It's been a while since I posted an update. Was pretty much riding it till I started working full time again. Not much riding these days due to weather as well. About 3 weeks ago I actually had a break down. The ratcheting sound after pushing the bike pretty hard up a hill became quite loud and soon after just a hum without any power to the wheels. I suspected the clutch had finally given up. About a week later, I finally had time to take it apart. I found that keyway had sheared completely in half. It had damaged the surface as well, but this wasn’t much of a problem to smooth out. It must of taken a lot of torque to do that. I replaced the keyway with one I milled out. The clutch was also replaced since it had much more rolling resistance than the new clutch and I was not about to do another rebuild. The good news is the gears look great after 3 years of hard riding and jumping. Here is a picture of it after all the grease had been cleaned off. It looks like it was just bought. The clutch replaced was another V3. It sounds like the newer V4 clutch has even lower rolling resistance. I will have to go that route next time.
- gears still looking new.jpg (74.84 KiB) Viewed 1219 times
- split keyway.jpg (73.99 KiB) Viewed 1219 times
- Damage to surface from split keyway.jpg (71.25 KiB) Viewed 1219 times
This weekend was the first time I was able to take it out riding again. Sure felt good to hit the trails. It’s been warm for this time of year as well. The bike performed great as usual and left me with smiles. Looking forward to spring. I should have replaced the rear tire while I had it apart. I need to find a good tire that can last a bit longer than the soft trail compound of the velociraptors. The center is pretty much bald with the sides still looking good, and this is pretty much after one season. Any ebike trail tire recommendations out there? You can see the wear is actually into the liner now.
- tire wear.jpg (55.75 KiB) Viewed 1215 times
I still need to get the covers completed so it fully encloses the Lipos. It should be done this winter. I had a bad crash worth mentioning while riding the trails at night about a month ago, clipped a tree and went down hard. Stopped night riding after that. Need to have a lot more lighting if I were to do it again. Only had one magic shine and a low power helmet light.
