar power production.
My best one day production so far is 30kwh. And for my last two bills which is 4 months, the power company owe me $700, this is our spring and early summer, so good conditions, loads of light and not too hot.
Cheers,
Matt.P.
1000w
Next
Return to Alternative Energy
Who is online
Users browsing this forum: No registered users and 1 guest
