Grinhill III - "Supercommuter" featuring Recumpence RC drive
Re: Grinhill III - "Supercommuter" featuring Recumpence RC drive
Postby recumpence » Tue Feb 16, 2010 6:34 pm
Good to see the progress. :)
I love welding. For me, it quickly became addicting!
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
recumpence
Location: On Earth right now. That can change at any time, though..........
Postby AussieJester » Tue Feb 16, 2010 6:42 pm
DC Inverter TIGS are getting ridiculously cheap these days, i been doing a lil research last few days both the Weldsmart and Alltrax models
get a pretty good rap, Transformer welders are old and outdated, inverters is the new trend. WeldSmart even have a local store to me! 595 for 160amp DC TIG...Better again Welders Direct 500 bucks 200amp DC pulse TIG for 500 even 24 delivery to me... OK so they can't do aluminium but for 500 bucks nice neat welds in steel, stainless and chrom is possible...guess what im getting next Mr R :-)
KiM
AussieJester
Postby recumpence » Tue Feb 16, 2010 9:17 pm
Did you catch my earlier post?
I have a customer with a Miller liquid cooled aluminum TIG I am getting (swapping for some work). :D
I will be fully setup soon!
Oh, we have a huge CNC lathe coming tomorrow (my landlord has it coming). We may soon be manufacturing finned motor cans and other bits.
Anyway, sorry for clogging up Grin's thread.
Back on topic!
Matt
recumpence
Postby EVTodd » Sat Mar 06, 2010 7:09 pm
Any updates on this project yet?
New Tidalforce friction drive build: viewtopic.php?f=28&t=28029
My Friction Drive Outrunner Setup: viewtopic.php?f=28&t=9652&start=330
EVTodd
Postby Grinhill » Thu Mar 11, 2010 8:39 pm
I'm still chipping away, Todd, but don't get much time to spend on it these days, only a few hours each weekend.
Here's an update on my battery pack parallel connectors (first mentioned here: http://endless-sphere.com/forums/viewtopic.php?f=14&t=16219&p=239742&hilit=+bus+bar#p239742 )
With a bit of dremel work, I got the red sleeves to fit over which is great for preventing shorts.
Also made a balance parallel connector from a piece of veroboard:
I discovered that my proposed drive mounting position will have chain clearance issues, so I need to push it further back on the rack.
As an alternative, I decided to make use of some kerbside-find bikes, and am now doing a mount for the back of a BMX. This is made from a cut-up frame, which has a 1.5" tube. This will let me mount the drive easily using Matt's custom made drive mounts for round tube. This will also allow me to keep my daily ride on the road while sorting out the new drive.
Here's a mockup, note the rear 53-tooth sprocket is held on by cable ties at present, but there's plenty more room for chain with this setup than I had on the MTB.
1995 Giant Hybrid - Zeta2 with 12V 7AH SLA - removed after one year.
2006 Converted Giant to Geared Brushless Rear Hub with 24V 17AH SLA - bike stolen 2007.
2008 Hardtail MTB Disc Brake - lightweight RC/LiPo system.
Grinhill's Medium-power RC-Motor Hardtail build
The Grinhill Mk2 RC-motor drive
Grinhill
Postby AussieJester » Thu Mar 11, 2010 9:14 pm
Personally i have to say i'm a Lil disappointing not too see the original planned rack used Grinhil.
KiM
AussieJester
Postby Grinhill » Sun Mar 14, 2010 4:48 am
Don't worry, still gonna happen, Kim!
This one's just a 3D model to get things sorted like chain location, wiring loom lengths etc, then can all be transplanted to nice aluminium rack.
I still haven't found the right aluminium yet, there are a few fabrication places near where I work, will try and get access to their scrap bins at some stage.
Grinhill
Postby AussieJester » Sun Mar 14, 2010 12:55 pm
Its taken you 7 months to find 'the right' aluminium? tell me EXACTLY what you need ill send it to you free of charge
i want to see this project up and running buddy, i have good suppliers 10 minutes down the road from me.
KiM
AussieJester
Postby Grinhill » Mon Mar 15, 2010 3:20 pm
Thanks Kim, the main tube is still on the scrounging list, which would ideally be 40 x 40 x 3mm square tube say 400mm length. I have no use for the other 5 1/2 m of a length which is why I am balking at buying it off the shelf - if you can find such a small piece, I will gladly pay for any costs to send it over.
All my other ali is lightweight angle and mouldings 1.5mm, 3mm etc, so I would also like some offcuts in 5 or 6mm thickness for making brackety bits, even chunky 10mm stuff would be handy.
The ali seems to take me 3 times as long to cut and shape as the steel, I only want to do it in ali once. :D
(the main missing ingredient for me at present is SPARE TIME :cry: )
Grinhill
Postby AussieJester » Mon Mar 15, 2010 6:41 pm
Having to buy by the length is a bitch all the steel tubing i use for frames is by the length sometimes they
will do half lengths, 6meters is usually the norm though..I shall see what i can do later today and get back to you.
I have no doubt i can get it whether its in that short length is another story... :: fingers crossed ::
KiM
AussieJester
Postby heathyoung » Thu Apr 01, 2010 12:27 am
How much 10mm did you want? Ive got heaps of small plates 6" by 4" or so I'm not using, decent stuff too. I'm in charlestown btw.
New evil decided - GNG offroad build on Craftworks DHR with 12S4P lipo. Aim - Light, balanced, powerful, able to climb a tree.
Project Vectrix restarted. Status - BMS + Charge control redesign (read faffing with batteries again)
heathyoung
Postby Grinhill » Thu Apr 01, 2010 9:59 pm
thnks - pm sent :)
Grinhill
Postby Grinhill » Mon Aug 16, 2010 7:35 pm
From EVtodd on my Frankenscooter thread:
Not to be an ass but that kind of sucks. I don't remember the exact details of the contest but didn't you get Matt's drive for free to build that original design? Maybe the drive should be sent back to Matt so he can run the contest again. Heck, I'll build a version of your "super commuter".
I was really hoping to see what you came up with. I voted for you! I demand satisfaction!!! Ok, maybe it's not that big of a deal, I'm just sayin'...
Yep, fair call Todd. Sorry to any members offended by the lack of delivery. :(
The contest-winning design is of course "open source", so it's available for use by anyone who thinks there's some merit in it, but note it is only that, a design. :D
The great thing about ES is that there are so many different approaches for members to reach their various goals. It doesn't always work out as we first hope it will. My present (more humble) efforts are aimed at getting this drive running one way or another. The following is not intended as excuses, but this is simply my evaluation of whether or not the Supercommuter would work for my existing MTB:
A RHS drive setup would cost an extra $500 (dual-drive, shifter, two WI freewheels), and this would reduce the available pedal gearing ratios, a sacrifice I'm not prepared to make. I had a couple of attempts at getting a LHS drive setup going. Firstly I machined 2mm off the top-hat adapter, but still the disc rubbed on my frame. I do not want to risk frame failure by crushing to provide clearance. I also discovered that the calipers did not clear the adapter either. So, I wouldn't be able keep the existing hydraulic discs. Again, it would be a backwards step to go to v-brakes on the rear. At this point, I didn't proceed with work on the drive setup.
The bike I had intended to install the Supercommuter on is presently still running the Grinhill Mk2.
Grinhill
Postby EVTodd » Mon Aug 16, 2010 8:30 pm
Just to clarify, my point wasn't that I wanted to make that design just to make it. My point was that the design is why the drive was given out for free. I'd love to get my hands on one of Matts drives for free which is why I said I would complete your contest winning entry. And I was really more joking around about that. Well, kinda...
My intent isn't to make a big deal of out it anyway. No skin off my back. I really just liked your previous work and I guess I'm pissed that it wasn't me that got one of his reductions for free. :cry:
I'll shut up about it now. lol
EVTodd
Previous
Who is online
Users browsing this forum: Nelsjourney, Rodney64 and 10 guests
