Have You Ever Accidentally Shorted a Battery ?
Get the forum community involved in polls and surveys.
Yes
106
91%
No
10
9%
Total votes : 116
Re: Have You Ever Accidentally Shorted a Battery ?
Postby liveforphysics » Sun Sep 04, 2011 5:51 am
I've shorted batteries more times than I could count.
I've had shorts that blew apart 180amp anderson connectors. I've shorted massive packs by doing all sorts of stupid mistakes. Thank God with RC LiPo, if you short too solidly for more than a second or two (which is hard to do because it normally arc's away the contacting points in a split second), it simply pops the tabs and opens the circuit.
In the large EV game and TTXGP, there have been some folks with pretty epic shorts that make all the shorts that I've done seem pretty tame. Some needed skin grafts...
For ebike parts, don't be a douche, buy from http://www.ebikes.ca or http://www.MethTek.com
Justin saved the forum at great personal expense! The man is a legend and a hero!
liveforphysics
Postby Thud » Sun Sep 04, 2011 6:09 am
Best short out I ever saw was my good buddie Dave at a thursday night 1/10 scale buggy race.
He droped a fully charged 6cell pack into his front pocket on his baggy shorts (apptly named) & the pack settled onto his car keys blowin a firey hole through his pants....of cours the key was the ignition & that was destroyed. Had to drive him 30miles to get the spare set.
But i have experianced welders spots after vaporising 4mm bullets on a miscue :mrgreen:
get some......
Thud
Postby dbaker » Sun Sep 04, 2011 6:38 am
epic shorts for sure :lol: The baggy shorts car key could have been bad :oops: My dramatic short experiences have come from using a multimeter to measure voltage when the leads were plugged into the 10 amp ammeter socket :idea:
dbaker
Postby tedcs » Mon Feb 20, 2012 10:43 am
I dropped a wrench in a live 480 volt circuit breaker panel once.
The result was spectacular and I think it would count.
tedcs
Postby ohzee » Mon Feb 20, 2012 10:54 am
When I got my new triangle bag I was placing my batteries into it and hooking them up.
So 24s3p in total. Some of the wires were a bit buried so I failed to realize I was almost
done and needed to plug the 2 ends into my andersons/controller. Rather then do that
I plugged the pack into itself with 4.5mm bullets..
WOW what an explosion.. bullet connectors were gone and my left hand was totally black
all the way up to my wrist.. Looked a lot worse then it actually felt. Worse part was the
ears ringing and eyes flashing. Well and my pride.. 1st time I have admit this on the board heh.
ohzee
Postby richirich1113 » Mon Feb 20, 2012 11:40 am
Well, about five years ago i had the great idea to wire up some portable dvd player lipo's to run my remote control car. Well those are definatly not batteries you would want to short. I still not sure what i did but the end of the pack started to glow , the wham it started a pressure flame almost 1 1/2 ft long. it sounded like a jet turbine engine just blowing flame. This was on my bedroom floor. it was a good thing i had a fire extinguisher outside the door. A good blast and i thought it was out but woom it went off again. Another blast of extinguisher it was out but the battery at this time was just an ash. It left a 2ft burn of melted carpet and my room was a so solid of a cloud of smoke, i held my breath to get to the window and turned on a fan and the closed my door. It took like 3 hours to clear out. Afterwards i had to throw all my bedding and some clothes away and had to clean everything from floor to ceiling to get the toxic residu off EVERYTHING. IT sucked soooo bad.
I still used lipo's in my remotes but not homemade ones anymore. I think i still kida have a lipo phobia now.
KHS full suspension - 26x 2.5 Maxxis Hookworms
Avid Elixer 5 Hydraulic 203mm disks front/back
18 FET Lyen controller / HS 3540
21s - 10ah lithium ion polymer
richirich1113
Postby miuan » Mon Feb 20, 2012 11:48 am
I have a 20S 15Ah turnigy pack. I use no precharge circuit so every now and then I just change out the 4mm bullets. It was already quite late and I should've probably gone to bed instead, but hey... I took some massive steel pliers to cut off one of the plugs, but somehow forgot to separate the other wire.
Flashing eyes and black hands with burnt skin were well deserved, but the 5 x 5mm hole in my pliers was an unexpected bonus :)
miuan
Postby FastDemise » Mon Feb 20, 2012 5:21 pm
miuan wrote:... I took some massive steel pliers to cut off one of the plugs, but somehow forgot to separate the other wire.
Something similar is exactly how I ruined my good pair of wire cutters. Just had some SLA and saw my wires were too long and stupid me just clipped both wires without a second thought. lol, man I was laughing more than scared due to be knowing how stupid I was. The ones that scare the shit out of me is when I'm measuring a individual battery and 1 of the DMM probes slides into the other.
21" Hardtail, Docs Torque Arm, Lipo 20s2p, ebikes.ca 9C 8x8 and Lyen 6fet (both Mineral Oil cooled)
FastDemise
Postby Farfle » Mon Feb 20, 2012 5:31 pm
accidentally plugged a set of two 12s3p 20c packs into one another, instead of in series. What bullets? Have not had any 100v pack level shorts yet, I hope I never get to experience that...
The race bike:
24s5p 50c nano tech
Badass custom mofo outrunner 205x177mm 26kv
Peak power in : 318A at 91v
Peak power out: 24 Hp and 151ft/lb
Build to last...
"It will be assaulted by the elements, It will be ravaged by time and it will be destroyed by the user. BUT, if you Stick to the little rules: K.I.S.S., Overbuild everything, and test, review, revise, repeat. It will last"
Team Farfle blog!! http://www.farfleselectrics.blogspot.com
Farfle
Postby amberwolf » Tue Feb 21, 2012 1:48 am
I can't get it to focus well enough to take a pic, but I damaged another set of meter leads the other day when tracing out wiring on CrazyBike2 ot find out why the taillight stopped working. There's a "temporary" :roll: connection I made for the laptop adapter that boosts the voltage to the CFL taillight, which is basically just the tapped wires to the pack and to the light itself wrapped thru the holes on the AC cord prongs and taped with electrical tape. I'd intended to go back and splice things together properly, back when I built it, but it kept working and i kinda forgot about it. :lol:
Anyway, while testing it I accidentally stuck the meter probe all teh way thru one of the holes in the prongs, and touched the other with it. So that shorted the 14s 20Ah pack, and vaporized a pit in the meter lead and burned away about 1/4" of the 20g wire used to supply ground from the pack to that plug. Saw spots for a few minutes there. :roll: No harm done except the wire and meter lead tip. Easily fixed.
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby Sacman » Tue Feb 21, 2012 2:20 am
Threw my keys into my rear paniers where there was partially exposed battery connections.
Sparks shot out and blew a hole in the paniers.
When I retrieved my keys I found 2 of them were arch-welded to each other. :shock: :shock:
Sacman
Postby Ypedal » Tue Feb 21, 2012 7:14 am
Damn.. 56 to 4 to far !!!... :o
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Postby rojitor » Tue Feb 21, 2012 9:07 am
Once i almost weld the andersons when plugging, i turned it off and everything went ok again, i had to replace the connectors though.
rojitor
Postby tedcs » Tue Feb 21, 2012 9:13 am
Ypedal wrote:Damn.. 56 to 4 to far !!!... :o
If the number of events were considered, I could push the ratio higher than 14:1!
BTW: Steel reinforcing bars can be used if jumper cables are unavailable.
Everything I know is wrøng.
tedcs
Postby Doctorbass » Tue Feb 21, 2012 10:02 am
For those who might doubt about the dewalt 36V pack.. give a try... you'll see! :lol:
These damn BMS have their case connected to the negative of the battery.. and when you unsolder them.. you better disconnect the NEG first!!!.. otherwise when desoldering the positive tab, the risk of shorting the positive to the BMS case is really high! :lol:
The blast was impressive and the firework that produced felt on some paper on mt table and they caught fire! :shock: fortunately i had time to react!
I also shorted my two 14s4p A123 together ( i reversed one of the parallel connections :lol: ... This is impressive how fast a SB50 connector can dissapear... vaporize!
Any KFC sponsor here? :mrgreen:
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby lostrack » Wed Feb 22, 2012 3:52 am
My granddad was an electrician who was working on overhead live lines. He checked with his partner to see if the power was off, which the dude said it was, so he climbed up there and started working... He took a 30,000 volt shock and flew to the ground...and survived!
This man was winding his own TV sets with copper wire around a cathode ray tube before tv was being broadcast! If he was still around I'd be building an EV with him :)
lostrack
Postby e-bike-is-fun » Thu Mar 01, 2012 9:22 pm
Yea that's good.
I drove a boom lift w/two men into lines on a cage.
Men survived (pussy's) but shut down half the town.
e-bike-is-fun
Postby blake.thomas.80486 » Tue Mar 20, 2012 10:34 am
I dropped a wrench across a car battery once, it stuck and burned a chunk out of it and the terminal, thankfully lead acids are tuf and it didn't seem to harm it.
I took 20Kv or so from hand to hand (high voltage supply failed and arced) I felt my chest thump, it rather scared me.
blake.thomas.80486
Postby Ykick » Tue Mar 20, 2012 10:52 am
My dad told me about being in the Phillipines when a volcano erupted - the iron dust spewing into the immediate area shorted car batteries and created dramatic sparks and mini explosions. Power lines and transformers too!
Ykick
Postby Doctorbass » Tue Mar 20, 2012 12:58 pm
Whe3n i was in car audio hobby ( SPL contest) We had a VW gold with 8 parallel optima yellow top Group 31 12V battery with aluminum bus bar. A frind of mine droped a wrench and... yes it have fall directly on those :shock: :shock: :shock:
12V is not so high for arcing.. but still impressive when you have alot of amps ( 10 000+A) it's dangerous!
One of the aluminum bus bar ( 1" x 1/4") melted and fall on the car carped wich melted too :lol:
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby mdd0127 » Wed Mar 21, 2012 3:32 am
I did the same thing! We built an Isuzu pickup with six Cerwin Vega Stroker 12's and six custom, one off linear power 2500 watt monoblock amps. I can't remember how many yellow tops we had in there but we used 1" X 1" aluminum bar for the buss bars and after tightening the last battery, the wrench slipped out of my hand. It instantly vaporized in the middle and I swatted the molten metal off of the top of the battery before it did any damage. We had to bolt a chunk of 2" x 4" solid aluminum from between the seats to the top middle of the windshield frame to keep the 3/4" lexan windshield from blowing it's rivets out! That truck was hitting 174.9db......in 1996!
The most recent battery short was while demonstrating the coolness of my lipo parallel blocks to someone. As I was saying, "I designed these so that the batteries can only be plugged in correctly.", I touched the lipo bullets to the parallel block in reverse polarity causing a giant spark and the instantaneous vaporization of the two 75A castle bullets that connected the pack to the controller. My ego has a scar from that one...didn't burn my fingers though! While it was impossible to actually plug the battery packs in backwards, it sure wasn't impossible to touch the terminals together! :shock:
Turn it OFF!!!
Appocaloptimist! (thx Kiwi!)
mdd0127
Postby Ypedal » Wed Mar 21, 2012 6:33 am
Heh Heh.... i hates bullets.....
Andersons all the way. 8) ( no matter how many people try to convince me otherwise )
Ypedal
Postby Doctorbass » Wed Mar 21, 2012 10:06 am
mdd0127 wrote:I did the same thing! We built an Isuzu pickup with six Cerwin Vega Stroker 12's and six custom, one off linear power 2500 watt monoblock amps. I can't remember how many yellow tops we had in there but we used 1" X 1" aluminum bar for the buss bars and after tightening the last battery, the wrench slipped out of my hand. It instantly vaporized in the middle and I swatted the molten metal off of the top of the battery before it did any damage. We had to bolt a chunk of 2" x 4" solid aluminum from between the seats to the top middle of the windshield frame to keep the 3/4" lexan windshield from blowing it's rivets out! That truck was hitting 174.9db......in 1996!
Are you sure of your 174.9dB score you mentionned?.. because the loudest SPL that waas made in 1998 it was John Henry with the 12x 12inch woofer and the Mmats amp that had 174.7dB back in 1998.... i think no one ever beated that score BEFORE 98 ?
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Ypedal » Wed Mar 21, 2012 10:12 am
Ypedal
Postby el_walto » Wed Mar 21, 2012 10:14 am
I once shorted a 48V 15Ah ping battery. Melted the fuse AND the fuse holder and made a very bright flash of light.
el_walto
Next
Return to Polls & Surveys
Who is online
Users browsing this forum: No registered users and 1 guest
